Like Tree81Likes
Old 07-31-2013, 03:27 PM   #19261
monkeyracing's Avatar
Originally Posted by Granpa View Post
Let's just call it political correctness...Let's be honest here and call it the drivers skill level.
Call it semantics. Everything depends on where the speaker is coming from and how the listener hears it. In essence however, you're right.
I have a very good friend, whose cars are nearly impossible for me to drive. He is also one of the fastest, if not the fastest driver here locally. In his hands, his Minis are very quick. Now my contention is that this has nothing to do with "style" and everything to do with driver skill.
I hear that. We've got a few guys here that are SUPER quick, but their cars turn to crap if anyone else tries, even very good racers, to drive them. They turn back again when the owners take over. It's a combination of skill, putting in, the laps, the hours and the tuning to suit how they drive.
I've tried various cars owned by fast guys. Some are soft as baby poop, others feel like they've got razor blades for tires. Some were engineered to the n'th degree, others were loose, sloppy wrecks. I was bad with all of 'em.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 07-31-2013, 03:50 PM   #19262
cementsurfer86's Avatar
Good thought Granpa.
Just like a plain-jane kit that we can't leave alone, and upgrade over time, our setups and cars undergo the same transformation as our skill levels progress.
I can't count the number of times my car setups have changed because my ever-changing skill level demands more steering, more response, etc. What I thought was "dialed" 5 years ago, wouldn't cut it now as my skill level has changed.
Obviously, tracks, time of year, class type, etc. all have an affect on how I go about setting up a car, the final "feel" remains the same. The difference when you're skill level goes up, is how you go about reaching that "end-result", and what that final "feel", actually feels like.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 08-01-2013, 03:53 AM   #19263
Boons's Avatar
Hi all,
Re the superglue trick on the front tyre walls, I've heard of lots of different methods and no one has mentioned simply buying one of those pots with the brush under the cap. So I assume that won't work?
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 08-01-2013, 02:13 PM   #19264
Ive never seen CA (cyanoacrylate) glue with a brush before. I've used a brush and it was ruined in a few seconds.
Stab it and steer.
Old 08-01-2013, 02:24 PM   #19265
elv
Loctite makes a super glue "bottle" with a brush. That's what I've used.
Tried to add a link but was not allowed to due to number of posts...
-e
elv is offline   Reply With Quote
Old 08-01-2013, 11:12 PM   #19266
Boons's Avatar
Cheers guys.
Re the NIMH battery, I've a few now of differing sizes but they are all too small for the kit battery clamps in terms of length. What is the procedure here to stop the pack sliding from side to side?
Old 08-02-2013, 01:23 AM   #19267
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
You can put a strip of foam in the battery clamps to cut down on the movement, I used some of the loop side of stick on velcro originally.
I eventually did away with the endcaps altogether and now I just tape them in place with battery tape.
marcos graveyar is offline   Reply With Quote
Old 08-02-2013, 01:56 AM   #19268
Anyone now what the newly announced 58581 MONSTER SUPER SWIFT (M-05) is all about ?
Old 08-02-2013, 02:34 AM   #19269
Boons's Avatar
Thank you.
I have stuck some foam in but just wondered if there was another method. Some of the guys at the club tape their batteries in but I thought that might be a pain if you plan on switching cells through the night?
What is that clamp that has just the one body pin holding it in place?
Old 08-02-2013, 08:11 AM   #19270
Originally Posted by Boons View Post
Thank you.
The best solutions always seem to be the simple ones. In this particular instance it's tape. Create a 2 layer piece of tape by laying one piece directly over the other, then use that to tape the battery in place. This stiffens the tape so it's much easier to handle and the double layer makes it so that you don't have to wind the tape around the battery twice.
Those pieces were originally in the M03. In my personal cars, the 05 holder is used on the right and the 03 holder is used on the left. I posted awhile back the whys and hows for this particular combination, but it was for the use of lipos, so is not applicable here.
Granpa is offline   Reply With Quote
Old 08-02-2013, 10:36 AM   #19271
Same M05, but with Monster Energy stickers?
Stab it and steer.
Old 08-02-2013, 02:22 PM   #19272
Boons's Avatar
Hi all
So first night using my M05 last night at my indoor carpet track. I went quite well but would now like to discuss my findings. My car is equipped as follows
TRF shocks with 3 hole pistons, built as per instruction, 600cst oil in the front, 500cst in the rear, blue springs on the front, yellow on the rear, adjustable upper arms on the rear with a 1mm spacer in between, a 2mm spacer in between the front steering arms, M grip tyres all around (club rules allow standard or m grip 60d tyres) silver can motor with 20t pinion (club rules). The ride height is about 5 or 6mm. I also have the front suspension hanger that allows the shocks to be stood up. I use the outer hole.
I have the 3 racing alloy steering set up with the arms in the front holes, shimmed to be level at ride height, and a high torque servo saver. I haven't done the super glue trick on the edge of the front tyres but here's what I found. The car was quite sensitive with lots of steering, it wasn't uncontrollable but wasn't as forgiving as the M03 I used a couple of times a few weeks ago. I could turn my car on full lock flat out and it didn't roll, but it does 'tripod' and lift its rear wheel, it has that trying to stop itself turn in whilst lifting the rear wheel if you know what I mean. Guys at the club suggested the glue trick but I wonder if the car needs dropping further or more?
Good fun though, even if my lap times were 1 sec down from the battered, friction shock equipped M03 I used the other week........
One last thing, some guys used the O rings behind the shock pivot balls??
Thanks all!
So I have just got back from racing. Since last week I have changed the shock oil to 500cst front, 450cst rear as last week I got my oils wrong! (I was copying the M05 set up on rc mini.net and didn't read it properly!) I have lowered the car to about 5mm at both ends, applied superglue to the front tyre side wall, increased the front toe out so there is about 1mm between the steering arms, and shimmed out the axle slop. The car still has loads of steering so I was taking it easy not to turn in to hard, no grip roll due to the superglue, but if I have to lift off in the corners the back steps out or will spin out. I managed to get through the evening with some reasonable lap times but it was hard work! What could I try to counter the lift off oversteer?
Cheers
Old 08-05-2013, 08:37 AM   #19273
Boons's Avatar
I wonder if because I set my ride height at 5mm, and when you pick the car off the ground the spring is able to rattle around I should tighten the collars down again? I guess the spring should always have tension even if the wheels are off the ground?
Old 08-05-2013, 08:39 AM   #19274
Does anyone know off hand, if the Tamiya M05/M06 alum. rear uprights will fit a M03? It looks like the mount for the upper arm is offset, so I wasn't sure if it would work. Thanks!
Old 08-05-2013, 09:53 AM   #19275
Too much weight is transferring forward when you lift off so you could do a couple of things.
Start off lengthening your rear shocks a little. Assuming you've built them up to approximately 56mm try going .5 to 1mm longer on the rear to give yourself more droop.
Failing that I sometimes add 10g of weight to the rear which I stick just behind the servo.
www.eecc.co.uk
shawnh is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
