Like Tree1Likes
Old 10-01-2013, 11:59 AM   #19636
cementsurfer86's Avatar
Novak's Edge 2s speeder can be used for brushless/brushed racing. I have a few of them, easy to use, as with any Novak unit.
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 10-01-2013, 12:17 PM   #19637
howardcano's Avatar
Trader Rating: 35 (100%+)
Are you sure you aren't thinking of the Havoc? I have both Havocs and Edges, but only the Havoc instructions cover brushed (and it works well, although it's very large for a Mini). Is brushed operation a hidden feature in the Edge?
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 10-01-2013, 12:26 PM   #19638
Thanks!
gguertin145 is offline   Reply With Quote
Old 10-01-2013, 02:20 PM   #19639
Yep, you're right. My bad! I have both and got the two mixed up.
Old 10-02-2013, 06:24 PM   #19640
Shopping for spare parts to make waterproofed so I can drive in the rain. What specs should I look for in a servo? or shouldn't I worry about it getting wet?
pizzaboy192 is offline   Reply With Quote
Old 10-03-2013, 05:20 PM   #19641
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I'd worry about the speed control and the receiver....
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 10-03-2013, 06:07 PM   #19642
monkeyracing's Avatar
Traxxas makes a line of waterproof servos. That might be a good place to start. Your best bet would be to find a video or two on waterproofing RC electronics for trail trucks. There are techniques that are as simple as stuffing things into balloons to complete tearing stiff down to encase it in epoxy. I just avoid water. haven't blown anything up since the puddle incident of 2008.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-04-2013, 02:18 AM   #19643
muahdib4's Avatar
Send a message via Yahoo to muahdib4
Savox also makes waterproof servos. None of them are exactly speed demons but should work ok on these. I use them on my scale trail rigs.
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 10-04-2013, 12:40 PM   #19644
That's where I got my inspiration. I saw some videos of using PlastiDip and stuff like that, but my plan is just a few old sandwich containers and some hot glue around wires. Was planning on putting just short jumper cables for battery and motor in, and a servo wire, and then packing both the RX and ESC into the sandwich container and toss that in a ziplock if required. We're wanting to do winter rally and rain racing this fall, but want to have them be safe. Was going to order some servos as spares so if\when we do kill one, we can replace em quick. Probably will put the battery in something similarly shaped that should be waterproof as well.
Old 10-06-2013, 02:13 AM   #19645
Hey guys, big question about small parts: How does camber affect top speed? I'm running the stock, solid upper links on my M03. At the very low ride height we tend to run, they give a fairly insane amount of camber. I know this is generally good for cornering and bad for tires, but does it have an effect in a straight line?
I'm generally happy with my setup (crude as a rock). It corners very well as is. I've got a complete set of adjustable uppers I'm hesitant to install. How do you guys see it?
Stab it and steer.
Old 10-06-2013, 12:06 PM   #19646
CraigMBA's Avatar
Except that the camber speeds tire wear, makes the tire smaller, which lowers the effective gear ratio, no changes.
Old 10-06-2013, 08:23 PM   #19647
3racing dif gear set or ta03 dif set ... do you need extra bearings to install in a m05 complete?
TeamThibault is offline   Reply With Quote
Old 10-06-2013, 08:44 PM   #19648
OOPS-edit
The 3Racing gear diff uses two 10X15mm bearings. The TA03 ball diff uses the same bearings as the stock diff.
mariob62 is offline   Reply With Quote
Old 10-06-2013, 08:45 PM   #19649
Theoretically, yes. But taking tire wear out of the equation, what does it do? EG: Two cars bombing down the back straight, one with loads of camber, the other with almost none, how will the top speed of either be influenced?
I've got some ideas. Just looking for perspective.
For the TA03, no. For the 3Racing you'll need a couple 10x15x4 bearings.
Stab it and steer.
Old 10-06-2013, 08:56 PM   #19650
CraigMBA's Avatar
Which has the biggest tires?
If your M chassis is getting passed on the straight....it isn't camber. IMO.
Tried, but failed, to go club racing yesterday. Last chance for me for a month probably.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
