Like Tree81Likes
Old 02-16-2014, 06:48 AM   #20461
jasons56's Avatar
Originally Posted by CraigMBA View Post
Mini on s grips will be fine. In sedan, it's going to be horrible if they spray.
On the M03, yes. The M05 seems to be immune to getting on the outside of the front tire.
We had to resort to CA on the outer tread on our M05 yesterday. The new carpet at the Plex has definitely brought the traction to another level.
I think if we had more time to experiment, we could get away from that on the 5. MAYBE.
The driver wants much more steering today, so we will see about that!
http://www.youtube.com/user/ZenRacing
jasons56 is offline   Reply With Quote
Old 02-16-2014, 06:59 AM   #20462
Golddust's Avatar
How many entries are there that its a two day TCS???
Lead Driver of Team Golddust Racing
aka: The Tottenville Terror
Golddust is offline   Reply With Quote
Old 02-16-2014, 07:01 AM   #20463
howardcano's Avatar
Trader Rating: 35 (100%+)
My M05 absolutely requires it on the new carpet.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 02-16-2014, 07:02 AM   #20464
howardcano's Avatar
Kids are just running with the adults. They started in their own heat. Most of them are in the bottom heat after the re-sort.
Augie is sitting overall in the 7th spot. A main bubble!
GO AUGIE GO!!!
Howard Cano
Old 02-16-2014, 11:06 AM   #20465
Blue Sky's Avatar
Send a message via Yahoo to Blue Sky
What area some of the things, if at all, are you guys doing to have the M05 balanced left and right? I'm finding my motor side is quite a bit heavier. Thanks.
Blue Sky is offline   Reply With Quote
Old 02-16-2014, 11:37 AM   #20466
sosidge's Avatar
I have my car with the ESC on the opposite side to the motor, that helps a lot with the balance.
If you are wanting to get more weight specifically over the right-front tyre, Tamiya now make a monster of a motor heatsink/counterweight (#54538) or you can put sticky weights on the flat area between the motor screws.
Old 02-16-2014, 04:39 PM   #20467
jasons56's Avatar
We had about 125 or so I believe.
Old 02-16-2014, 05:51 PM   #20468
monkeyracing's Avatar
You could stick the ESC opposite the motor...
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-16-2014, 08:50 PM   #20469
Schs2013's Avatar
Hi guys i just installed ball bearing into my m05 and add a new spur but something in binding i hear a sound of grinding.
Any advice?
VBC Lightning 10LM, Tamiya M05v2
Losi TEN MT, Traxxas 1/10 Summit LT, Vaterra K-10
-Marc Gill
Schs2013 is offline   Reply With Quote
Old 02-16-2014, 10:37 PM   #20470
Take it apart, look around, and find the source. Remove it, put it back together and test. Repeat until grinding gone.
Waalah.
jjjheimer is offline   Reply With Quote
Old 02-16-2014, 10:40 PM   #20471
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Take out one thing at a time till you find it. I'd start with the tires and work back.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 02-16-2014, 11:05 PM   #20472
iti20090's Avatar
Default M05 ball diff in M03
Apologies for thick in advance. The M05 (1500 bearing) and M03 (1150 bearing) ball diffs use substantially different bearing sizes where the cup shafts go through the chassis wall.
A number of the adverts show the M05 ball diff as for M05/M03/Mo6:
http://www.tqrcracing.com/shop/produ....asp?p_id=1846
How does one then fit the M05 cup shafts in to the M03 chassis? Does it imply removing the M05 cup shaft system altogether and replacing with the TA03 touring system or is there an intermediate bearing with OD small enough to fit the small M03 opening but also big enough to carry the M05 cup shafts?
The reason for also this is because I would like to fit the M05 oil filled diff in to the M03 but one assumes the same conundrum still applies?
Thanks and regards
Dave
iti20090 is offline   Reply With Quote
Old 02-16-2014, 11:42 PM   #20473
Thanks and regards
Dave
Go back to page 1360 and read ruebiracer's posts. This may answer your question, if I understood it properly. Matthias(?) is a pretty sharp guy and probably answer your questions.
Hope this helps.
Granpa is offline   Reply With Quote
Old 02-17-2014, 03:11 AM   #20474
iti20090's Avatar
Hope this helps.
Thanks Granpa, you right, it goes right to the heart of what I am after.
Cheers
Dave
Old 02-17-2014, 06:32 AM   #20475
Any advice?
You probably stripped a gear. You'll have to take the car apart and inspect the gears. That happened to a racer yesterday.
Marc D is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
