Old 02-20-2014, 06:34 PM   #20521
Trader Rating: 44 (100%+)
What foam inserts are you guys running with s grips on carpet front and rear? Soft or hard? I would say medium grip carpet
Justin33 is offline   Reply With Quote
Old 02-20-2014, 07:13 PM   #20522
Carl Giordano's Avatar
Trader Rating: 18 (100%+)
Originally Posted by fresnojay View Post
Ok so finally got a decent shot of my setup sheet so I can post it. This is how my mini is set currently. Changes made were switch from 22.5wt shock oil to 40wt, and front springs from black/red to black/yellow.
Jason
Jason, any chance you can post a blank setup sheet or email me an excel or word version. Looks great
Carl993@mac.com
Mugen Racing / OS Engines / KO Propo / Byron Fuels / TOP Racing / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho RB6
Carl Giordano is offline   Reply With Quote
Old 02-20-2014, 07:36 PM   #20523
monkeyracing's Avatar
Go with hard foams, Justin. With the newer floppy tires, you'll need all the support you can get. Maybe have a look at HPRT's setup too. He's dominating WCICS mini this year. https://www.dropbox.com/s/nyt1rl64hq...02012-2013.pdf
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-20-2014, 09:59 PM   #20524
I have 1 set with hards and 1 with softs thats all i got at the moment. How would you run them?
Old 02-20-2014, 10:17 PM   #20525
I'd put the tires with the softer inserts on the rear.
Whoo! Guess what kind of sway bars I just got!
Stab it and steer.
Old 02-21-2014, 11:01 AM   #20526
Default Aliso Viejo Track hours
Hello,
On Tamiya's website it opens at 10 am. But last week I got there at 9am and it was open. Anyone know how early it will open this saturday. I have a long drive and the earlier the better for me, to avoid traffic
fx35rc is offline   Reply With Quote
Old 02-21-2014, 03:40 PM   #20527
Wade....'s Avatar
That looks like a clothes hanger sway bar.
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 02-21-2014, 09:28 PM   #20528
Schs2013's Avatar
Is it normally easy to warp(enough for the internal gearing not to line up anymore) a M05 chassis? after crashing?
or am i just unlucky
VBC Lightning 10LM, Xray T4 Touring/USGT, M05v2
Losi 8ight 3.0 E Truggy, Losi TEN MT
Traxxas Summit & RC4WD TF2 SWB
-Marc Gill
Schs2013 is offline   Reply With Quote
Old 02-21-2014, 11:05 PM   #20529
Yosh70's Avatar
Trader Rating: 17 (100%+)
I cant say for sure but I cant see a crash warping anything....damage, breakage, cracking, yes. But warping doesn't make sense.
Now put the M05 in an oven, different story.
TLR 8T 1.5, AE SC10, TLR 22SCT
Yosh70 is offline   Reply With Quote
Old 02-21-2014, 11:13 PM   #20530
Yosh70's Avatar
So my little guy wanted a new body for the Mini and originally I ordered the HPI BMW which was pretty rare and no one in our club has one.....until the last club race when one of the members showed up with one with a bright white paint job. Shysta....
Good thing it got backordered so I cancelled it and got my LHS to get the Datsun 510 (225mm, M05-M)....trimmed it last nite, got the body post holes done (have to turn the rear posts around) and gonna give it to a guy who's pretty good with painting bodies. This thing came with a chrome tree including bumpers, mirrors, wipers and a tailpipe.
Should be pretty sweet.
Old 02-22-2014, 12:44 AM   #20531
Schs2013's Avatar
I been back tracking in my mind since i had that one crash which stripped my spur gear and unless i hit the boards harder than i thought i don't know. Oh well one for the history records now.
-Marc Gill
Old 02-22-2014, 02:41 AM   #20532
sosidge's Avatar
The chassis parts will deform in a crash (and return to normal) without being permanently damaged, that's how some damage occurs. Stripping a spur in a crash is more likely due to the combination of the wheels being stopped suddenly and the motor still being powered, the weakest link in the drivetrain will go.
Old 02-22-2014, 01:21 PM   #20533
TamiyaM05Mini's Avatar
Can I have some recommendations of what chassis length to run on my M05. I have set the car up after 4 years of testing, and got a good set up, with the short wheel base. But I would love to run a Fiat 500 M03M body, or maybe a Super 1600 Swift. I would like to know the pros and cons of each wheel base. Also if I need to change any other things, to really make the new wheel base excel.
Thanks a tonne,
Sam
Tamiya M05 x2 and Schumacher Supastox x2
TamiyaM05Mini is offline   Reply With Quote
Old 02-22-2014, 04:48 PM   #20534
howardcano's Avatar
Trader Rating: 35 (100%+)
Thanks a tonne,
Sam
Moving the rear wheels back (which is how the the wheelbase is lengthened on the M05), with all else being equal, gives better straight-line acceleration, since front-to-rear weight transfer is reduced and more weight is placed on the front tires. It also promotes understeer, so you may need change springs, sway bars, or tires to compensate.
It will also make the car less twitchy/more stable.
I'm running the JCW coupe on a long-wheelbase M05.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
Last edited by howardcano; 02-23-2014 at 04:42 AM. Reason: Changed "gives the better" to "gives better".
howardcano is offline   Reply With Quote
Old 02-22-2014, 08:29 PM   #20535
KA2AEV's Avatar
Unless when you hit the wall, did you happen to get wedged against it and try to
Power out of it in other words the car was stuck and you were burning rubber, in that case
Yes you could have stripped the gears,
Like sosidge said the weakest link will go
So ...
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
