Like Tree23Likes
Old 10-29-2013, 10:19 AM   #19771
Originally Posted by pizzaboy192 View Post
I've heard of taking a hammer to the motor before, but questioned the legality of it. Looks like it's technically legal as you're not advancing the timing with it, just jostling the magnets (risking destroying the motor in the process)
There are a ton of "old school" tricks that were in some cases effective. This was usually due to the inconsistencies in the motors. Beating on it with a hammer was never a good idea. In the diagram with the hammer, he was tapping on the end of a "stick" to move the magnet away from the end of the case. This will "center" the stack of the armature to the magnets. You really don't need to use a hammer cause if you push firmly on the magnet, it will move cause it's only held in place by clips. If you get a performance increase, you'll have to "glue" the magnets in place or they will shift back.
It's not overly difficult to achieve a 20k Silvercan, but it's just boring work. It can also become expensive cause the motors are inconsistent, although they seem to be better now than they used to be. I used to buy motors in lots of ten and there would be one or two "duds" in every lot. However, since they have an rpm limit in the TCS races now, there's hardly any point in doing much motor work. The "new" batches of the Johnson motors can exceed the rpm limits if you're not careful.
Granpa is offline   Reply With Quote
Old 10-29-2013, 11:01 AM   #19772
KA2AEV's Avatar
Since we are discussing Silvercans etc...
Does anyone know the RPM difference between a 540 and a Torque Tuned Motor?
Or is there a difference?
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 10-29-2013, 11:09 AM   #19773
monkeyracing's Avatar
Nice! I hadn't seen that page. I stumbled across the video on YouTube and grabbed that frame out of it. Thanks for finding the source.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-30-2013, 12:02 AM   #19774
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
Has anyone tried the Shimizu 55mm treaded tires? Any good?
Dan is offline   Reply With Quote
Old 10-31-2013, 05:29 PM   #19775
From just a brief trial, they seem to have much more "grip" than the Sweeps that they were being compared against. In the particular conditions we tested them, they had too much "grip".
More testing needs to be done before I'd recommend or not.
Old 10-31-2013, 07:17 PM   #19776
Dan
Dan's Avatar
Thank you, this is on asphalt I presume? Which compound also?
Old 11-01-2013, 09:32 AM   #19777
No, it was on carpet. They were hard fronts and soft rears. I can't give any info on which inserts were used. Did a handful of laps with them on asphalt, but decided at that time the inserts in the front tires were wrong. I gave the 55mm Shimizus I owned to another racer so can't check exactly.
My overall impression of these tires is favorable, but since all of my racing in the future will be on 60D tires, saw no need to keep them. Too much work to figure out the right wheels and inserts and find the right set up for these tires.
Old 11-01-2013, 10:37 PM   #19778
I picked up a mini. Went to local hobby shop and asked the guy what type of battery works with the mini. He gave me a 3s lipo. Is this too crazy for this car...even if brushless motor
Franjo is offline   Reply With Quote
Old 11-01-2013, 10:39 PM   #19779
nolo148's Avatar
Not sure which hobby shop told you a 3s would work but your looking for 2s round hard case packs.
nolo148 is offline   Reply With Quote
Old 11-01-2013, 11:10 PM   #19780
jcr
which inexpensive 2S will work? The GenAce technically fits but the wires are not coming out of the center. any other options?
jcr is offline   Reply With Quote
Old 11-02-2013, 04:56 AM   #19781
volracer's Avatar
Send a message via ICQ to volracer
Something like this with the rounded sides:
http://www.tqrcracing.com/shop/produ....asp?p_id=5802
volracer is offline   Reply With Quote
Old 11-02-2013, 05:12 PM   #19782
AngryRog's Avatar
Trader Rating: 19 (100%+)
My TA03 ball diff is 'diffing out'. Newly built diff, maybe 20 runs on it. Still feels smooth.
Really confirmed this on my last run today, didn't make the opportunity to consult the Mini Mafia before leaving.
Any thoughts?
Anger, K-Speed, Mini Mafia, NitroHouse.com
M03, M05v2 Pro, M05v2-R, FF03-R, TA05v2, TRF419X, Roche P12
AngryRog is offline   Reply With Quote
Old 11-02-2013, 08:17 PM   #19783
Any thoughts?
Roger,you have a PM.
Old 11-02-2013, 09:33 PM   #19784
Tron's Avatar
Trader Rating: 16 (100%+)
Any idea if this body will fit an M03 or is the servo height too high to look right?
http://www.tqrcracing.com/shop/produ....asp?p_id=1002
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 11-03-2013, 04:35 AM   #19785
Tim K's Avatar
I had one on my M05, and it only just fit when using the front shocks in layed down position. If you're using an M05 with the front shock tower, or the M03, there is no way it will fit ... unless you want to cut holes in the body and have the shock tops poking out :-)
Tim K is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
