Old 02-25-2014, 09:38 PM   #20551
Originally Posted by ncpantherfan View Post
23 is for the Johnson silver can as per tcs rules, that is about average. Is there a much cheaper source I didn't know about?
How do you know what parts to swap out on bl motors? Is it just buying a bunch of parts and trial and error?
Well it looks like I didn't succeed in making it understandable for you, so let me go through how you might do this. Since a Speed Passion is one of the motors on your list, let's do that one.
First buy the right motor. SP has the V3 1 cell motor which has the small or high rpm rotor, so you won't have to buy an extra rotor. Second, you have to figure out how much you can safely advance the timing. For this particular motor you will have to buy an optional sensor unit. Whether you use a +20, 30, or 40 unit is trial and error. The motor has 10 degrees of adjustment on the end bell so with a +40 sensor unit, you can get a max of 50 degrees of timing, which I don't suggest. Also, you have to take the motor out to adjust the timing.
You sort of have to go through an analysis on each motor, cause each seems to have strong and weak points. The Thunder Power has a sensor wire that plugs in differently from the other motors and for me is a little harder to work on. The Novak goes nowhere unless you advance past the label. The Trinity has more tuning rotors than I have fingers or $$$$ to buy them.
Of the motors on your list, I'd buy either the Speed Passion or the Killshot. Just do your research, cause I can't tell you which is better for your track.
Granpa is offline   Reply With Quote
Old 02-26-2014, 01:51 AM   #20552
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Is the Silver Can for TCS 53689 ?
marcos graveyar is offline   Reply With Quote
Old 02-26-2014, 11:07 AM   #20553
That was the TCS motor in previous years. However, for 2014, the motor is the 21.5 B/L motor.
Old 02-26-2014, 11:17 AM   #20554
rramjet's Avatar
Location: Everett WA in the Summer Mesa AZ in the Winter
I just ran across a "High Speed Gear Set" for the M cars. Think it's been around for a while but I had never seen one.
I know it would not be TCS legal but has anyone ever tried one?
It appears to change the tranny ratio so you get a lower FDR with the stock 37/20 Spur and pinion.
http://www.tqrcracing.com/shop/produ....asp?p_id=1591
Associated TC7.1
Tamiya M05 Ver II Pro
TC4 Late Model
CW GBX2
rramjet is offline   Reply With Quote
Old 02-26-2014, 11:31 AM   #20555
monkeyracing's Avatar
It's only been a few years since I bought one locally, but it was $14.99. Even at that, it was on the very edge of being reasonable. It's a 50+ year old design, manufactured in the millions each year, that wholesales for under a buck.
They're not very good and will wear quickly, especially with a BL motor. I believe this has something to do with them not being properly round and because they're made of soft cheese.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-26-2014, 11:59 AM   #20556
Default Tamiya Track (Aliso Viejo) Saturday
Hello Racers,
Per the weather forecast it will rain this upcoming saturday. Where are all the mini drivers going? TQ track?
Danny
fx35rc is offline   Reply With Quote
Old 02-26-2014, 12:13 PM   #20557
sosidge's Avatar
We use them locally (those Ride ones are identical to the 3Racing ones). The material is very poor so they don't last if you are prone to crashing. The counter gear is particularly bad so use the standard Tamiya one instead.
Locally we race with the fast gears and HPI Saturn 20 motors. The cars are quite quick. This is from last weekend, my car starts 3rd on the grid running 33/20 gearing, others are running higher ratios so have a bit more top end than me - https://www.youtube.com/watch?v=OmQi8nPtqvk
Old 02-26-2014, 03:27 PM   #20558
Schs2013's Avatar
Thumbs up
Originally Posted by Granpa View Post
Not really. This is absolutely the most common reason for stripped gears. The spur gear is almost always the culprit, as Sosidge said, it's the weakest link.
Just imagine this. Hold your car up, accelerate to full throttle, then cause your front wheels to come to an sudden stop while under power. Try this a few times and you'll strip a gear. This is exactly the loads your drive train is under when you "bang" the boards.
The reason the Mini veterans don't go thru gears very often is that for one they don't bang the boards that often. The other is that when they make a mistake big enough to take them into a "board", they do it off power.
I learn(you guys teach) something new everyday. Thanks guys
VBC Lightning 10LM, Xray T4 Touring/USGT, M05v2
Losi 8ight 3.0 E Truggy, Losi TEN MT
Traxxas Summit & RC4WD TF2 SWB
-Marc Gill
Schs2013 is offline   Reply With Quote
Old 02-26-2014, 06:24 PM   #20559
rramjet's Avatar
Interesting. Where do you find the lower tooth spur gears?
Never mind I see the spur gears are in the kit. Thought they were all internal gears.
Associated TC7.1
TC4 Late Model
CW GBX2
Old 02-27-2014, 04:13 AM   #20560
Banzia do them for just over $8.
http://banzaihobby.com/index.php?mai...pto=&x=32&y=21
Old 02-27-2014, 11:05 AM   #20561
Originally Posted by fx35rc View Post
Hello Racers,
Danny
It's time to do some complete overhauls, so will take the day off. Some of the others may be going to TQ. They often do on rainouts.
Old 02-27-2014, 11:09 AM   #20562
Thanks Bob. This is the last saturday I can run RC cars. I have to take advantage of it. My wife is coming back next week.
Old 02-28-2014, 03:58 PM   #20563
Boons's Avatar
Hi guys,
I'm hopefull I can buy the 'guts' for the TRF 54000 shock. Anyone got any part numbers for me please.
Thank you
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 02-28-2014, 04:52 PM   #20564
KA2AEV's Avatar
Which leads me back to an earlier question that I didn't see an answer for
Are those speed gears legal for TCS?
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 02-28-2014, 05:00 PM   #20565
You're probably after the guide and o-ring set, but here's a complete breakdown. Each part can be looked on Google, so you can be sure about what you're ordering.
54000 M-Chassis Aluminum Damper Set (4 pcs.)
53334 Low Friction Damper V Parts (2 pcs.)
9808169 Damper Cylinder (2 pcs.)
9808170 Piston Rod (2 pcs.)
9808171 Coil Spring (Medium, White, 2 pcs.)
9808172 Coil Spring (Hard, White, 2 pcs.)
53333 Touring Car Tuned Spring (Short) (2 pcs.)
53572 TRF Damper Piston (2-Hole, 4 pcs.)
53573 TRF Damper Piston (3-Hole, 4 pcs.)
53574 TRF Damper Rod Guide & O-ring Set
53576 TRF Damper Oil Seal
53577 TRF Damper Urethane Bushing
9804153 3x2mm Spacer
9805611 5x9mm Ball Connector
9804205 5mm Ball Connector
9805240 3mm O-ring
9808077 2mm Shaft Guide
No. From the TCS Racing rules page:
"Tamiya internal gears only. Aftermarket idler and spur gears are not legal."
Stab it and steer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
