Like Tree173Likes
Old 08-20-2013, 12:42 AM   #19321
Originally Posted by sosidge View Post
Diff oils are a lot thicker than shock oils, you will need to buy some.
My personal preference is for a much lighter oil than 500k in the diff - I run 5k.
Just make sure you run the 3Racing diff in as much as you can before racing it because the standard seals are very tight.
Thanks for the speedy reply. Any particular brand that you use (I see you are in the UK as well)?
Tony.
tonybod is offline   Reply With Quote
Old 08-20-2013, 12:49 AM   #19322
sosidge's Avatar
Fastrax is pretty easy to get hold of and what I use.
Old 08-20-2013, 11:27 AM   #19323
Thanks again,
I'm a bit confused as to what to get. The Fastrax oils seem to be measured in "wt", others are "cst". Does the Fastrax bottle you have mention cst at all?
I've got a conversion chart for the Schumacher shock oil to other types (cst), but cannot find much info on the Fastrax stuff at all.
Did the 3racing diff come with any oil?
Tony.
Old 08-20-2013, 11:53 AM   #19324
c-lyon's Avatar
It comes with 2000, good for an M06. For M05 most racers around here use 300,000 or 500,000.
c-lyon is offline   Reply With Quote
Old 08-20-2013, 12:12 PM   #19325
I'm having trouble finding something suitable. Even the Team Associated oil at one supplier I use only goes up to 100,000cst. It may be that the Fastrax stuff is just measured on a different scale (but I cannot find any info on it (yet)).
Old 08-20-2013, 01:00 PM   #19326
monkeyracing's Avatar
Kyosho 300,000 and 500,000 are available.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-20-2013, 01:09 PM   #19327
sosidge's Avatar
Originally Posted by tonybod View Post
Thanks again,
Tony.
The Fastrax oils are cst, all silicone oils that are measured in thousands are on the cst scale. Go with what you can get hold of and stick to the same brand for consistency.
Old 08-20-2013, 11:36 PM   #19328
Boons's Avatar
Raced last night at a different club and got 3rd in the A with the M05 ��My mate who came along got 2nd in with his M03 so we are pretty pleased with that. The 1st place guy in the A was using a Lwb car. Do the Lwb have an advantage over the swb cars, or is it track dependant?
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 08-20-2013, 11:43 PM   #19329
Picked a nice M06 R kit for cheap.. what's a good build setup for indoor carpet racing?
I'll continue to run the M03 and M05, but maybe I'll try a bit of RWD action this winter.
jjjheimer is offline   Reply With Quote
Old 08-21-2013, 12:52 AM   #19330
sosidge's Avatar
Depends on track, I run LWB outdoors and MWB indoors.
Old 08-21-2013, 04:34 AM   #19331
kwkride's Avatar
I run basically the stock setup. I have the kit oil in the shocks, I am running -2 camber front and rear and I installed an M05 ball diff. I run S grips all around.
For our track this is the car to have. The battle for the win is usually between M06s. The 3s and 5s just can't quite keep up through the infield.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 08-21-2013, 04:58 AM   #19332
Boons's Avatar
On a suspension question, last night I was running yellow front and red rear springs and doing quite well so I left the car alone. 99% of the other drivers were running blue front and yellow rears. Can you explain what running harder front and rear shocks would or should do to the handling on carpet? My car had plenty of grip, however I'm still pretty green when it comes to suspension settings!
Cheers
Old 08-21-2013, 09:35 AM   #19333
Cheers
You are falling into a trap that catches all of us at one time or another. To quote Tony G, " there are no hard and fast rules for Mini set up". Using yours truly as an example, I'd developed a set of guidelines at one of the tracks I frequent. A fellow racer was having a bit of "trouble" so we made a couple of adjustments to his set up. The car looked much better, was easier to drive, and was now nearly 0.5 sec/lap slower. Back to the drawing board for me.
Thankfully, I've been aware of this for awhile now and have been very careful about posting set up advice and have only couched it in very general terms. For your question, try running harder shocks and springs and see what happens. I often try other set ups to see what happens. Mini set ups are a lot of trial and error.
Granpa is offline   Reply With Quote
Old 08-21-2013, 01:47 PM   #19334
Boons's Avatar
Thank you Granpa, I'm always grateful for your comments and advice. And you won't offend me with your honesty! I'll stick the other springs on and see what happens. I was surprised at how different my car felt on another club's carpet. I suppose like anything, it wears out over time!
Old 08-22-2013, 12:01 AM   #19335
Boons's Avatar
What's your thoughts on UJ driveshafts guys? I think part no 53597 (for my M03 & M05) and the harder out drives for the standard diff?
Cheers
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
