Old 03-02-2013, 01:41 PM   #18526
Swampracer's Avatar
Trader Rating: 67 (99%+)
Default Hey
Thanks for the info Aaron, so go with the harder bar (silver) instead of the black?
Cheers
Swampracer is offline   Reply With Quote
Old 03-02-2013, 01:44 PM   #18527
Swampracer's Avatar
Default Check out the paint
Check out the blingy paint!! I'll make sure the diff is tight as well. I'm running the standard gear diff with putty.
Are you guys running gear diff's or locked ball diff's?
Greg G
Old 03-02-2013, 03:46 PM   #18528
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Cheers
Hey Greg, yep id recommend going the stiffest bar straight away. i found the car almost loose initially, but concentrate on camber and traction compound on the rear tires and it will get better.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 03-02-2013, 07:16 PM   #18529
I got a question for m03 racers. Does anyone know the kimbrough servo saver that works for the m03? I run an associated XP servo so hopefully it works with that.
Dirt_McGirt is offline   Reply With Quote
Old 03-02-2013, 10:58 PM   #18530
monkeyracing's Avatar
I've used the Kimbrough large and x-large on my M03. You will have to trim the corners back a little for clearance and drill your own holes for ballstuds. They're damn near indestructible once they're installed, though. It will come with 3 adaptors to suit pretty much any servo. Red lines and dots show roughly where to modify it.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 03-03-2013, 08:01 AM   #18531
Awesome! Thank you so much monkey racing. The diagram is perfect, thank you so much for sharing that.
Old 03-03-2013, 08:13 AM   #18532
muahdib4's Avatar
Send a message via Yahoo to muahdib4
Anyone here run their minis on dirt, rally stuff? Trying to find a way to keep dirt of it as much as possible. I have a DF03ra and use a dark impact body as a cover to keep stuff out. Gonna build an M05 specifically for rally and a new one for carpet though probably won't give up my M03R entirely.
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 03-03-2013, 03:03 PM   #18533
Just thought I'd pass on some info to all TA03 ball diff fans. The diffs in a couple of my M03 Minis were starting to be a little "loose" so rebuilds were done. Both diffs were in their respective chassis for many months with no attention and were still smooth, but were freer than optimum.
Tore both down and put the gears and diff parts in disc brake cleaner, but the antiwear grease just did not clean off as well as I'd like. Then Simple green and water was tried and it was way better. I'm fortunate to have a good strong ultra sonic cleaner, so did have to "soak" the parts.
Diff #1 was reassembled and came out okay, but was still on the loose side. Diff #2 was as loose as it was before the rebuild. WTF, these had always rebuilt well. Cleaned all the parts, rebuilt again with the same results. Tore them apart again and discovered that the Belleville or cone washers were flattened a bit , so had lost their "spring" capabilities, which, of course, made the diff action lighter.
Conclusion: Might be better to replace the washers when rebuilding.
Granpa is offline   Reply With Quote
Old 03-04-2013, 03:15 PM   #18534
Trader Rating: 306 (100%+)
About start building my M05. What size bearing can I replace the stock plastic?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 03-04-2013, 03:33 PM   #18535
fresnojay's Avatar
Jmoneym, If you plan on replacing any of the uprights for the aluminum ones dont bother buy bearing for the plastic uprights as the aluminum ones require a different size. But if you plan on sticking with the plastic uprights for a good while you will need 5x11's for them, 2 per upright.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 03-04-2013, 03:43 PM   #18536
Jason
Jermaine Mitchell
Mercenary Racer
Old 03-04-2013, 07:20 PM   #18537
Csaari77's Avatar
Trader Rating: 34 (100%+)
I just picked up a 05 for the upcoming outdoor season. I'm going to use a Kimbrough 201 servo saver and I was wonder what hole you guys are using on the saver?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 03-05-2013, 06:16 AM   #18538
big kid 37's Avatar
You will need 12, 5X11 bearins an 6, 5X8 bearings. Just built 3 M05's.
Team C TS2TE SC, TC02 Evo Buggy
FT SC10, FT T4,SC10 4X4.
Traxxas Slash, Arrma Fury
Axial Honcho.
Losi TEN 4x4 SCTE
big kid 37 is offline   Reply With Quote
Old 03-05-2013, 06:20 AM   #18539
Thanks just ordered a Tamiya M05 bearing kit.
Jermaine Mitchell
Mercenary Racer
Old 03-06-2013, 06:29 PM   #18540
Jmoney, also look into threaded shocks, 3racing are fine if you dont care about tcs legal
I also like the aluminum steering assemble & ball diff.
Let me know if you need any other help I will be at the track sunday
Nick.
Shortbusallstar is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
