Like Tree163Likes
Old 08-06-2013, 09:37 PM   #19291
monkeyracing's Avatar
Originally Posted by JaseEng View Post
Didn't see any info about the rally though in tamiya usa. Will check TQ, Perfer to change the motor to brushless with more torque. Do you have any suggestions?
Here's a link to a PDF of the M05ra instruction manual. It'll give you some idea of what you need and how to put it together.
Originally Posted by kawi650 View Post
Does anyone run brushless instead of the stock motor? There is a new track starting up by me and I'm pushing for a more open motor choice for the mini class.
The gold standard for minis is the Hobbywing EZRun 13T system. It's cheap, extremely reliable and has good distribution and support. Part number is 81030020.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-07-2013, 02:56 PM   #19292
thanks for the info.
beginner question, I have a Am futaba jr radio, does those work with the latest esc or do I need a new one.
thanks
JaseEng is offline   Reply With Quote
Old 08-08-2013, 03:02 AM   #19293
KA2AEV's Avatar
thanks
You should be fine Jase, you just need an AM Receiver that matches
your AM Transmitter along with matching crystals (same frequencies,
sorry its 6am here!)
Actually know a few driver that still use AM and even FM transmitters
for their cars!
Its all about having fun with what you got
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 08-08-2013, 05:38 AM   #19294
What's the minimum RTR weight that you guys run? Thanks
cheapskate.brok is offline   Reply With Quote
Old 08-08-2013, 05:58 AM   #19295
Mechintosh's Avatar
1250 gr
Xray T4-14,T4-15, X1
Pro Mini Truggy Mid Motor Mafia Xfactory
Serpent SRX4, 811 TE-e
Kyosho RB6, MP9e TKi
Mechintosh is offline   Reply With Quote
Old 08-08-2013, 10:06 AM   #19296
*double post, my apologies
Old 08-08-2013, 10:06 AM   #19297
Originally Posted by marcos graveyar View Post
We run Nimh's in our series with black can motor and standard TEU104BK speedo. My car would be one of the lighter ones but some are 30% heavier and the racing is always close, it all down to driving style as the others have said.
Beat you to it? Locally we have a 1200g minimum weight rule. Just finished taking off unnecessary weight and optimization. I installed shorter titanium screws wherever possible, taking off the sway bars (ride height around 4mm, too much play before swaybar takes effect), and running a single screw directly over the steering post. I bet I could go lower with a low profile servo and composite knuckles.
Old 08-08-2013, 11:43 AM   #19298
thanks also what kind of battery r u guys using to run the stock gears and the hobby king motor and esc. Any hobby king suggestion or link would be greatly appreciated
thanks
for their cars!
Old 08-08-2013, 11:58 AM   #19299
cementsurfer86's Avatar
I used a Venom 4000 20c Lipo sport pack at the NW TCS regional a couple weeks ago. Now granted, that was with a silver can, but round-case sport packs are super cheap and work just fine for mini, no matter what motor.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 08-08-2013, 12:58 PM   #19300
The HOBBYWING combos are available all over. Try Hobbypartz if in the US.
Stab it and steer.
Old 08-08-2013, 05:15 PM   #19301
Has anyone run the Tamiya Mini JCW coupe body on a M03L? Will it fit?
It seems like it would, but it only shows it being compatible with the M05's, just wanted to check before I order one. Thanks!
Old 08-08-2013, 07:39 PM   #19302
Yes and yes. Nice body that requires a little more work than the usual. The front "splitter" needs reinforcement and the rear wing is a little tricky to get right. Don't short cut or leave any of the parts out or you'll wind up with a fragile rear wing.
It feels as if the body gives a bit more steering than the BMW or the 2006 Cooper S. If you don't bend the splitter, it's a very consistent body without any undesirable characteristics.
Granpa is offline   Reply With Quote
Old 08-09-2013, 02:08 AM   #19303
Boons's Avatar
My dad has just got hold of a NIP M03 Mini Cooper that he has asked me to build and test for him. Oh go on then I thought
I'm looking forward to seeing how it runs compared to my hopped up M05
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 08-09-2013, 10:01 PM   #19304
I've found the M03's are still just as competitive as the M05's. I love my 03.
Old 08-13-2013, 08:03 AM   #19305
Yes, that's so true. It's not a new or particularly enlightened revelation however. Most of the racers in our local area prefer the M03. I think that Mark Brown in your area runs the 03.
The new TCS Spec tire has narrowed the "gap" between the 03 and the 05 locally. Here at the Tamiya USA track, the guys are having to make a tough decision. The consensus seems to be that the M05 is the easier car to drive, but the M03 might be quicker.
What's really interesting is that there are 3 guys who are more "dialed" than the rest of us. 2 of the 3 are using the LWB car. That's probably a more interesting conundrum than the 03 05 debate, which has been discussed ad nauseum on this thread before.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
