Old 10-03-2006, 04:44 AM   #2056
makes sense tony, tanks for letting me now
hey i got another question: besides rocket minis and crazy experiments like that trying to beat a speed record, which is the fastest motor + pinion you run in a normal club track?, i mean not oval or something
DrKucho is offline   Reply With Quote
Old 10-03-2006, 04:50 AM   #2057
tony gray's Avatar
We always run Sport-Tuned with 20t pinion, Thats the standard over here.
We tried 23turn motors once and only went a tiny bit quicker. The reason why? On a mini, you lose all the extra grunt in wheelspin. And around a track you really dont gain any advantage.
tony gray is offline   Reply With Quote
Old 10-03-2006, 04:57 AM   #2058
i am runnig novak SS4300 Brushless , as i am the only one running mini , the other guys run tourings so i have to push the mini to the limit ... novak says that the 4300 is simlar to a 19T brushed
i realized the wheelspin , i have to gun it slowly, but once its on the way it goes very fast on the straight
Old 10-03-2006, 05:13 AM   #2059
tony gray's Avatar
If you've seen the tracks we run on (Check out the video) a brushless wouldnt work, even the mild one you're running.
However, on the oval.....
Old 10-03-2006, 08:56 AM   #2060
minimanintaiwan's Avatar
Default servo saver
earlier posts talked about a high torque server saver. Can someone tell me how it would improve performance/handling?
minimanintaiwan is offline   Reply With Quote
Old 10-03-2006, 09:01 AM   #2061
i was looking not to improve performance , just to avoid the play the standard servo saver can have
i just re-checked mine and it looks like the play was coming not because the standard servo saver is playly , it came from the plastic input piece where the servo match , it looks like it was weared, so im gonna replace it for a newer one which matches more stiff and try again
Old 10-03-2006, 02:52 PM   #2062
tony gray's Avatar
I think you'll find that you can spend a lot of time playing with servo savers and such to remove the play, and end up with a car that's actually a pig to drive.
Contrary to what you might think, some cars are engineered to have that little bit of play in them. I had several Corallys a number of years back where they specifically said to NOT take out any of the play in the steering system
Minis are similar. We spent ages taking it all out and ended up with a car that was truly awful. They just dont work like that. We use the standard servo saver with Tech Racing turnbuckle and ball joint kit. Still has a little play, but lasts a lot longer in normal use.
Old 10-03-2006, 03:45 PM   #2063
If the servo saver is too weak as you turn the wheels might not turn because the saver flexed.
On the otherhand you don't want too strong of a servo saver for a particular servo because it wouldn't "give/flex" from an impact before something (gear) breaks in the servo.
Sydewynder is offline   Reply With Quote
Old 10-03-2006, 03:53 PM   #2064
TonyGray
Did you finish the mini Assassin yet? If you did I want to ask if you see any wheel chatter when you turn the front wheels and throttle with the car off the ground. Thx
Also where did you guys get the ABC Genetic? The shipping from an HK place to the US is a killer.
Old 10-03-2006, 04:26 PM   #2065
tony gray's Avatar
The Baby Assassin isnt going to be a runner, shelf-queen only I'm afraid. So I wont be able to tell you what it runs like... Got way too many 4WD Minis as it is and I cant run them all. Sticking to only running the Jap cars (Active Hobby, HPI etc) as they're easier to get bits for.
The Genetic came from rc-champ in Japan. Although for us Japan or HK are both OK shipping wise to Australia. Bit further for you guys though.
Old 10-03-2006, 04:39 PM   #2066
The mini assasin actually runs quite well besides the wheel chatter. It's quick with lots of steering. Then again I'm running carpet with foams.
I'll check RC Champ for the ABC. You mentioned a belt drive version soon. Do you have any pics? Thx
Old 10-03-2006, 05:52 PM   #2067
tony gray's Avatar
We have a couple of pics somewhere but the cars only been shown once or twice. And no official word on production yet.
I'll try and find the pics we had.....
Old 10-03-2006, 06:04 PM   #2068
Customworksking's Avatar
Trader Rating: 69 (99%+)
Default servo
yah I run the tamiya white heavy duty saver everything else is stock/tcs legal
cur runs fine with some play in it....
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-03-2006, 08:03 PM   #2069
raffaelli's Avatar
Why does Tamiya include shafts with the M03 bearing kit?
24ITA
raffaelli is offline   Reply With Quote
Old 10-03-2006, 08:07 PM   #2070
raffaelli's Avatar
Anyone working on the gear diff to stiffen it up? Pack with grease? Seems to me that if the diff action was slowed down, there would be less wheel spin.
24ITA
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
