Like Tree1Likes
Old 10-24-2013, 02:35 PM   #19726
Originally Posted by howardcano View Post
Okay, my mistake. Since I bought my car used, I didn't even know that the "arches" on either side of the servo were separate pieces, or could be removed without compromising the structural integrity of the chassis.
Is it allowable to leave the arches off under TCS rules? (Not that I have any idea if those are the rules your club uses. But I'm curious now, since my car needs to be TCS legal.)
EDIT: Found the answer to my question: TCS Rules General "1. All chassis platforms must be built per the instruction manual. Altering their basic structure and design is prohibited."
For TCS, the "hoops" need to be in place. That's TCS in the USA. Some will not tighten the rear screws. Theoretically, loosening the screws should allow the chassis to flex more, but for a driver of my limited capabilities, there doesn't seem to be much difference. Removing them seems to be more of a lightening procedure rather than something that will make a huge difference in rear end grip.
They have been allowing you to leave the esc and receiver platforms off tho. A lot of the guys do that and just "sticky tape" them in place.
Granpa is offline   Reply With Quote
Old 10-24-2013, 02:39 PM   #19727
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Yep we allow non required components to be left off, including the little radio trays on the M05.
Jim I dont run them on mine, only because it looks cleaner. I found zero recognisable difference on the track, since i removed them.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 10-25-2013, 04:05 AM   #19728
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Originally Posted by caltek1 View Post
The MO6 suspension shaft with ball is used on the new MO5 Pro gold edition, so I can not understand how it would not be legal. That would make it Tamiya supplied part.
They are not the same part, the is a difference in length, the M05GE being 1mm longer than the M06PRO, and they are easily identifiable as the M05GE has a groove cut into the cylinder portion of the pillow ball end.
marcos graveyar is offline   Reply With Quote
Old 10-25-2013, 11:15 AM   #19729
I'm just building a m05, and am wondering on these parts. Do I need both or just one? I'm guessing 54121 is the better one?
Tamiya (#51000) Servo Saver High Torque Type (black)
Tamiya (#54121) HT Servo Saver
Franjo is offline   Reply With Quote
Old 10-25-2013, 12:24 PM   #19730
Laguna Bozo's Avatar
There may be different part #s, but my M06 ball-end suspension shafts measure 36mm long, and fit M05 just fine. In fact, they are about 1mm too long on M05, and about 2mm too long on M06. Seem to work fine on either, whether shimmed or not...
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 10-25-2013, 01:57 PM   #19731
The mid-sized Kimbrough may be a better option.
Old 10-26-2013, 03:01 AM   #19732
monkeyracing's Avatar
Got bored this evening, so I built a set of Super Mini CVA dampers and every other damper in my hobby room began to leak sympathetically. Wow, those things are weepy!
Any thoughts on sealing them up?
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-26-2013, 02:39 PM   #19733
CraigMBA's Avatar
Trader Rating: 22 (100%+)
What o rings did you use?
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 10-26-2013, 03:46 PM   #19734
Used the clear ones they came with. Those are actually okay - it was the tops that we're letting all the good stuff out. Problems seems to have resolved itself. They were dry this morning. (Must be empty!)
Stab it and steer.
Old 10-26-2013, 07:54 PM   #19735
madjack's Avatar
Send a message via Yahoo to madjack
So Cal Mini locals - what wheel / tire combo do you recommend for (trying) to run an M03 at TQ.
Thanks in advance,
John
madjack is offline   Reply With Quote
Old 10-27-2013, 02:32 AM   #19736
Boons's Avatar
Default Lwb shells
Hi all,
Apart from the later Mini shells, what else is there that would fit an M05 with the 54236 front shock mount?
Cheers all
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 10-27-2013, 12:36 PM   #19737
Thanks in advance,
John
For club races at TQ, sweep 40 in the front and 33 or 25 in the rear. Light coat of CA on the front tires. I usually put the front tire on the rear hub so it spins freely and apply the CA with q-tip.
For TCS races, Old S grips all around with light CA on the first tread on the front tires. If car is still traction rolling CA the shoulder of the front tire.
back9monsta is offline   Reply With Quote
Old 10-27-2013, 01:32 PM   #19738
I was wondering if an aftermarket M05 diff will fit a M03?
Are the only diff options for a M03 the 3racing ball diff and TA03 ball diff? Does anybody make a sealed gear diff?
jha07 is offline   Reply With Quote
Old 10-27-2013, 02:34 PM   #19739
Unless it is the longer, grooved version that comes only from the M05GE then Tamiya will rule it as ineligible for their race series.
Old 10-27-2013, 02:40 PM   #19740
The standard M03 setup is a planetary diff. I've built a few using the reinforced gear sets, and they're ranther strong for what's in them. The gearing is different on the M05 from the M03. Supposedly the gears for the M04 fit an M03, but as I only have the M03, I can't comment.
pizzaboy192 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
JUNI
