Old 03-02-2014, 08:22 PM   #20581
Carl Giordano's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Granpa View Post
The new generation S-Grip premounts are a lot softer than the old tires. For most it's instant traction roll if you don't cyano the sidewalls of the fronts. Some will cyano the rears also, but some don't.
If you feel the sidewalls, they fold right over with very little pressure. They also wear out much quicker than the old ones. Once properly treated with glue, they'll give you some good lap times.
Thanks for the tip. Are you using thin or medium cyano? are you also glueing the first rib on the outer edge of the front tires or just the side walls. What about the inside side wall?
Mugen Racing / OS Engines / KO Propo / Byron Fuels / TOP Racing / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho RB6
Carl Giordano is offline   Reply With Quote
Old 03-02-2014, 08:38 PM   #20582
Has anyone had success running a Tamiya TA03-RS with a LWB M03\05 body? Does it work, or would it be better to get regular TC bodies?
pizzaboy192 is offline   Reply With Quote
Old 03-02-2014, 10:00 PM   #20583
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by monkeyracing View Post
Jay, I know the M05 is brittle as hell, but why not just slap a new chassis together?
I helped Jay with his car today, and I think we identified the problem. No, it wasn't Jay.
My m03 was somewhere between awful (early) and tolerable (late) but not perfect today. Which is more than I can say for my FF. I learned a whole lot about setting up FWD today, or at least how to fix problems.
Can't wait to test again.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 03-02-2014, 10:01 PM   #20584
It's much easier to use the standard tire glue rather than the thin. The thin just runs all over the place, but the medium needs to "smeared" in to place.
Fronts----glue outside rib plus the sidewall
Rears-----just the sidewall
Actually, how you glue the tires sorta depends on your set up and how the car's handling. I think you've been around for awhile so won't presume to tell you how to do this. But, you do have to do the fronts to the edge of the 1st rib or it's no good at all. Whether you do the insides or the rears just depends on whether your car is "loose" or "tight".
Granpa is offline   Reply With Quote
Old 03-02-2014, 10:24 PM   #20585
Usually apply thin cyano with a q-tip while the tire is spinning on a balancer And use kicker to get a nice smooth finish. Glad I stil have a ton of he older tires for outdoor racing. Thanks again for the response
Old 03-03-2014, 02:41 AM   #20586
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Had a very frustrating days racing at our indoor series on Saturday. Set TQ for round 1 and then failed to finish rounds 2 and 3 and each of the 3 A Final legs.
My car runs Spektrum radio/micro receiver, Savox 1251MG servo, Teu105Bk ESC, Sport Tuned Black Can motor, 7.2V 3700mah NiMh cells. I run a 3Racing Motor cooling fan from the Aux port of the receiver and have a glitch buster plugged into the bind port.
In Round 2 the car stopped after 290 seconds, no forward/reverse power but front wheels were able to steer, the ESC and Motor were hot. The gearbox had started to make a noise so before leg 3 I stripped it and found some bent teeth on the intermediate gear, replaced it and rebuilt it.
This time the car only ran for 100 seconds before stopping, after 40 secondss rest it started responding again but only went for a further 75 seconds. A fellow racer measured the temp of the motor/esc at 61 degrees.
For the first leg of the Finals I changed the Esc to a TEU104BK , the car stopped after 130 seconds, rested for 60 seconds and then ran for 70 seconds before coming to a halt again, each time this happens the steering is still working.
I changed the motor for leg 2, car stopped after 120 seconds. ESC/Motor temp 53 deg.
For the last leg of the final I changed to my spare car, It's SWB instead of LWB with same radio set up, savox 1256, 105ESC, no glitch buster, no fan.
I ran the original motor from the qualifying. Got as far as lap 17 and after 245 seconds the car stopped again.
Many of the guys racing use a similar setup to mine yet I was the only one who had any problem during the day. The same car has been faultless throughout the 9 previous rounds of the championship at the same venue this year.
Any thoughts ?
marcos graveyar is offline   Reply With Quote
Old 03-03-2014, 03:28 AM   #20587
VooDooPH's Avatar
Send a message via Yahoo to VooDooPH
the 104 and 105 esc's tend to become problematic after some time. the 101 is actually more reliable. but if you could use a "higher end" esc, i would suggest you go for it.
also, i remember spektrum having some glitching problems when running along with 2.4G Futaba's and Sanwa's (TITC 2011 i think...)
hths
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-03-2014, 05:23 AM   #20588
whitrzac's Avatar
Trader Rating: 93 (100%+)
Get rid of the spektrum
spektrum+savox=
whitrzac is offline   Reply With Quote
Old 03-03-2014, 08:24 AM   #20589
Have to use the kit Tamiya ESC's.
Anybody know what level the thermal cut-ouy is on the 104/105?
Old 03-03-2014, 09:24 AM   #20590
sosidge's Avatar
Old 03-03-2014, 09:25 AM   #20591
AngryRog's Avatar
Trader Rating: 19 (100%+)
spektrum+savox=
+1. Savox draws a ton of juice. The cap is just a temp solution.
Anger, K-Speed, Mini Mafia, NitroHouse.com
M03, M05v2 Pro, FF03-R, TA05v2, TRF419X, Roche P12
AngryRog is offline   Reply With Quote
Old 03-03-2014, 09:57 AM   #20592
Any suggestions for a replacement for the Savox ?
Old 03-03-2014, 10:01 AM   #20593
rramjet's Avatar
Location: Everett WA in the Summer Mesa AZ in the Winter
I think you need to look at the gearbox/drive system again. Something may be causing a drag resulting in hot motor and ESC. Just a guess.
Good luck.
Associated TC7.1
Tamiya M05 Ver II Pro
TC4 Late Model
CW GBX2
rramjet is offline   Reply With Quote
Old 03-03-2014, 10:07 AM   #20594
whitrzac's Avatar
I recommend replacing the spektrum...
Look at the airtronics Mt4, futaba 4pl, etc.
Old 03-03-2014, 10:12 AM   #20595
Laguna Bozo's Avatar
Wouldn't it be a lot easier to get rid of the Savox? With one of the upgrade receivers, Spektrum no glitch, which wasn't mentioned as a problem anyway.
Craig Richter
Laguna Bozo is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
SEO by vBSEO 3.5.0
