Tamiya mini cooper
This may have been posted before, but has anyone tried a spool???? What are the driving characteristics and how durable are they?????
When you "stuff" a gear diff, how tightly do you pack it???? I've always just shimmed mine and my one attempt to "stuff" a gear diff was a disaster. Took me hours to clean it all up. What do you use?????
Who has the best oil filled gear diff???? Presently I have the SpecR unit sitting on my bench, but really have some misgivings about how fragile the gears look. It still hasn't seen the inside of my Outlaw Mini.
Outlaw Mini. Definition. One that does not comply with TCS Rules.
Alan
I replaced all the stock items with the 3racing steering system and a custom made carbon support for between the steering system works great
I've noticed on the M05 that the steering is sloppy enough that it doesn't fully recenter after turning in either direction. Tis is a bit annoying when you are trying to center the servo, but doesn't seem to be a problem when driving. Just don't let go of the wheel and expect it to drive straight: steer it there, instead.
I did also have a problem with one of the bell cranks bending and causing the steering to bind. In my case, it prevented full steering travel, and caused the steering to fail to recenter when it was far off center.
Alan
Alan
I am going to suggest that you lose the stock steering linkages and replace it with one of the aluminum ones. If you insist on staying with the stock linkages, do not shim it. The tighter it is, the easier it will bend. Even the slightest bend in one of the bell cranks will make the steering go crazy. It's almost always the right bell crank.
Play or slop in the steering is hardly ever a major problem in a Mini, but then, I've never seen how much play you have in your steering.
I want to clarify: I don't have a problem with the play in the steering... I just have play in my steering. I was only trying to convey to someone else that if they just have a little play in their steering, maybe it isn't a problem.
Alan
R/C Tech Elite Member
I've been experimenting with the floppy tires. Strapping them with a strip of duct tape (2cm x 19cm) seems to work pretty well at creating a more solid base. They sure do push out on the sides though, as the sidewalls are weaker than the foams. Haven't tried using CA on the inside of the sidewalls yet. Any advice on how to do that without gluing my hand to my glasses/workbench/cat?
BTW: Haven't done any road testing at this point. So this may still turn out badly.
+ YouTube Video | |
Had a great day of on road racing with the M05. I ran a 20 lap race with the fastes time I have ever ran a hot lp at 13.177. getting faster just need to keep tuningI'll get there.
Just lay the tire on the workbench and squeeze on the inside sidewall. You may have to use something to smear it to the right places. An allen wrench works well for this-----you know, the ones that came in the kit that you never used, but didn't throw away either.
Thin tire glue doesn't work well, but the regular, which is much thicker does. Any thick cyano should work. Using a Zip kicker might not be a good idea cause it does make the cyano very brittle. Just waiting a few minutes for the glue to set on one side so you can do the other is just common sense.
Just a weekend update.
I changed the sways and springs to yellow front, blue rear, stif rear bar soft front. I reset ride height with the back a little lower then the front, and the front arms at level. I also had too much front camber (3*) and have brought that down to 1*.
Traction roll virtually went away. The issue now seems to be heat in the rear tires. After 5-6 min they warm up enough to pick up all kinds of garbage on the track, which makes the back end really squirrely the rest of the run. On a TC, collection garbage on the tires either meant you were spending way too much time off line, and usually that your setup was off and you were overworking the tires. Normally I would consider less rear toe, but only at 2* now. I am not sure if I should try less toe on the rear or look somewhere else.
When mounting new tires, do most glue the foam inserts to the tire or not ?
So I have got the itch for possibly getting a mini. Since there are so many different versions of this car, which one seems to be the one majority of people are running? M05 or M06?
The class looks super fun and I just got a Tamiya 417 so I am looking to get a second class going that will be fun so I am not sitting around the majority of the day.
Double post
