Like Tree21Likes
Old 09-05-2013, 08:30 AM   #19456
sosidge's Avatar
Originally Posted by Boons View Post
I'm still wondering which UJ's to go for guys, one of the Tamiya types or 3 Racing? It's for indoor carpet with kit motor if that makes a difference.
Cheers
Tamiya.
Old 09-05-2013, 08:59 AM   #19457
RussF's Avatar
Trader Rating: 21 (100%+)
Cheers
I see a few post back you were looking at the 3Racing gear diff. I also purchased the 3Racing gear diff a few months ago. I went ahead with the 3Racing universals since I knew they would fit fine. No problems so far with them, the seem to work great. I've not tried the Tamiya ones but I'm sure they are fine also.
BTW since my gear diff was quite tight in the beginning I tried running it in with a drill to "break it in". It did loosen it up a bit, but I still ended up only putting 70k diff oil in instead of the 500k or 1M oil I ordered with it. Maybe someday it will loosen up enough to use those high weights but for the past few months its been great with the 70k.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 09-05-2013, 09:01 AM   #19458
Boons's Avatar
Originally Posted by sosidge View Post
Tamiya.
Which ones, the fixed ones or the ones you build?
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 09-05-2013, 10:24 AM   #19459
Boons's Avatar
Do all the bits come with the 3 Racing diff? Do i need additional bearings etc?
Old 09-05-2013, 10:36 AM   #19460
RussF's Avatar
Everything but the bearings and the fluid. Yes you need to get bearings 10x15x4.
Old 09-05-2013, 10:47 AM   #19461
Boons's Avatar
Thank you. Two of those?
Old 09-05-2013, 11:01 AM   #19462
RussF's Avatar
Yes one for each side.
Old 09-05-2013, 11:32 AM   #19463
cementsurfer86's Avatar
I'm more of a fan of the Spec-R diffs. Just personal experience. Worth a try if you're considering a fluid diff.
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 09-05-2013, 11:40 AM   #19464
sosidge's Avatar
I doubt it matters, but the old ones will be harder to find and if they wear out they will have to go in the bin.
Tamiya parts fit perfectly and are well made. I can't think of a single component that is better than the Tamiya part anywhere on the car - the only exception being the diff and that is only because Tamiya don't make an oil-filled gear diff. My car is all Tamiya with the exception of the diff, and the diff (3Racing) is the part that has needed the most fettling to get right.
Old 09-05-2013, 12:21 PM   #19465
+1
I keep my main car TCS-spec at all times, just because it makes it easy. Tamiya's fit/finish is top-notch, so I've never seen the need to use aftermarket stuff.
The fluid diff's are nice, and I have a Spec-R unit ready to put in to my secondary car to test with, but you can get the same effect for the most part with the stock gear diff. I just use different greases and shim stacks.
Old 09-05-2013, 01:04 PM   #19466
mugler's Avatar
I just dropped a TA-03 ball diff in my M03 to repace a grease packed stock gear diff and the car turned into a rocket on the straight as well as excellent corner speeds, can't detect any wheel spin either...Have never tried the fluid diffs...how does the ball diff performance compare to fluid diff's? I can't imagine it being much better but would love to hear from those who have tried both.
mugler is offline   Reply With Quote
Old 09-05-2013, 01:54 PM   #19467
Boons's Avatar
Thanks guys
I was surprised to see plastic diff gears in there, I guess spur gears can take abuse so why can't these. Also do you use the plastic cushions for the drive shafts supplied or just continue to put the rubber o rings in the outdrives?
Old 09-05-2013, 02:57 PM   #19468
monkeyracing's Avatar
In the interest of being a contrarian, I'd suggest 3Racing v3 universals. I own 3 sets, drive like a hyper 5 yr old on Red Bull and crash a lot. I've never had one fail. I can't even tell them apart from the Tamiya units. They're pretty much the only non-Tamiya parts on my cars.
Avoid their v2 unis, if they ever pop up and the Yeah Racing ones are extra crappy.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 09-05-2013, 03:36 PM   #19469
sosidge's Avatar
Thanks guys
You need to use the blades otherwise the driveshafts will not be an accurate fit in the outdrives.
Old 09-05-2013, 03:48 PM   #19470
Hey Alex..good seeing you in this thread. You should have joined Opi and I at TCS
Danny R
fx35rc is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
