Like Tree45Likes
Old 06-05-2013, 07:03 PM   #19036
I)arkness's Avatar
Grandpa are the 1016's the same as 53254's but for TCS or are they a different compound? as i saw you mentioned "old and new sgrips" but was wondering how you tell the difference?
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 06-05-2013, 10:23 PM   #19037
I think the stock numbers are the same for the old and new S-Grips. The easiest way to tell is the packaging. The old S-Grips were in a box, the new in a plastic bag. The rubber is very different with the new ones being of a much softer cpd. I think the rubber itself has more grip, but the overall performance leaves a lot to be desired. The other way to tell is by the stiffness of the sidewalls and just how the rubber feels. The old ones have a stiffer sidewall and the tire just feels harder.
The 1016s are the old S-Grips, Tamiya hard foam insert, on a special rim that was not available for purchase separately. That way the tech people could tell that you were using the Spec tire. I may be wrong here, but I think these were just used in the USA and Canada. We may be getting a new series of !016s with the new rubber, which is just freaking us out. That's why I took a little driven Mini and started to play with set ups on it.
Granpa is offline   Reply With Quote
Old 06-05-2013, 10:31 PM   #19038
monkeyracing's Avatar
1016 was the part number for the pre-mounts that were produced up until last year. The tires (53254) somehow got a different compound about 6 months ago. So, 1016 tires were built using the same part number, but they were the old, firmer compound. If you find some, please let us know! The current S Grips are amazing for a few meets, but are less so once the tread begins to wear.
The way to tell the difference is that the old ones feel like they should and the new ones feel as if they're made from gummy bears. New ones also come in the red/white/blue plastic bag. I hope they fix this soon.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 06-05-2013, 10:41 PM   #19039
edhchoe's Avatar
Trader Rating: 41 (100%+)
So are they still allowing non-premount wheel/tires at TCS or are 1028 and 1029 only choices?
edhchoe is offline   Reply With Quote
Old 06-06-2013, 02:25 AM   #19040
I)arkness's Avatar
the only reason i ask is we have the AOC event coming up and most likely plan to use s grips on the front, being run on crc carpet was thinking the older hard walls may be more suited
B.Portelli
Old 06-06-2013, 06:43 AM   #19041
MD
MD's Avatar
Trader Rating: 106 (100%+)
I have an M06. Is there an adjustable upgrade turnbuckle set to make it easier to adjust front toe. Currently, mine has the threaded rod, which came with the kit, and you have unsnap one end to adjust it. I think it would be the same for the M05. Thanks.
MD is offline   Reply With Quote
Old 06-06-2013, 08:29 AM   #19042
You're probably right. The new S-Grips softer sidewall just can't be an advantage, especially on carpet or other hi-grip surfaces. The new ones are easily a second slower where I race on the same car. Plus, the car became very uncomfortable to drive.
Old 06-06-2013, 05:20 PM   #19043
Be happy we don't have to deal with this! The picture is just a corner of a setup sheet for an F1 car from 2012.
Stab it and steer.
Old 06-07-2013, 12:15 AM   #19044
caltek1's Avatar
Trader Rating: 33 (100%+)
Perhaps then I should hold onto my S grips in cardboard packaging then, if they are better than the new plastic packaged ones.
I have always found on carpet the M grips a better tyre than the S grip. Perhaps that just comes back to my driving style.
caltek1 is offline   Reply With Quote
Old 06-08-2013, 10:14 AM   #19045
What about the m-grips? Did they change the compound on them?
jha07 is offline   Reply With Quote
Old 06-08-2013, 10:17 AM   #19046
Has anyone tried fitting a JCW coupe on a M03 chassis? Just wondering how well it fits.
Old 06-08-2013, 11:11 AM   #19047
spring71's Avatar
Smile
TCS Spec Mini Premounts #1016 is back in stock.
http://www.tqrcracing.com/shop/produ...w.asp?p_id=976
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 06-08-2013, 07:36 PM   #19048
It fits with no problems. Be sure to reinforce the front splitter cause if you bend it the handling goes away. The wing is a little tricky, just don't leave out the reinforcement pieces.
Old 06-08-2013, 10:22 PM   #19049
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
Hello all mini guys I am selling the majority (not all ) of my mini stuff. And I have lots of it! What ever you need I more then likely have it from parts to full cars. If you want me to build a full car just let me know. It will be full race ready minus electronics and motor. In have several items that are discontinued just let me know what you need and I will give you a price. I am selling it very much lower then u can by on the web for. Tires, cars, parts, a few body's some esc's with silver can set ups etc. who and for the TCS guys I have several sets of 1-4 run premounted s grips. Good luck all talk to you later
Why do people park in a driveway but then drive in a parkway?
SirSwiftAlot is offline   Reply With Quote
Old 06-09-2013, 08:43 AM   #19050
FYI, Thanks.
Are these 1016 because they've switched back to grey wheels, or has the tire compound been sorted out?
Stab it and steer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
eyekenspel, KA2AEV
