Old 11-27-2013, 11:42 AM   #19921
mekios's Avatar
Nope, stock gears everywhere.
Soldering skills are fine. No cold joints. The buds car it's his solder job but the same concept.
The ESC has 2 protection modes, overheat and overcurrent. I am ruling out overheat cuz its really cold and overcurrent is left to see.
mekios is offline   Reply With Quote
Old 11-27-2013, 01:02 PM   #19922
Stop trying to make these cheapo ESC's do what they can't do , and get a ”no limit” serious brushed ESC !!! Wow!!!
bertrandsv87 is offline   Reply With Quote
Old 11-27-2013, 01:04 PM   #19923
mekios's Avatar
Any recomendations?
Old 11-27-2013, 01:11 PM   #19924
Lrp v7.1 , old Novak Gtb ,Gtx, etc..., Tekin RS pro, RS, FX pro, etc..., Duratrax 8T esc, Lrp Qc2/Qc3, if you can find them......
Old 11-27-2013, 09:37 PM   #19925
Basically anything Novak. My Novak Cyclone can handle up to 10 cells, but would need an LVC for a LiPo. It's a tank of an ESC though as long as you don't need reverse. A Futaba MC210CB is what I have running in the other chassis I take care of, and it makes the standard Tamiya Silver Can fly (and has reverse) But both of those are older than LiPo, so you'll need an LVC.
pizzaboy192 is offline   Reply With Quote
Old 11-28-2013, 08:13 PM   #19926
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by mekios View Post
Any recomendations?
Ignore that guy for one.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 11-28-2013, 09:55 PM   #19927
monkeyracing's Avatar
That's the best thing I've read all week! +1M
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 11-28-2013, 10:00 PM   #19928
Beware of the haters on Rctech.... They come in packs of ”partners in life” congratulating each other all the time, if you know what I mean...lol... Happy racing....
Old 11-28-2013, 10:05 PM   #19929
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Not really, you just spew out a lot of BS. Makes the new guys more confused.
Dan is offline   Reply With Quote
Old 11-28-2013, 10:21 PM   #19930
Here we go, another member of the ”partners in...” ! It never fails. They follow folks on here, harrassing them forever.... Keep it up guys.... Bravo...
Moving on, I run my mini with an old Lrp v7.1 no limit esc , and I never worry about overloading the esc. I just time my runs so the lipo won't get down too far, and my motor won't fry... I get well over six minutes solid runtime, and put back about 1200mah in the tp3200 lipo pack to recharge it...... Just helping the newbies not the partners....
Old 11-28-2013, 11:12 PM   #19931
CraigMBA's Avatar
I used to race a lot of oval at the very end of the brushed days. I still have my Turbo30 that I used to break in stock motors back in the 27 wind Epic days. I remember with the super soft Orion F brush would pull 8.0-10+ amps at 1 volt. After breaking in the six new Johnson motors I had lying around, the very best one is 1.3 amps at 1v.
Why does this little motor need a big amp speed control?
My current favorite is this one - it's small, light, dependable, and $20.
http://www.teamassociated.com/parts/details/LRP80810/
Old 11-28-2013, 11:43 PM   #19932
That micro esc use to cost $149.99, while my lrp v7.1 use to go for $120... Now brushed no limit esc's are also reasonably cheap ($40-$60), but they can run any motor out there, not just mini. I go for big amp ratings for peace of mind, and not having to buy an esc twice if I need to put that esc in another car... I still own many cars with mod brushed motors in them.
The esc is an investment , and the more it can do, the better... If it also can run brushless, then go for it : tekins, Novak gtb/kinetic, etc...,that are a bargain.....just sayin...
Old 11-29-2013, 03:16 AM   #19933
Boons's Avatar
I've just fitted my -1 degree front upper arms to my M05. I have taken a shot of it next to my stock M03 for comparison.
I hope I notice some difference when I test it!
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 11-29-2013, 02:49 PM   #19934
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
cool... got them for mine and i'm curious to see how they work
mine's in the middle of a complete re-build
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-29-2013, 09:14 PM   #19935
caltek1's Avatar
Trader Rating: 33 (100%+)
Default A new setup to test
I have just begun testing the new shorter front linkage, with the MO6 hinge pins and cf rear shock tower. We are also experimenting with the Ride inch ups as a control tyre for future events.
With this combination I have found you need to run softer oil and softer springs. On a short tight track, I found I had issues with understeer unless I got off the throttle, which made my car slower.I am looking at trying some other things to see if I can rectify this.
So far I have shortened the steering link, so it has no spacer, softened the front oil to 30 weight and red trf short spring, rear same oil but fluro blue spring. I am running 6mm axle hubs, but might try thinner up front. I am running two degree rear hubs, which I will change to 1 degree to see if it improves the steering. Ride height is low with the front lower than the rear. I am also using the JCW coupe body. I did increase the length of the shocks so the car would sit properly.
As I say a work in progress.
Any advice will be taken on board for possible testing. I have the new gold edition bottom toe in block, so you can run 2.5 degrees rear toe.
Thanks,
Calvin.
Tamiya mini cooper-20131128_183519.jpg   Tamiya mini cooper-20131128_183551.jpg   Tamiya mini cooper-20131128_183714.jpg   Tamiya mini cooper-20131128_183613.jpg
caltek1 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
