Old 08-14-2013, 07:11 PM   #19306
Default Hop up question for M05
New to the forum and would appreciate and advice:
1) on a M05 Mini Cooper can I use the TA03 Ball Diff with the black reinforced gear set ? The TA03 ball diff has the light tan plastic which is not as hard
2) I am building the m chassis aluminum damper set shocks and there are 2 o rings one clear silicone and one black. Do you know which o rings go where? Like which o ring sits on the piston rod between the 2 e rings? Which morning goes in the bottom of the shock assembly?
3) is there a site that shows how to use these shocks with M05 chassis ?
Thanks!
Willis
Willis99 is offline   Reply With Quote
Old 08-14-2013, 07:35 PM   #19307
monkeyracing's Avatar
1. Yes
2. Clear o ring goes in bottom of damper, between the white plastic rings. The black ones I'm not sure about
3. This thread or rc-mini will tell you everything you'll ever need
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-14-2013, 08:38 PM   #19308
Thank you!
Old 08-14-2013, 08:43 PM   #19309
1...also, you'll need to run 5x11 bearings with diff and use the adapter bits supplied with the kit.
Stab it and steer.
Old 08-14-2013, 11:10 PM   #19310
cementsurfer86's Avatar
For those of you NW mini guys, I'll be heading up to Galaxy hobby in Lynnwood for some season-end testing. Should be a light day race-wise, so I'm hoping for lot's of stick-time.
I have a post with more info on my blog: www.theminiunderground.blogspot.com if anyone's interested.
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 08-17-2013, 10:40 AM   #19311
Boons's Avatar
Hi all
I've been trying to get my M05 to behave and not spin around when off power in the bends. As blue front springs and yellow rear springs seem to be what people use I was trying to get that to work. I was having trouble with that so I tried yellow on the front and red on the back, disconnected the rear sway bar and it was a different car, I'd even say competitive!
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 08-17-2013, 10:53 AM   #19312
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Boons View Post
Hi all
I also had to disconnect the rear sway bar on my M05 to get a little more stability. I left it in the car, with only one link removed, so it would be easier to reconnect if the need arises.
One other thing I noticed regarding trailing-throttle oversteer: If I take special care to minimize wheelspin when accelerating, the car doesn't pick up oversteer towards the end of the run. I'm guessing that heating the front tires by spinning them also increases their grip. I'm running type A slicks on CRC carpet. Has anybody else run into this?
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 08-17-2013, 01:35 PM   #19313
Boons's Avatar
Originally Posted by howardcano View Post
I also had to disconnect the rear sway bar on mt M05 to get a little more stability. I left it in the car, with only one link removed, so it would be easier to reconnect if the need arises.
Yes I left my sway bar connected and just took one side off like you. When I ran mine with no other cars I could really hear the motor spinning up for quite a while exiting corners, obviously indicating wheelspin. I am limited on diff work so maybe instead of a red rear spring, maybe yellow? The way I see it is a softer rear spring will allow the inside wheel to spin more on exiting corners?
Old 08-18-2013, 12:34 AM   #19314
David Home's Avatar
Thanks!
Willis
Hi Willis,
The black o ring slides onto the shock shaft so that it sits under the piston, you then push the piston through the shock body and then attach the ball link to the end of the shaft. The black o ring helps reduce droop. Some guys use just the 1 black o ring but I've read of some guys putting 3 in there. Hope this helps
David Home is offline   Reply With Quote
Old 08-18-2013, 04:02 AM   #19315
niznai's Avatar
Originally Posted by David Home View Post
Hi Willis,
The o-rings under the shock piston are used to tune the suspension travel/droop especially if you use hard springs. I prefer to use soft springs and leave the suspension compress a lot under the car's weight. This gives me a lot of droop, I know, but I prefer it that way.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-18-2013, 09:38 AM   #19316
Boons's Avatar
Just finished the build on the M03. Without battery and body, and with sweep wheels, Tamiya's plastic oil filled shocks it weighs 850gms. My hopped up M05 without battery and body is 970gms. Do the shiny blue bits weigh that much!?
Old 08-19-2013, 09:49 AM   #19317
niznai's Avatar
Yep. I actually weighed some of the plastic bits against the alloy some time ago. Only thing you can do now to get back the weight you lost is try titanium screws (about 30g saving on a TC).
And that's how spiral of madness begins.
Lightweight TC bodies are about 100g lighter so that would be another possible move. Not sure if there's lightweight mini bodies though.
Team Greasy Weasel
Old 08-19-2013, 01:25 PM   #19318
sosidge's Avatar
An m03 is a lot lighter than an m05, don't waste your effort trying to get the weight off. The alloy options are generally a bit heavier, but the difference is in single figures for each part.
Old 08-20-2013, 01:10 AM   #19319
Hello all,
My son and I are expecting our 3racing gear diffs any time now. I've trawled through the posts on the board in search of what oil people are using in their diffs and it seems to be the 300-500k (I think gearbox oil rather than shock oil, I'm still quite new to RC racing).
They will be both running in M-05 chassis cars (long wheel base if it makes a difference). We have been racing at a local club here in the UK.
Any recommendations? I've got a few bottles of shock oil already available so it would be great if I could use that instead of purchasing more (I know the Spec R sealed diffs for the Schumacher Mi4 uses shock oil).
Thanks in advance for any recommendations.
Tony.
tonybod is offline   Reply With Quote
Old 08-20-2013, 01:29 AM   #19320
sosidge's Avatar
Diff oils are a lot thicker than shock oils, you will need to buy some.
My personal preference is for a much lighter oil than 500k in the diff - I run 5k.
Just make sure you run the 3Racing diff in as much as you can before racing it because the standard seals are very tight.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
