Like Tree198Likes
Old 03-18-2014, 06:30 AM   #20686
whitrzac's Avatar
Trader Rating: 95 (100%+)
Originally Posted by KA2AEV View Post
Wow never seen anything like that. Have you been running them along time? That looks to be
Either a manufacturing defect or a stress fatigue fracture
That one is ~4 weeks old.
IDK how old the other one is, it came in my mini and I never used that diff(outdrives are fubar)
whitrzac is offline   Reply With Quote
Old 03-18-2014, 07:55 AM   #20687
Originally Posted by Boons View Post
Thanks Granpa.
I pulled my motor out last night and yes it has 540 SH etched on it. I have never cleaned the motor as my car always seemed quite fast. My car/motor was new last July. Now that I've improved my driving and I'm in the A finals, I've noticed some of the other Mini's can pull past me on the straight. From what I've seen they have the motor with the grey end bell like mine.
After blasting my motor out with HPi motor spray I applied Tamiya bearing oil to the outside of the bushes at both ends. You mention about polishing the comm, what is the best method for that?
Cheers!
You'll find these and a couple of other methods on the Silver Can Motor thread. Generally, using motor spray is not a good idea cause it "dries" out the brushes, the exception being if you use VooDoo comm drops.
Method 1. Start with a motor with an old pinion gear. Find an old oil bottle with a needle tip, fill with a metal polish like Brasso, or my favorite, Mother's chrome polish. Apply the polish directly on the comm, run the pinion back and forth on the table top, or spin the motor over by hand. Be sure to put a towel down to protect the table top, before running the pinion on it. Do not spin the motor over under power or you can "clog" up the slots in the comm. Flush the motor out with a stream warm water or with a water syringe. Check the comm, it should be perfectly clean, copper colored, with a "satin" finish. If not, repeat until it does.
Method 2. This is one that Doc Mertes posted as the one he uses. He takes a few drops of VooDoo drops, spins the motor over at low voltage, then uses motor spray to flush out the gunk. This method will give you a comm that looks polished and will not dry out the brushes because of the use of comm drops. Also, if you use 1 or 2 drops of VooDoo drops before each run, you won't have to clean the motor nearly as often. Don't use too much cause your motor will run slower if you do or can create a small fire. VooDoo drops are used by the slot car guys and can be found on e-bay-----not cheap. but worth it.
Some additional stuff. If you have run the motor with little or no attention it could use a general cleaning. A 50% solution of Simple Green, soak the motor a few minutes, then run the motor in the solution for a few seconds. Flush out with water, dry. lube and reinstall in the car. I imagine, regular liquid dishwashing detergent would work also, but don't know for certain, having never done it myself. Sounds like a whole lot of hassle, but a clean motor is usually a few hundred rpms faster than the same motor "dirty". I've seen motors that have picked up as much as a thousand rpms at 7.2 volts. If the motor was really dirty, use Method 1 before Method 2.
You'll find this stuff on the Silver Can thread and a bunch more. Some of the early stuff is preoccupied with "black magic" and tall tales, but the later stuff is more valid.
Granpa is offline   Reply With Quote
Old 03-21-2014, 04:19 AM   #20688
Boons's Avatar
Thank you for taking the time to write all that, very useful!!
On another, but similar matter, I've taken the motor out of my 1980's Kyosho Outlaw and it turns out to be a very shiny Johnson motor with a metal black end bell.
Are these any good for Mini racing??
Cheers!
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 03-21-2014, 06:54 AM   #20689
Cheers!
That motor may be a 540J which is the motor of choice. Be careful cause some of the older 540J motors had soft brushes that wore very quickly when run under water. The most recent examples had CS molded into the side of the brushes. These, generally, were a tad faster than the "older" ones.
With a little research and a little effort, you'll have a motor advantage over most of your competitors. Strong motors and good set ups have kept me competitive with much better drivers for quite awhile.
Old 03-21-2014, 08:37 AM   #20690
monkeyracing's Avatar
I've stocked up.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 03-21-2014, 09:07 AM   #20691
cartix's Avatar
Trader Rating: 33 (100%+)
Granpa-Thanks for the motor cleaning tips, heaven knows I need to clean mine.
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 03-21-2014, 09:08 AM   #20692
whitrzac's Avatar
Originally Posted by monkeyracing View Post
I've stocked up.
What body is that?
Old 03-21-2014, 09:14 AM   #20693
Blitz Racing - Jazz, RS1, GTI and C30. Got them in for a group buy, retail packaging on the side. Saves a lot on shipping.
Stab it and steer.
Old 03-21-2014, 09:35 AM   #20694
Boons's Avatar
I quite fancy trying the C30, that's 210 (swb) isn't it?
Old 03-21-2014, 10:11 AM   #20695
so im about to start assembly of my m05. my oldest son is going to be racing occasionaly with it. ill be driving it most of the time. for the time being i will not have either the ball diff or a sealed gear diff. can i lock the stock diff with some putty? will i make much of a difference? im sure it will push going into corners but it shoud have some drive coming out am i right? i allready drive my 4wd with a spool up front. will this hamper performance or will it help? just qurious on what it may do. ill get a good diff later. i just remember when i had my m01 it liked to diff out alot. (spin inside tire in the turns).
dragonracing is offline   Reply With Quote
Old 03-21-2014, 03:15 PM   #20696
poeee's Avatar
Yes, I believe the Volvo is a SWB.
poeee is offline   Reply With Quote
Old 03-21-2014, 03:52 PM   #20697
It is, yes. The rest are 225mm. The ones right on top are the RS1. The nice thing about these shells is they are available in both 0.8mm and 1mm thicknesses. I've been running a 1mm and it's a tank.
EDIT: Forgot to mention. I've been running a really crude M03 the past few days and it's absolutely magic compared to my M05. The only alloy on the car is the old style TL01/M03 steering knuckles. Everything else is plastic, right down to the dampers. Here's the part i don't understand completely. I'm running a fairly loose ball diff and I'm actually staying closer to the cars with oil filled diffs and spools than I could with any car I had equipped with the same stuff. I'm generally lucky to be in the bottom of the A, but I seem to be in the running with this little beast. As much as anything else, I think it may just be that the car is much easier to drive well. Damn you, Tony Gray and your timeless mini wisdom and insight!
Stab it and steer.
Old 03-21-2014, 07:22 PM   #20698
just looking thru my Kamei vw rabbit M05 and it came with slicks. #42214 39244. anybody know what slicks they are? they seem to be non reinforced so im thinking super slicks? anybody know what compound they are? they seem pretty grippy. i dont think they will ever hit carpet since we only have 3 races left for the winter series. they it on to pavement. its still fairly cold so i dont think these will be very good till its hot out. any help is greatly appreciated.
Old 03-22-2014, 07:40 AM   #20699
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Saturday finally - TCS testing awaits!
madjack is offline   Reply With Quote
Old 03-22-2014, 08:11 AM   #20700
Boons's Avatar
I always believe that the minis seem to get better as they get older and looser, like they've 'settled' down a bit? My new M05 was unpredictable for months, I could not seem to make it work. Admittedly I've made changes but it seems to have 'settled' down into an M03 pestering racer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
tvih
