Old 05-04-2013, 12:44 PM   #18796
Rolology's Avatar
Thumbs up TCS Mini racing in Oshkosh - Starts this Wednesday
Spec racing starts this Wednesday night....is your Mini ready?
Check out the Revolutions Raceway website (RevolutionRaceway(dot)com) for more info!
Rolology is offline   Reply With Quote
Old 05-04-2013, 08:57 PM   #18797
One of the new Coupe bodies was sent by mistake. It was going to be a hassle to correct the error, so decided to paint it instead. There are a ton of stickers, which works to my benefit cause there were enough of them that I was able to cover most of the "boo boos". Actually, when all the drips and runs were covered with the stickers, it looked pretty good. The wing was a bit difficult to cut out, but made sense after assembling and mounting. The little wing pieces that fit under the wing were actually reinforcements rather than an aero piece. Those definitely should be fitted.
I'd driven a well set up M03 with this body and thought it was just okay. The car was a little "twitchy" when it was compared to the original BMW body. The body behaved the same way on my M03LWB, but since it was my car, I could change the set up a bit. The first change was to go to a softer front spring to tone down the corner turn in. Second was to install the heavy rear roll bar to replace the original softer one to compensate a bit for the soft front spring. A couple of little ride height adjustments and we were there.
Just one suggestion tho and that is to reinforce the front "splitter". I have a feeling bending or breaking that is going to change the handling.
Granpa is offline   Reply With Quote
Old 05-06-2013, 08:56 AM   #18798
niznai's Avatar
Ahem. What are we talking about here? What coupe bodies?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-06-2013, 11:31 AM   #18799
My apologies, but being a TCS racer, I only run the Tamiya bodies. That post was in reference to the "new" Mini JCW Coupe, part # 51489. This body fits the 239mm chassis.
My favorite body the BMW Mini Cooper has been discontinued and have tried a number of other Tamiya bodies for a LWB chassis. This one seems to be the best one at the venues I frequent.
Hope this clears up the matter for you.
Old 05-07-2013, 04:49 AM   #18800
niznai's Avatar
Merci.
Team Greasy Weasel
Old 05-07-2013, 05:06 PM   #18801
Trader Rating: 72 (100%+)
I'm running an M-05M.
I happened to score a good deal on a set of the TRF Mini dampers NIB with all the pistons, springs, etc.
Which of the pistons, springs and what weight oil is the hot ticket?
I'm running on a tight, small parking lot track (very low grip asphalt).
Your recommendations would be very much appreciated.
waswadener is offline   Reply With Quote
Old 05-07-2013, 07:17 PM   #18802
Core Creations's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Core Creations
Thought I read the BMW Cooper was returning but as a new Tamiya "heavy duty" body. Or are you talking about the original long Cooper Grandpa?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 05-07-2013, 08:21 PM   #18803
Yeah, I was referring to the original BMW Cooper. Just the best of the LWB bodies until now. The JCW Coupe may make me change my mind about which is the best body though. The big thing about this body seems to be the amount of steering without making the back end going crazy.
Just posted my experiences with the Coupe so that people don't dismiss this "ugly duckling". I think this body is worth a good look cause it has a lot of desirable characteristics. Set up is a little different for this body compared to the old body.
Old 05-07-2013, 08:55 PM   #18804
First, the springs that came with the shocks are too stiff for your track layout and traction level. Get some softer springs like the #53333 short TC springs. If you use the soft springs, use the rear roll bar
Insert enough spacers under the piston so the shocks are 56.5 to 57mm in overall length. Use the 3 hole pistons and start with the equivalent of Losi 40 or Tamiya 400. Associated oil, I'm told, is thicker so you need to use 25 or 30 wt.
Build the shocks with less than 2mm of rebound and have an even amount of rebound for each shock. The Tamiya air removal pump is a worthwhile investment and saves a ton of time in "bleeding" the air out.
This is just a starting point and I'm not claiming this is the optimum set up for your track. Let's face it, if the rules at your track is "open" tires, 75% of a good set up starts with the right tires. If your track is open tire start with some Sweep Premounts-----33s in front and 25s in the rear. There are tires with more grip out there, but Sweeps are relatively inexpensive and are a good starting out tire.
Hope this helps. Again, just trying to get you started in the right direction.
Old 05-07-2013, 09:14 PM   #18805
caltek1's Avatar
Trader Rating: 33 (100%+)
Grandpa,
I have used the JCW Coupe and I agree the car has more steering than the normal LWB BMW Cooper body. I also had to revise my car setup to suit the tyres and this body combination.
To strengthen the front, I used the Yeah racing goop, (which is similar to shoe goo) and gyprock,(plasterboard), tape, used to aid in sealing the joins between the plasterboard sheets. It is of mesh construction and has a sticky coating. This will support the body and the shoe goo and make the front of the car stronger.
I use this on all my mini bodies, front and rear and makes the car less prone to cracking. I use this above the wheel arches as well.
When I have more time I will post a picture or two.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 05-08-2013, 05:00 PM   #18806
KA2AEV's Avatar
Guys just wanted to update on the work we've done on the mini
We replaced the Gear Diff with the Ball Diff like you guys said to
We even invested in the CV Joints as well as the upgraded aluminum steering components, We even splurged and got the front Aluminum Damper
stay and the Servo Saver
My Driver took it out on our secret testing facility track and ran
a bunch of laps and he was really pleased with the increased speed and
handling. It held its speed in the cornering and he said that the sloppyness
from the steering was gone now
So looks like we have one competitive Mini to run now!
Thanks All for the Help and Suggestions!!!
Mike
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 05-08-2013, 08:52 PM   #18807
Trader Rating: 32 (100%+)
Just started racing mini this year and I'm having a blast. I have a m06 as was thinking of getting a front wheel drive mini? Is the m03 still competitive or should I just get a m05? I have an alfa mito all painted up just need to get the chassis.
v_squared is offline   Reply With Quote
Old 05-08-2013, 09:39 PM   #18808
monkeyracing's Avatar
M03 is still very competitive. It's a toss up between it and the 05. Really comes down to preference.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 05-08-2013, 11:10 PM   #18809
Oh wait for it.....wait for it.....
Sydewynder is offline   Reply With Quote
Old 05-08-2013, 11:22 PM   #18810
If you've been reading this thread for awhile, you'll know that I prefer the M03 over the 05 except on the hi-grip surfaces. Won't bore anyone with the reasons cause I've posted them several times.
The Alfa Mito body is not the best body for the LWB chassis. The esthetics are great, but the handling is not. I gave mine away, no actually threw it in the trash, but a fellow racer said he'd take it if I was trash canning it. He doesn't use it now either cause he couldn't get it to work either. Incidentally, he is a Nationals A Main caliber racer. If you're running on carpet it might be okay though.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
SEO by vBSEO 3.5.0
