Like Tree137Likes
Old 01-28-2014, 07:57 PM   #20281
fresnojay's Avatar
Anyone plan on being down at the Tamiya track this Saturday? My wife wants to take a trip to LA and I told her I wanted to take the mini to the track and she agreed.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 01-28-2014, 09:15 PM   #20282
It's a rare weekend with no Minis in attendance. There are several of us that run every week. Check the weather cause there is a chance of rain Saturday.
Granpa is offline   Reply With Quote
Old 01-28-2014, 09:36 PM   #20283
fresnojay's Avatar
Awesome good to know. Plan on test running the newly brushless and rebuilt mini.
Jason
Old 01-29-2014, 06:23 AM   #20284
Quick question guys for those that run the standard gear diff, what did you use to seal the grease/oil in to prevent leaking?
Green_Machine is offline   Reply With Quote
Old 01-29-2014, 08:55 AM   #20285
You really can't effectively seal the Tamiya gear diff if you're packing it with oil or grease. Some will use some sort of "putty" instead of oil or grease. IMO the best way to "tighten" the diff action is to use extra shims. If you must use a gear diff there are several on the market, that I'm told do not leak.
The easiest solution to the diff problems is the TA03 ball diff.
Old 01-29-2014, 09:02 AM   #20286
samshirley00's Avatar
not much you can do really, unless you are running incredibly thick oil, like 1m, its gonna leak, and if it doesnt leak, its gonna spread out.
hopefully mine should be a winner on sunday, for my local championship, 7 points behind 1st and i think every time apart from 2 i TQ'd
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 01-29-2014, 09:15 AM   #20287
How does the TA03 ball diff compare to a shimmed gear diff? Can it be tightened so they feel about the same?
jha07 is offline   Reply With Quote
Old 01-29-2014, 12:48 PM   #20288
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
I have another question.
When I'm not using my Mini, I'd like to mount the body lower, but it seems it hits the front shock tower. Is there a way to mount it any lower?
SerpentCT4S is offline   Reply With Quote
Old 01-29-2014, 02:28 PM   #20289
monkeyracing's Avatar
I like the TA03 diff, but found I could never get it tight enough reliably and it required a little more attention that my shimmed stock diff. (3 shims per side, a tiny bad of anti-wear, tighten case screws carefully and evenly, adjust screws to modify tension. A tiny hole drilled on the outside of the chassis allows a screwdriver to access the case screws while the cars is assembled.)
Other have had better luck with the TA03 diff than I have, so don't take my words as gospel.
I set my gear diff up to feel about the same as an oil filled diff with 500K silicone. Works pretty well, is low maintenance and cheap. Haven't really touched it in quite a while. It just works for me.
I do have an oil filled diff in my 05. It's pretty good, but I still somehow prefer the shimmed stock unit. Maybe it's because I'm nervous about it letting go and filling my gearbox with silicone goo. Never seen it happen, but the doubt is always there.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-29-2014, 02:30 PM   #20290
Hey, sorry for back to back posts, but I've got a question: How do you keep the bottom caps on your shocks from backing off? I sem to be forever retightening the bottom caps on mine. I'm using both the older bronze coloured dampers as well as the current blue. (they're the same thing, really)
Stab it and steer.
Old 01-29-2014, 02:32 PM   #20291
As someone who has actually filled their gearbox with goo (Automotive bearing lube) thinking that it was the proper care procedures, it sounds harder than it is to clean. Crack the case, and blast the sucker with "Goop" and "Oops" cleaners (not at the same time) and it'll clean up like new. After I cleaned that goop out of the case, I stopped melting battery connectors, and stopped having torque and coasting issues.
pizzaboy192 is offline   Reply With Quote
Old 01-29-2014, 02:32 PM   #20292
a bit of threadlock will surely stop that from happening
Old 01-29-2014, 03:48 PM   #20293
Jim, the best way is to clean both the threads on the shock body and the cap with a degreaser. I suspect that when assembling your shocks, they weren't clean. I usually just wipe mine and have rarely had a problem, but using a degreaser will eliminate the problem.
Threadlock is NEVER, EVER a good idea on threads this fine. You'll have a difficult time removing the cap and may lose a set of shocks.
Also, you can build a TA03 ball diff very tight. There are a couple of ways to do this which I've posted more than once. Also, Tamiya makes some nylon(?) diff balls that will give you something that resembles a spool. Can't remember the part number, but I did get a set from TQ. Will build a diff with those if I ever race on carpet.
Old 01-29-2014, 05:51 PM   #20294
Hey guys was putting in a set of 3racing C hubs tonight and when putting together front axle the 3x14 standard issue step screws dont fit!! Bit baffled as never heard of these needing diff screws from original. Any ideas??
Old 01-29-2014, 08:10 PM   #20295
Timbulb's Avatar
Can anyone supply some links to M-Chassis rally cars? All the old threads' links are no good it seems. I wanna put together an m03RA.
Timbulb is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
