Like Tree19Likes
Old 09-19-2013, 08:37 AM   #19561
No need to give you a hard time granpa, you made the Amain, you made the show ..... A few unfortunate crashes kept you from a podium finish, and it seemed that you were losing some power at the End of each main..... Just a few things to straighten up, and you'll make top three consistently... Keep up the good Work, and I am still reading this thread eventhough I don't post here as much as before....lol....
bertrandsv87 is online now   Reply With Quote
Old 09-19-2013, 10:27 AM   #19562
monkeyracing's Avatar
Which car was yours Bob? Who was driving what appears to be a red/yellow coupe and said "dammit" a lot?
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 09-19-2013, 10:38 AM   #19563
Thanx, but driving talent will keep me about where I presently am. I had a faster set up, but it was harder to drive. Opted for a little more conservative one that I could hold together for 5 min.
Granpa is offline   Reply With Quote
Old 09-19-2013, 10:56 AM   #19564
Mine was the all red Swift that was running near the back. Dave Weir had the Coupe. I heard he got involved in a couple of tangles. I got punted to the rear of the field in the first and third mains. Had a good clean run in the second, worked up to fourth, but didn't have the pace to keep Jason and Kevin behind me so let them go by.
Great fun, but those 8 min. mains are really tough.
Old 09-19-2013, 12:38 PM   #19565
cementsurfer86's Avatar
8 MINUTE MAINS?!
....Talk about a mental meltdown times 3. Good lord.
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 09-19-2013, 04:51 PM   #19566
AM03GT's Avatar
nice vids, i miss the Tamiya track
out here beachside Brownies racing we do 10 minute A-mains for mini
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 09-19-2013, 05:21 PM   #19567
10 minute mains would be epic with a mini!
Several years ago, we did a 12hr enduro with mini's at (Now-Defunct) SIR. Still probably the most fun I've had racing.
Old 09-19-2013, 05:54 PM   #19568
AM03GT's Avatar
10 minute mains ARE epic! if you're leading you have to be super consistent and if you're behind you have plenty of time to make a move!
thank goodness for newer lighter radios 10 minutes with a M11 was rough!
Old 09-19-2013, 06:25 PM   #19569
I have a base setup that should work, my first carpet race will be next Wednesday, I'll post it after a good shakedown.
Get good results?
Granpa,
I have the Hudy and XXX Main touring car set up books to help with my 417.
Does that info transfer over to the front wheel drive M05?
ncpantherfan is offline   Reply With Quote
Old 09-19-2013, 09:39 PM   #19570
fresnojay's Avatar
ncpanther, I can tell you that is a big fat negative! I found that out the hard way. But thanks to many here in the thread got my head on straight in the realm of the mini.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 09-19-2013, 09:45 PM   #19571
Originally Posted by ncpantherfan View Post
Get good results?
Granpa,
Some of it does and some of it is just backwards. My background is TC primarily with X-rays and Tamiya TC. This in my case delayed my progress with Minis cause I had to unlearn before I could learn. It was very confusing cause what worked before did not work with the Minis, but enough did that it was hard to let go of what I knew. Hope that made sense.
It's probably better to let go of your TC set up books and write your own Mini book. You'll probably progress much faster. The M05 and the 417 are as different as men and women. What makes one happy can just p--s the other one off. You even have to drive them differently. The cars, not the people.
Old 09-19-2013, 10:13 PM   #19572
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
I have the M03...
I' wondering which of the mini chassis M03.M05 or M06 is better on carpet?
OVA is offline   Reply With Quote
Old 09-19-2013, 11:15 PM   #19573
Get good results?
Sorry, I actually meant next Wednesday, oops!
I'll post my base-setup afterwards. Should be close as it sits, but we'll see.
Old 09-21-2013, 09:12 PM   #19574
There was some talk about fitting the rear carbon shock tower and the M06 suspension ball shaft #54296 to the M05. It gives you a wide range of options and may be an advantage. Since this was before the Nats, I was only able to get to it this past week.
It was not just a bolt on the shock tower and fit the suspension pin conversion. The rear shocks on the MWB car need to be lengthened to at least 58mm by removing some of the internal spacers. I can't tell you how many cause my shocks are the TRF TC shocks. The top shock ball was put in the second hole from the outside of the shock tower. The rear suspension felt much stiffer than in the stock positions.
It turned what was a sweet handling M05 into an evil, ill handling piece of doodoo. The main problem was it was really "twitchy". I could not turn a single clean lap with it. Not everything was bad though cause when I could get a decent corner entry, it carried better corner speed. It seems to have the potential to be a useful mod, but be forewarned, it's going to take some work and some rethinking about what makes a Mini work.
I have a number of ideas to get the Mod to work. I won't share them cause I haven't the foggiest on whether they work or not. If I'm going the wrong way, I don't want to lead anyone else down some rat hole. If they work, I'll post them.
Old 09-22-2013, 12:32 PM   #19575
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
When I run the M06 lower link I lengthen the shock by using the longer ball connector from the 58193 V Parts bag.
marcos graveyar is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
