Like Tree55Likes
Old 03-11-2014, 08:50 PM   #20641
madjack's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to madjack
Originally Posted by Carl Giordano View Post
Hey guys I know many have been trying different 21.5's to try and find the "right" motor. So far, I've run the R1, Phanton Killshot, and Reedy Mach 2. Frankly its troubling that each have so many variables (ie: different rotors, stators, timing ranges, etc) What I've found that works the best is the broad band rotors (not sure if i should have geared down with the high rpm rotor as I ran a 20t pinion for all)
The Reedy seems to offer the best balance between torque and rpm. Not sure if this is the absolute best, but its just opinion at this stage. Just came back from the TCS race at Horsham this past weekend and although happy with the results, disappointed I did not get to practice earlier switching from my M05 to M03 and not getting to fully test all the motors I have. Planning on a practice weekend in a few weeks to further weed out the best motor for my driving style.
On a separate note, I know we're all expected to run blinky mode. So i purchased a hobby wing just stock speedo for the M03. Does anyone have any experience with this speedo and how does it compare to a tekin rs? other than the price! I still wish Tamiya would release a spec motor and speedo
Carl, I run a HW in my F1 and it works well. That said, I needed to update the firmware and pick up a programmer to get the most out of it. Once completed, the ESC performs very well.
madjack is offline   Reply With Quote
Old 03-11-2014, 09:27 PM   #20642
fresnojay's Avatar
Carl, this is where I got mine. http://www.petitrc.com/reglages/tami...yaMChassis.htm
Out of town working right now and the laptop is at home. Otherwise I would offer up the one I have on it.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 03-11-2014, 09:32 PM   #20643
fresnojay's Avatar
As far as motors go I run the Revtech Killshot Rpm 21.5 in my mini and it puts out well to me. I also use the hw justock esc in my mini and gt3 car. Have no complaints but as stated the programming box is a huge plus when making changes.
Jason
Old 03-12-2014, 07:57 AM   #20644
SRC_DRIVER's Avatar
Trader Rating: 60 (100%+)
Jason
Just curious.. What good is the program box if you have to run blinky mode? I thought the whole point was that you couldn't dig into the speedo. Isn't blinky mode supposed to be all pre-set end points?
www.Medlinracing.com
http://www.youtube.com/watch?v=VVIyGKSyAGg
SRC_DRIVER is offline   Reply With Quote
Old 03-12-2014, 08:23 AM   #20645
madjack's Avatar
It allows for fine tuning of neutral, minimum throttle, brake etc. (timing/boost will not change as it is locked in spec mode).
Old 03-12-2014, 08:54 AM   #20646
oreo's Avatar
Greetings. Hey Fresnojay, thank you for postin' the link to petitrc-I'd just built my first M05!(kinda had fun buildin' it till i'd got to the rear suspension- s,m, & l -arms in the wrong direction) I wish i'd had bearings before building it.
Rc 10L (x6)
(.......in 2010, I jus' may get to run one.)-Irrgang Racing Service;TeamCRP. R.I.P. Billy 105
oreo is offline   Reply With Quote
Old 03-12-2014, 06:18 PM   #20647
Trader Rating: 44 (100%+)
Anyone remember what cst the stock diff oil is on the 3racing gear diff??
Justin33 is offline   Reply With Quote
Old 03-12-2014, 07:29 PM   #20648
poeee's Avatar
Not sure, but won't even be close to what you wanna run in an M05. Not sure about M06...
poeee is offline   Reply With Quote
Old 03-12-2014, 10:21 PM   #20649
Problem is i had great success with the stock stuff but just need to up the cst by a little bit i dont like the feeling of a really tight diff. I want to say the stuff it comes with is like 5-6 thousand so i would want to gomto like 10,000 but i want to be sure
Old 03-12-2014, 10:43 PM   #20650
monkeyracing's Avatar
I recall the stock stuff being pretty thin. Maybe around 40wt.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 03-12-2014, 10:50 PM   #20651
ruebiracer's Avatar
Hi Justin,
stock oil of the 3-Racing diff is "2000", probably cst.
But it feels stiffer in the beginning, as the 3R needs quite a good time to run in properly. For my M06 I started with 1000 in new condition, and changed later to 2000.
Last race I run with another M06 very competitive, he even used 10000cst, he admitted after the Race. (this was on a medium grip carpet).
I think its no problem if you start with 10.000 in your M05 to find your preferences.
Br,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 03-13-2014, 10:41 AM   #20652
AngryRog's Avatar
First outing with the HW Justock at my local every Saturday MMafia Nats. Quite please with the speedo. Hard to justify the $100+ difference of the Tekin in my other cars.
Anger, K-Speed, Mini Mafia, NitroHouse.com
M03, M05v2 Pro, M05v2-R, FF03-R, TA05v2, TRF419X, Roche P12
AngryRog is offline   Reply With Quote
Old 03-14-2014, 07:01 AM   #20653
Boons's Avatar
Looking forward to running my new Tekin FX-R pro in my silvercan M05 tonight. First indication on th bench is that has a slightly higher pitch at top speed. The only thing I'll have to try and avoid is crashing as the reverse seems to take ages to engage Maybe with the hotwire I can reduce this delay?
Re the 3 Racing diff questions, I fitted my 3 Racing diff with 5,000cst oil from the begining for around 6 months sometimes racing twice a week without any problems. No leaks, still feels as tight as when I fitted it. Good product
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 03-14-2014, 01:23 PM   #20654
Has anyone been running the Blitz Racing shells? I'm looking for opinions, specifically on the Jazz and the GTI.
I've got an RS1 in the 1mm thickness. I love the weight and durability of the thing. I know I'm not going to win an A main anytime, so I may as well have fun and try to make my equipment last. It's hard to tell if it's a stable shell, as I've been running it on my M04. There's not much that can make that go in a straight line.
Other than that, I like the shell. It looks kind of mean.
Stab it and steer.
Old 03-14-2014, 04:59 PM   #20655
sosidge's Avatar
The GTI is smaller and maybe a bit faster overall. The Jazz is taller and maybe has relatively more steering. This is with the wings attached. GTI I found to be very unstable without the wing, so I never tried the Jazz without it.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
