Like Tree61Likes
Old 12-24-2013, 09:18 PM   #20071
BoneCrusher's Avatar
Originally Posted by Justin33 View Post
Thanks for the setup sheet!!! What adjustable front camber arms are you using or how did you set it up to be able to adjust it??? Thanks
Thank Scott "the professor" West from Karz in Calgary. It's his setup. I believe 3 racing sells an adjustable camber link set but I can't seem to find it online. Maybe someone else can chime in.
Where is your home track Justin?
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 12-24-2013, 09:22 PM   #20072
carcar.ca
Last edited by BoneCrusher; 12-24-2013 at 09:27 PM. Reason: Hate posting with my phone
Old 12-24-2013, 11:23 PM   #20073
Trader Rating: 44 (100%+)
Ivan
Penticton is my home track. anthony has a setup very similar to what you posted thats what i'm trying to duplicate at the moment
Justin33 is offline   Reply With Quote
Old 12-25-2013, 07:43 PM   #20074
Small world. Anthony most likely copied that from Scott. Not sure if you raced at your Wcics race but I think Scott gave another little seminar about Mini setup like he did the year before that hence "Professor".
Around your area, your target will be Anthony and when Brent comes up from Kamloops he's someone to chase too.
If you can make it to the Calgary Wcics race in March, you're probably looking at 30-40 mini deep field.
Ivan
carcar.ca
Old 12-25-2013, 09:46 PM   #20075
Yeah unfortunetly i couldn't make the wcics race in penticton so i missed the professor but i'm on the same lap as anthony but to keep up with him i need a bit more corner speed and steering. I'll keep trying but i think the blue springs will be the ticket i'm really close so i guess just keep trying track time cant hurt
Old 12-26-2013, 10:17 AM   #20076
Boons's Avatar
Hi all,
I would like a black can motor but I run the 105 esc. The specs of that suggest a 25t motor limit but the black is 23t I think.
I guess I can't run that combo then?
Cheers
Ryan
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 12-28-2013, 04:57 PM   #20077
Schs2013's Avatar
What are some Must have upgrades for a M05?
I am starting at oil-filled shocks/W tuned Spring sets.
after reading the forum i can tell there are other upgrades then what i mentioned.
VBC Lightning 10LM, Tamiya M05v2
Losi TEN MT, Traxxas 1/10 Summit LT, Vaterra K-10
-Marc Gill
Schs2013 is offline   Reply With Quote
Old 12-28-2013, 04:57 PM   #20078
Schs2013's Avatar
-Marc Gill
Old 12-28-2013, 05:23 PM   #20079
Hi, for me M-Grip/S-Grip tires, ball bearings, lead weights (to put in front bumper). The stock gear diff is fine. To give it limited slip effect, fill it partially with thick oil then seal the edge with gasket sealer or hot glue gun.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 12-28-2013, 06:05 PM   #20080
Hoping someone on here can help me I have an m05 gold edition and I cracked the chassis and cannot find a replacement one for it anywhere I realize I can put the standard on but kinda makes the kit pointless and I'm not gonna paint it
Proud to be a team driver for Triton , Radiopost, Pro-line
Yokomo YZ2DT, Bmaxx4 III, Sworkz s104evo all Tekin powered. Sworkz s350T Triton L5 powered, Sworkz S350 evo2 Triton L4 powered
scorpion51503 is offline   Reply With Quote
Old 12-28-2013, 08:06 PM   #20081
Obviously bearings, but the most important is the aluminum steering rack. There are several on the market with the Tamiya one being the best and by far the most expensive.
As far as the other upgrades, many of them are dependent on the track and the surface you race on. It's better to see what the locals are running and copy that. An example of that would be the aluminum rear blocks. If they are using 2 degree blocks, you can save yourself the $40 by using the kit ones. Minis are like any other car, you can go crazy on option parts.
Granpa is offline   Reply With Quote
Old 12-28-2013, 08:22 PM   #20082
Schs2013's Avatar
Thanks for those tips so far i will look into what the locals are running and the steering kit and bearing are on the list for next season. thank you for the help
-Marc Gill
Old 12-28-2013, 09:21 PM   #20083
monkeyracing's Avatar
Since you're running WCICS, the Yeah Racing and 3Racing steering racks are viable. I've been using the Yeah Racing setup. It's pretty good and it has a lot of adjustability. Avid is great for bearings. The Revolutions series are a bargain at a buck each.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 12-28-2013, 10:26 PM   #20084
Schs2013's Avatar
Does Tamiya include servo adaptor for 23 spline Spectrum servos? for a M05 would it be one marked with KO?
I am looking over my manual and puzzled at the moment?
Again thank you for all your help!
-Marc Gill
Old 12-29-2013, 06:52 AM   #20085
Hasi's Avatar
Hey guys,
I need some help. I ran these tires on my M-Chassis and they worked really, really fine and personally I like them more than the sweeps. Plus, they don't grab dirt from the carpet so there's no drifting around corners after a few rounds
http://www.rcmart.com/mini-radial-pr...?cPath=35_1086
Anyone knows where to buy them?
Or if the Pit Shimizus are equally?
http://www.ebay.de/itm/151195847197?...84.m1423.l2649
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage, Tamiya Mercedes Arocs 8x4
Hasi is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
