Like Tree137Likes
Old 01-27-2014, 12:20 PM   #20266
Schs2013's Avatar
@MonkeyRacig I think its only 3Racing that has the one way diff I could be wrong.
http://www.tqrcracing.com/shop/produ....asp?p_id=1772
VBC Lightning 10LM, WCICS spec M05v2, TA07 USGT 21.5
-Marc Gill
Schs2013 is offline   Reply With Quote
Old 01-27-2014, 12:36 PM   #20267
monkeyracing's Avatar
That's a spool. Loads of those around. I've got DIY, Yeah Racing and Tech Racing versions.
The answer, I think, is Tamiya. They made a one way for one of their awd cars that fits the stock mini gear diff housing. I've got one and it's always an adventure using it. Locks up on throttle, unlocks off throttle, zero braking! WHOO!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-27-2014, 01:47 PM   #20268
howardcano's Avatar
Trader Rating: 35 (100%+)
That sounds like a great way to clear away the traffic in front of you:
"Pink car, I'm right behind you, and I'm running a ONE-WAY!"
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-27-2014, 02:18 PM   #20269
Schs2013's Avatar
oh I did say i could be wrong. mybad
-Marc Gill
Old 01-27-2014, 02:28 PM   #20270
I think it was for the TA03. The minis would handle very well with it, but were "outlawed" where we were racing at the time. Getting them lined up at the start of the race and getting them stopped at the end was a bit of a challenge.
Granpa is offline   Reply With Quote
Old 01-27-2014, 02:30 PM   #20271
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
I have a M03.
Does anyone make adjustable camber links for the M03?
SerpentCT4S is offline   Reply With Quote
Old 01-27-2014, 03:44 PM   #20272
KA2AEV's Avatar
Okay getting off topic a bit
Could anyone explain to me what to do with a brushless motor that runs faster in reverse than it does
Going forward? Its in a m03 btw
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 01-27-2014, 04:12 PM   #20273
Originally Posted by SerpentCT4S View Post
I have a M03.
3Racing did. There are still some to be found. Their M05 set will also work.
Stab it and steer.
Old 01-27-2014, 05:13 PM   #20274
howardcano's Avatar
I'll assume that you have already checked the throttle EPA for both directions, and have calibrated the ESC. If so:
Advance the timing on the motor.
If you are running a Novak ESC, then you will get the same RPM in forward or reverse when the true timing on the motor is at 30 degrees advanced (for normal rotation). That is the "N" or "30" mark on Novak motors.
Howard Cano
Old 01-28-2014, 06:42 AM   #20275
samshirley00's Avatar
highly recommend not to use the 3 racing one, get some tamiya 5mm low friction all ends - part 53601, some long grub screws and make your own, the 3racing ones are prone to splitting, so they will pop off fairly easily, unlike those tamiya ones that i find pretty damm hard to get off.
gonna try a spool in my mini for the first time ever, my spec r gear diff internals stripped fr the 3rd time yesterday, annoying, especially when the car is handling so well. Got a 3racing gear diff on its way, with some ride putty to test out too, i usually run 100k in the car
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 01-28-2014, 12:12 PM   #20276
How weak / strong is the part no #54195 from Tamiya RC Aluminum TB Steering Rod - M05 Turnbuckle.
Vrooom is offline   Reply With Quote
Old 01-28-2014, 12:18 PM   #20277
whitrzac's Avatar
Trader Rating: 94 (100%+)
I've never seen a broken one...
whitrzac is offline   Reply With Quote
Old 01-28-2014, 12:19 PM   #20278
but... many bent ones ??
Old 01-28-2014, 02:25 PM   #20279
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to AudioStylz
I never seen a bent one either. My only complaint about the one I had was that it seemed to be a tad too short by 3mm. Could have been using the wrong eyelets though.
I was geared up to run my mini today for the 1st time since I've gotten it. Track did not open up due to extreme cold weather, they say they will be open tomorrow. Looking forward to going tomorrow!
Mike Zadler
Associated TC3 VTA (RIP 4/23/17)
AudioStylz is offline   Reply With Quote
Old 01-28-2014, 05:14 PM   #20280
KA2AEV's Avatar
Thanks Howard
something told me to go back and double check the ESC, and found that it lost its programming. Its the Edge by Novak. I guess that when I was
installing a new servo saver on the car and had everything apart for 2 days
it must have lost something someplace while everything was disconnected. Anyway All is okay now
Thanks for the heads up!!!
Oh and By The Way
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
