Old 11-06-2013, 09:56 AM   #19816
AngryRog's Avatar
Trader Rating: 19 (100%+)
Set up a carpet mini...
Anger, K-Speed, Mini Mafia, NitroHouse.com
M03, M05v2 Pro, FF03-R, TA05v2, TRF419X, Roche P12
AngryRog is offline   Reply With Quote
Old 11-06-2013, 09:57 AM   #19817
cartix's Avatar
Trader Rating: 33 (100%+)
The CRX is MWB correct?
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 11-06-2013, 11:06 AM   #19818
Bensi, you have a PM
Granpa is offline   Reply With Quote
Old 11-06-2013, 11:20 AM   #19819
kwkride's Avatar
Yes it is
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 11-06-2013, 11:30 AM   #19820
So lets say I'm not planning on doing any racing that requires the chassis to be all tamiya parts. What other ways can I lengthen the chassis to 225mm without the kit? (or are there ways to build the lengthening kit so that it can be easily removed?)
pizzaboy192 is offline   Reply With Quote
Old 11-06-2013, 11:36 AM   #19821
kwkride's Avatar
Which chassis are you running?
Here is one way to do it, and there is a lot of good information on the site too.
Jim
Old 11-06-2013, 11:41 AM   #19822
Trader Rating: 18 (100%+)
Originally Posted by monkeyracing View Post
What are these made of? Pics look like plastic. Might still be a better, less fragile option than the 3Racing link set.
Monkey,
Some sort of plastic. I had the 3 racing links on my Xevo, my set bound up the front suspension, couple of bad ball cups.
back9monsta is offline   Reply With Quote
Old 11-06-2013, 11:43 AM   #19823
M03 SWB. Will that trick get me to 225?
EDIT: shoulda read it. That looks like it should work, and that'll be easier to switch my fiancee's car between her Mini and the Civic I own.
Old 11-06-2013, 11:44 AM   #19824
Daddy Like!
Old 11-06-2013, 11:46 AM   #19825
kwkride's Avatar
Yep!
Jim
Old 11-06-2013, 12:49 PM   #19826
monkeyracing's Avatar
Thanks! Those 3Racing links are kind of cheesy.
Edit: I just took some measurements of the stock links. They're 17.5mm center to center on the screw holes. The new links are 17mm and 18mm. That's some really fine tuning in an otherwise sloppy car. Wow!
You could also get yourself Tamiya pn 51238. Cheap and loads available on online. This gets you chassis extensions, 2 degree toe in rear uprights, plus C hubs and steering knuckles.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 11-06-2013, 04:59 PM   #19827
Laguna Bozo's Avatar
Default MO5 front camber links
Bensi,
Can you expand a bit on this "must have"? Thanks Bud.
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 11-06-2013, 11:38 PM   #19828
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Expecting it to come together a lot better than my Atomic VM2...
Dan is offline   Reply With Quote
Old 11-07-2013, 01:46 AM   #19829
tony gray's Avatar
It's a much better car Dan, no question of that. Mind you it's also a lot pricier than the Atomic as well.
Whatever you do though, revise the steering system before you even THINK of running it. The stock bellcrank will break the moment a gentle breeze wafts past the car.
The first 2 pics are what we did to fix it, the third is where the problem area is with the stock system.
Tamiya mini cooper-screenshot007.jpg   Tamiya mini cooper-screenshot008.jpg   Tamiya mini cooper-screenshot009.jpg
tony gray is offline   Reply With Quote
Old 11-07-2013, 02:15 AM   #19830
Dan
Dan's Avatar
Thanks Tony! I was a bit annoyed to discover that the servo was mounted north/south instead of east/west but I'm glad to see the setup works and there is clearance with the upper deck too.
I was going mad since my ESC would not fit in front of the motor in the stock servo position and I didn't want to put it in the rear. You made my day! Hahaha
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Tandum4056
SEO by vBSEO 3.5.0
