Like Tree2Likes
Old 10-02-2006, 04:51 PM   #2041
Default servo saver
hello
i want to avoid the play on the steering to maximum posible , so i am lookign for a servo saver which can be used on the mini cooper .
tamiya high torque servo saver it is shorter so sterring response will be affected.... anyone did this before?
DrKucho is offline   Reply With Quote
Old 10-02-2006, 04:57 PM   #2042
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by DrKucho
hello
I want to avoid the play on the steering to maximum posible , so i am lookign for a servo saver which can be used on the mini cooper .
I use the Hi torque tamiya unit. I don't usually feel the need for all the steering. one issue that the M03 has is the servo is not firmly mounted, so I put some shoe goo to hold the servo firmly remember the chassis seperates so be carfull where you put it.
The M03M suspension has ackerman holes to gain what you think you are loosing.
tamiyarcracer is offline   Reply With Quote
Old 10-02-2006, 05:06 PM   #2043
thanks tamiyarcracer
well i am not afraid to loose steering , it might be even good to loose a little bit of steering on high speeds (theese minis steers a lot) im just not sure of what are going to be the changes using a shorter servo saver , because of that i would like to look for servo saver that has the same length
but if you are using the tamiya high torque SS and not feeling so much the diference , maybe i use it too...
i just wonder why tamiya did a special servo horn for the mini if they had the standard already done , it must be for some reason
Old 10-02-2006, 05:07 PM   #2044
what is the shoe goo by the way ? everybody talking about it but ...
do you have a link about it?
Old 10-02-2006, 05:08 PM   #2045
Pretty easy to understand, that is the same tree that is used on the TL01. and why add more cost to add another tree.
But racers edge makes a servo saver that is very very similar in length to the original unit if you are concerned.
As for shoe goo. it is glue that is like a silcone sealer let me see if I can find something. You can find it in a hardware section most anywere.
These are the 2 products, I use the 2nd product cause my LHS carries it.
http://www.eclecticproducts.com/shoegoo.htm
http://www.zapglue.com/New%20Pages/Zap%20Goo.html
Old 10-02-2006, 06:05 PM   #2046
Mad Mackem's Avatar
Default TCS Mini
Just thought I would post a couple of pics of my Oz TCS mini. The paint job was better than the driving performance!
Mad Mackem is offline   Reply With Quote
Old 10-02-2006, 06:10 PM   #2047
thanks tamiyarcracer!
Old 10-02-2006, 07:12 PM   #2048
Originally Posted by Edgarski
no..just showing the shafted mini (shortened TL01)
Any tip of how doin it shortened TL01.Any website oor thread of it.
X1 CRT
KO HELIOS
9351,9451
STS.28
JP3
JConcepts
faiunie is offline   Reply With Quote
Old 10-02-2006, 08:00 PM   #2049
Customworksking's Avatar
Trader Rating: 70 (100%+)
Default car
looks nice!!! after I did my 2,
looking at yours next time i will do the FRt/rear light's looks good
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is online now   Reply With Quote
Old 10-02-2006, 10:20 PM   #2050
BEAST's Avatar
Thumbs up
Mad Mackem Just thought I would post a couple of pics of my Oz TCS mini. The paint job was better than the driving performance!
yeah that was a nice paint job
really liked the front and rear lights
BEAST is offline   Reply With Quote
Old 10-03-2006, 03:12 AM   #2051
tony gray's Avatar
Default More Updates
New update on rc-mini.net today.
The new TECH RACING M03 Mini 4WD conversion. Lots of pics and info on this amazing car available now. And we hope to have the completed car up soon (when I get time to build it!)
Online now...
tony gray is offline   Reply With Quote
Old 10-03-2006, 03:25 AM   #2052
nice update on rc-mini.net!
shame that conversion is belted, i preffer shaft drive ones in general ,i have seen you tested the ABC hobby shaft mini, how is it?
Old 10-03-2006, 04:18 AM   #2053
tony gray's Avatar
The ABC Genetic is a fine little car Doc. And interestingly enough, ABC are doing a belt version of it too. Will be out soon.
Its only problem is that its a little fragile by comparison with an M03 so you need to stay off them walls! But they sure have got a nice turn of speed, and nice and quiet too.
Old 10-03-2006, 04:29 AM   #2054
out of the walls? definitly is not for me LOL !
now that you mention it , why tamiya minis are so noisy? is it possibe to make them more silents? they sound like a pig being killed by knife on throat !!!
Old 10-03-2006, 04:38 AM   #2055
tony gray's Avatar
Why are they noisy? Well it's a combination of things. Gear pitch (internal) is pretty coarse and that's the main source. Plus the mesh is designed to run as 'loose' as possible and that makes for more noise.
And...there's a lot of empty space inside the chassis so what noise there is, the chassis amplifies and makes sound worse.
In the end, it's just something that you learn to live with.
Plus its good because if I hear a really quiet car, then I know its probably illegal....
You can get aftermarket gears but they dont really make any difference.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
mcmattila
