Old 07-06-2013, 10:48 PM   #19156
AngryRog's Avatar
Trader Rating: 19 (100%+)
A hand full of 16.9s at the Tamiya USA Track with my outlaw mini today. Quite the milestone for me.
Anger, K-Speed, Mini Mafia, NitroHouse.com
M03, M05v2 Pro, FF03-R, TA05v2, TRF419X, Roche P12
AngryRog is offline   Reply With Quote
Old 07-07-2013, 07:34 AM   #19157
It's #54182. Tamiya has some unique names for it's parts so on occasion parts can be difficult to locate. For example if you're looking for a shock shaft you'd better know it's a piston rod. This is the adjustable upper arm set.
Granpa is offline   Reply With Quote
Old 07-08-2013, 08:18 AM   #19158
Boons's Avatar
Thank you Sir!
And what spacer should I use? Should I also use the 1.5 alloy rear hubs??
Thanks again!
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 07-08-2013, 09:39 AM   #19159
Trader Rating: 18 (100%+)
Default AOC mini race
Brad/ Tony G.
How was the race this weekend?
I was looking for results on AOC site however I couldn't find them.
back9monsta is offline   Reply With Quote
Old 07-08-2013, 09:47 AM   #19160
Originally Posted by Boons View Post
Thank you Sir!
Thanks again!
I do not use any spacers on the camber links. My guess is that they are used as stiffeners and as such need to have the couplers snug to each side. Thus, every time you want to change the camber, you'll have to change the spacer. Also you'll find on many Minis, the camber links will be different lengths from side to side to achieve the same camber. The spacers have many uses so keep them. I use them internally in my shocks rather than the o-rings.
Stick with the stock 2 degree plastic units for now. I can't advise with any degree of surety whether the !.5 rear hubs would be better on carpet. I've only found them useful on low grip surfaces. Yes, I know, that sounds counterintuitive.
Old 07-08-2013, 09:55 AM   #19161
Originally Posted by back9monsta View Post
Brad/ Tony G.
Bensi, thanks again for the shock rebound tool and the shock building tips. Tried it last nite and it worked great.
On the other subject we were discussing, a softer front spring will also slow down steering as well as the other things.
Old 07-08-2013, 12:19 PM   #19162
GP,
You're Welcome. "Remember I can only tell 98% of what you need to know the other 2% will be up to you." Haha, I don't know much. Got that awesome quote from you or Chuck.
Speaking of softer springs. I know Tamiya makes 4 sets of short springs.
- Short whites with colored dots
- Short hard springs colored springs
- Short Flourescent colored springs
- Short black springs with colored dots
I've found universal spring chart from Petit but never see the short blacks listed
http://www.petitrc.com/reglages/Univ...pringChart.pdf
The short blacks have always seemed softer to me by using the finger method. What do you guys think am i crazy? How would you rate the blacks compared to the others?
Old 07-08-2013, 02:59 PM   #19163
tony gray's Avatar
Brad/ Tony G.
Cos...they aint up anywhere yet.
1 - Wayne Rabot - TOP Sabre Mini
2 - Brad Portelli - M05
3 - John Watkins - M05
tony gray is offline   Reply With Quote
Old 07-10-2013, 02:46 AM   #19164
Boons's Avatar
I have ordered 54182, so I'll have a go at setting that up when it arrives. Should I follow kit instructions? It's for high grip carpet.
On another note, I have the 3 racing alloy steering set up (M05) and I wonder which holes I should use for the steering arms. Front or back on hub and steering set?
I guess that along with potentially using the front holes combined with the drop in ride height from the 54000 shocks and short springs will mean I need to adjust the toe out?
Cheers all
Old 07-10-2013, 07:12 AM   #19165
Boons's Avatar
Almost forgot, what width Tamiya hop up alloy wheel hexes should I get?
Thanks!
Old 07-10-2013, 10:40 AM   #19166
sosidge's Avatar
Cheers all
I don't know the 3Racing parts, but I would choose the setting that is closest to the kit setting and work from there. You might need to adjust the toe links, build it and see.
Thanks!
Get the 6mm hexes, 53569, these are the same as the kit offset.
Old 07-10-2013, 12:51 PM   #19167
sosidge's Avatar
I noticed that the new Gold Edition M-05 was advertised as having new suspension, and I think I've worked out what has happened - they have simply mounted the shocks at the hingepin with M-06 style ball-pins. Might be interesting to try.
Old 07-10-2013, 06:34 PM   #19168
Originally Posted by demoman588 View Post
It seems like grandpa just cant be nice on his posts or replies.
Lol, Granpa is the single most helpful guy here.. he's old, his delivery might not be the nicest but he gets the point across. Good information too.
Too all you other "sphincter sandwich eaters".. when was the last time you offered anything helpful?
jjjheimer is offline   Reply With Quote
Old 07-10-2013, 07:58 PM   #19169
G-PA is definately a wealth of information . I never said he wasnt. All I said was he is a bit rough around the edges.lmao. I hope someday he will come to the roadrunner track in camarillo and race sometime . I think that they have the best mini class out there .
demoman588 is offline   Reply With Quote
Old 07-10-2013, 10:20 PM   #19170
Thanks!
Actually a pretty interesting ????? If I'm not mistaken, sosidge does a lot of carpet racing, so the 6mm hexes make sense. I run mainly on outdoor asphalt so usually opt for the 5mm hexes. That way if you want a wider track, just use a 1mm spacer. It gives you a little more flexibility and another tuning option.
There are times, for example, that you might find 5mm hexes in front with 6mm hexes in back are the best option. Or vice versa. If you haven't tried it, you might be surprised or not. This is a fine tuning option and you might not notice much if anything unless your base set up is pretty close
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
