Like Tree198Likes
Old 02-28-2014, 04:41 PM   #20566
KA2AEV's Avatar
Originally Posted by monkeyracing View Post
No. From the TCS Racing rules page:
"Tamiya internal gears only. Aftermarket idler and spur gears are not legal."
Thought So
Thanks Jim for confirming
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 03-01-2014, 01:26 PM   #20567
Boons's Avatar
You're probably after the guide and o-ring set, but here's a complete breakdown. Each part can be looked on Google, so you can be sure about what you're ordering.
54000 M-Chassis Aluminum Damper Set (4 pcs.)
53334 Low Friction Damper V Parts (2 pcs.)
9808169 Damper Cylinder (2 pcs.)
9808170 Piston Rod (2 pcs.)
9808171 Coil Spring (Medium, White, 2 pcs.)
9808172 Coil Spring (Hard, White, 2 pcs.)
53333 Touring Car Tuned Spring (Short) (2 pcs.)
53572 TRF Damper Piston (2-Hole, 4 pcs.)
53573 TRF Damper Piston (3-Hole, 4 pcs.)
53574 TRF Damper Rod Guide & O-ring Set
53576 TRF Damper Oil Seal
53577 TRF Damper Urethane Bushing
9804153 3x2mm Spacer
9805611 5x9mm Ball Connector
9804205 5mm Ball Connector
9805240 3mm O-ring
9808077 2mm Shaft Guide
Thanks mate, that's very Kind of you
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 03-01-2014, 01:38 PM   #20568
Boons's Avatar
Guys I've got my M05 pretty much where I want it now, I run silvercan/NIMH on carpet and it's running with the M03's which dominate at my club. What I could use is a touch more turn in as it's running wide on 180 degree single drainpipe turns. If you need set up I'll elaborate but in terms of an RC car in general, what would you be looking to do? Or is that too general??
Old 03-01-2014, 02:00 PM   #20569
sosidge's Avatar
If you aren't already running the stand-up front shock tower, then you probably should. Lighter front damping may also help.
But my first reaction was "slow down"...
Old 03-01-2014, 02:13 PM   #20570
Boons's Avatar
I'm pretty tight most corners and a decent FTQ, but it did seem a touch slidey on 'that' 180 last night. I tried rolling off early, staying out wide etc. I've got the wide tower and in the outer hole too, 450cst on blue short springs up front, -1 arms. Maybe I just need to practise on that one!
Old 03-01-2014, 06:32 PM   #20571
First, what's a FTQ?????
Funny thing about Minis, they all seem to go faster with a softer spring up front and a harder spring in back. This is just my opinion, but the short Mini springs are all too stiff----that includes the white ones that come with the TRF shocks. That blue spring you have up front should make your car understeer like crazy.
Couple of other things you could try. Start adjusting your toe out. Sounds like you're running too much. Lower your front ride height or raise the back. These two adjustments will make your car "steer" better-----but unfortunately, not always.
Nah, if your car won't turn, driving practice isn't going to make it turn any better. I'm just guessing here, but it sounds like you base set up is off a bit. It sounds like it's too stiff, too much toe out and too wide. Ride height is probably level. Diff may also be a bit stiff. It sounds as if your car is easy to drive, but your results come from driving talent. Your car's not helping you.
Granpa is offline   Reply With Quote
Old 03-01-2014, 09:32 PM   #20572
fresnojay's Avatar
Wanted to give another more serious heads up to anyone that has recently replaced their mini chassis recently although it may only be limited to recent runs of m05 chassis. I broke a second new chassis today in practice. I warned this before when my last new chassis broke in a mundain fender bender. Today the chassis broke in a brush with a dot. I am not sure what's going on but this last brush has ended my hopes of attending tcs as a mini class participant. I may still attend but not in this class. G/L to all that are going and be careful with your minis.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 03-01-2014, 11:19 PM   #20573
monkeyracing's Avatar
Well, it's minus 30 or 40 or some damned thing outside and i recently got new lighting for my workbench. (Ikea, Tertial task lamps, 600 lumen Ledare bulbs. Less than $40 invested!) Anyway, bored silly, thought I'd take some pretty shots of my weapon of choice. I really wish I was better at clean wiring.
Jay, I know the M05 is brittle as hell, but why not just slap a new chassis together?
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 03-02-2014, 08:03 AM   #20574
ruebiracer's Avatar
[QUOTE=monkeyracing;13056154]Well, it's minus 30 or 40 or some damned thing outside and i recently got new lighting for my workbench. (Ikea, Tertial task lamps, 600 lumen Ledare bulbs. Less than $40 invested!) Anyway, bored silly, thought I'd take some pretty shots of my weapon of choice. I really wish I was better at clean wiring.
Hey Monkey,
your M04 looks nice and clean, no worries!
What motor/esc combo is that?
Looks really small for brushless, nice!
And what about your setup and tire choice on the M04?
Itīs been a long time, since I drove my M04, by the way.
Itīs resting in the shelf at the moment...
Br,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 03-02-2014, 08:34 AM   #20575
Boons's Avatar
[QUOTE=Granpa;13055518]First, what's a FTQ?????
Hi Granpa,
Thank you for your input, I'll have a play with a few things then.
FTQ - Fastest Time Qualifying
Old 03-02-2014, 09:57 AM   #20576
Hey Matthias, set up is pretty simple:
Fluoro blue springs, 30wt (I think) S Grips all around
Front shocks stood up a little
Front rides a little higher than rear
Stock diff, completely open
Bit of toe out front, ridiculous amount of camber set by stock pieces
1.5 degrees toe in rear, camber is adjusted closer to zero than stock
Rear sway bar fitted, but I'm not sure if it does anything yet
It's heavily dependent on having good back tires. If the rears are weak or you get off line, forget it. That said, it's also surprisingly easy on tires, especially compared to an 05.
The motor/ESC is our spec Orca Q Spark 2200kv. Think Hobbywing 13t, but 1/3 slower.
Stab it and steer.
Old 03-02-2014, 12:16 PM   #20577
KA2AEV's Avatar
Jim That setup looks really neat and clean to me except for that
black stain on your right front fender.
Dude keep it off the walls!
Oh and By The Way
Old 03-02-2014, 03:57 PM   #20578
That stuff just doesn't come out of the Shoe Goo once it's in there. Tape and shoe-goo on are both inside and out, because I'm crashy.
Stab it and steer.
Old 03-02-2014, 06:29 PM   #20579
Carl Giordano's Avatar
Trader Rating: 20 (100%+)
Hey guys, getting ready for this Sundays TCS race at Horsham and decided to pick up a new set of TCS spec mini tires. HOWEVER, maybe it's me but the new tires feel softer that the 5 older / used sets I own. Even the color seems lighter. Feels like the tire " yawn" is much easier than my older tires. Maybe this explains why some guys are glueing the entire side walls and I haven't in the past.
Anyone experiencing / noticed the new batch of tires are softer. PS: I'm referring to the gray rim premounted s-grip
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is online now   Reply With Quote
Old 03-02-2014, 07:06 PM   #20580
The new generation S-Grip premounts are a lot softer than the old tires. For most it's instant traction roll if you don't cyano the sidewalls of the fronts. Some will cyano the rears also, but some don't.
If you feel the sidewalls, they fold right over with very little pressure. They also wear out much quicker than the old ones. Once properly treated with glue, they'll give you some good lap times.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
