Like Tree137Likes
Old 01-09-2013, 06:15 PM   #18166
Is there a big difference in performance running the double cvd's as oposed to the single tamiya's ?
thetweeker is offline   Reply With Quote
Old 01-09-2013, 06:35 PM   #18167
Yes, less chatter & wear at full lock ,and less wheel vibrations when turning.... As far as laptimes, not so much difference there, at least at my club.... Most, if not all Amain winners use the tamiya drives.....
bertrandsv87 is online now   Reply With Quote
Old 01-09-2013, 07:53 PM   #18168
caltek1's Avatar
Trader Rating: 35 (100%+)
We have found the DCJ's less reliable than the normal cvd's. They usually fail in finals or qualifying at big events. This maybe due to the torque generated by the HW 13T system we are using in combination with tight oil gear diffs.
Due to others having this type of issue I have never fitted them to my mini's. However each to there own. I have found using the tamiya universals the best and I do not use the pin and grub screw to retain. I use a shorter pin and alloy cover made by TOP . This retans the pin and prevents the pin from moving and jamming in the knuckle. Certainly not TCS legal although I believe Tamiya may have them as a hop up.
caltek1 is offline   Reply With Quote
Old 01-09-2013, 07:59 PM   #18169
monkeyracing's Avatar
Do you have any part numbers or links for those, Cal? Even when I thread lock them, the grub screws back out.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-09-2013, 08:36 PM   #18170
Originally Posted by orcadigital View Post
I don't think anyone is stalking you. You just post questionable advice and get very defensive/offensive when someone disagrees...and you do it all over rctech.
Granpa, regarding traction rolling, I very much like the idea of fixing it without CA. I have some things to try (shock/spring/sway bar tweaks) that will be first, but was wondering about tires. Spec tire out our local track is Sweep, and we can run 25's, 33's or 40's. I am running 40's all around on my M05 (high traction carpet, club level, not national level high grip) and the thing turns like a monster (almost 12th scale twitchy). Even backing off to full rear tire additive and none on the front, once the fronts warm up, it wants to roll. Is some of this just a factor in using slicks that I need to work around? I am not sure I want to run staggered compounds front to rear, but with the spring suggestions (I run hard front, soft rear like in TC currently which seems to possibly be backwards), I am not sure what tires and which side of the car to start with.
Someone posted that just changing springs is not enough, but the common setup advice is always to change one thing at a time. My experience is TC and pan car, so this mini is all new to me. I am not worried about top speed, and have little inclination to go crazy wrenching on it (it is a stress reliever class), I just want to make it a little less rolly polly.
I currently have the stiff front sway bar on it, blue front, red rear springs, 35wt AE oil, stock camber and toe, ride height is lower arms level, spec R oil filled gear diff with 100k in it (TC's ruined me for ball diffs). Slowing down steering speed and travel has helped some, stiffening the front has really had little to no effect (originally no swaybar and yellow front springs). I know I am falling into the TC setup trap of stiffening the front, which is why I am asking and my lack of mini knowledge.
Thanks!
Just some random comments on your post, which are merely that and not criticisms. Sweep premounts are a very nice tire. 40 fronts and 33 rears or 33s all around work pretty well under most track conditions. The adage of only changing one thing at a time is only true if your car is only true if your car is close to the right set up and you're looking to improve it.
These are just opinions only and may be off the mark at your track. Two of the major causes of traction rolling involve the tires. The first is a tire that is too grippy for the track. The second is that the sidewall on the tire is too soft and the tire rolls under and trips the car. Short of building a new set of tires with different inserts, the easiest way to cure this is with cyano. With the Sweep premounts, you almost always have to cyano the sidewalls up to and even slightly over on to the contact surface of the tire. They use a medium, 4.5mm insert, which will allow the tire to tuck under.
Contrary to popular belief, traction roll is not caused by by the car lean into a corner. Except in extreme conditions, this is not the case. I'll bet that when you put the front sway bar on it and the stiff blue springs, the car flipped so fast you couldn't even blink. When you drive your real car, the one you drive to the track, these things occur when you drive around a corner. Entering the corner, your car will lean, then take a set, then rip thru the corner. What happens with stiff front set up and roll bars is that it takes a set too quick and too harsh and over your car goes. So, you should go to a softer spring and shock combo and maybe lose the front roll bar. This will slow down the front end action and ease some of the traction roll. How soft a spring, what shock oil, don't know, but if you understand what's happening you'll be able to figure it out. Typically tho, I usually start with 40 wt Losi oil and the yellow springs from the #53333 Spring set. Usually the other types of Mini springs are way too stiff.
The rear of the car is a little different. I like to use a little stiffer set up in back to let the rotate a little quicker. You will hardly ever see a car roll on corner exit which would be caused by the rear of the car. This post is getting a little long so won't get into all the whys and wherefores. Generally you can get by with one step stiffer on the rear springs and a light roll bar.
Hope this was helpful and good luck. Mini racing is a blast as long as you're not traction rolling.
Granpa is offline   Reply With Quote
Old 01-09-2013, 09:33 PM   #18171
caltek1's Avatar
Jim ,
TOP part No. PO-DT1007TI. The TI at the end refers to the colour of the covers. They also come in red. There are 4 in a packet with pins.
They work a treat. I currently have the titanium ones on my car.
Old 01-09-2013, 10:10 PM   #18172
I thought that ecs's and dcj's were tougher than cvd's. Maybe the ones they made for the minis were not. In any case I am glad I had the foresight to grind down losi lcd drives, which are ten times tougher than cvd's for sure. I have not even come close to scratching One yet...
On the traction rolling issue I agree with Granpa about going softer in the front End, but I also found out that the rear can also play a roll in it if you have it also soft with thick oil. Upon corner entry, the front will eventually squat down until it can't go down no more, so the energy will need to go somewhere , and that's when a soft rear can be helpful, but it cannot squat too fast either, hence the need for thick oil. The thick oil front and rear will also keep the Car squated for a longer period around the turn, and if you still went too fast you will have time to steer to avoid traction rolling instead of being on your lid suddenly... It might not be the best Car in the chicanes though, since you lose a little bit transitioning from side to side....
Old 01-09-2013, 10:22 PM   #18173
ruebiracer's Avatar
Granpa,
your posts are never long enough, because you donīt talk about unnecessary things but arguments to explain your thoughts!
This post was a whole "how to" setup a mini and gave me the start setting for my M03 rebuild!
By the way, I received my new chassis parts (50792), and I was a little wondering: The grey was slightly darker than the original one, so I had to use for the look also the new rear halves.
Second thing: The new chassis is noticeably heavier than the old ones, so I put the rear halves on the scale for a comparison:
Old, light grey rear halves: 33gr.
new, dark grey rear halves: 42gr.
Front chassis section i could not compare, as I already scrapped it, but it should be even more difference.
So, not the parts to build a ultra-lightweight M03!
If you look at the effort some guys are trying to reduce weight on some items, using the old light chassis is rather simple...
Anyway, the new version feels slightly stiffer, so I guess itīs a durability fix from Tamiya...
BR,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 01-10-2013, 03:59 AM   #18174
Originally Posted by bertrandsv87 View Post
By the way, any videos of your minis Racing ??????
Yes
http://m.youtube.com/watch?v=eF3Lq-uLot0
http://m.youtube.com/watch?v=qRXjodXY7os
Our old track 1st vid was a club race A final , 2nd was M auto race with about 40 minis
Good old times ;-D
sidecarphil1 is offline   Reply With Quote
Old 01-10-2013, 05:34 AM   #18175
orcadigital's Avatar
Trader Rating: 61 (100%+)
Granpa,
The post is not too long, and you won't offend me in the slightest. I am asking for help because I know I got it wrong.
From what I have seen, the M06's seem to have much less in the way of traction roll issues, even with the softer 33's, so gut feeling says that the tire isn't too sticky, or at least that there is a work around that might not include CA (that is really the last option I want to try). I could be wrong as we are comparing apples and oranges too though. There are also some M03's that traction roll everywhere and others that do not...some running the 33's.
Oddly on my 1:1 car, I run much stiffer rear springs then front, but never equated the same as my RC cars all run the other way. My 1:1 car also is rear engine/rwd though and did not seem to be a fair comparison.
I see a lot of people discussing putting in ~35g of weight in the front bumper. This would seem to be to get more front traction (over the drive wheels). Knowing that I have more then enough steering, even under power (there is an on power push, but it is fairly minor), my gut would say weight would be better spent in the rear. Would weight if mounted low enough have any positive effect on traction rolling that might help? Front or rear?
Thanks!
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 01-10-2013, 06:53 AM   #18176
rimracker's Avatar
Trader Rating: 14 (100%+)
Default inserts and tires
Wondering if anyone can comment on the gluing of inserts. I did a search on this thread and found some people say it is not needed. I believe it was also touched on several pages back but can't seem to find it.
Tamiya has different inserts and lots of tires can anybody put them in some sort of order soft to firm. I am trying to stay Tamiya in case I have a chance to do a TCS race. The best descriptions I can seem to find is " to obtain different driving and steering response ". I suppose I can start buying and try them out for myself, might take a while though.
Tires
Tamiya (#50568) M-Chassis Radial Tires http://www.rcmart.com/tamiya-50568-m...?cPath=35_1386
Tamiya (#50683) M-Chassis 60D Radial Tires http://www.rcmart.com/tamiya-50683-m...?cPath=35_1386
Tamiya (#50684) M-Chassis 60D M-Grip Radial Tires http://www.rcmart.com/tamiya-50684-m...?cPath=35_1386
Tamiya (#53215) M-Chassis Slicks http://www.rcmart.com/tamiya-53215-m...?cPath=35_1386
Tamiya (#53222) M-Chassis Super Slicks http://www.rcmart.com/tamiya-53222-m...?cPath=35_1386
Tamiya (#53340) 60D Reinforced Tires TYPE-A http://www.rcmart.com/tamiya-53340-r...?cPath=35_1386
Tamiya (#54216) 60D Reinforced Tires Type B http://www.rcmart.com/tamiya-54216-r...?cPath=35_1386
Tamiya (#53254) M-CHS.60D Super Grip Radial Tires http://www.rcmart.com/tamiya-53254-m...tml?cPath=35_1
Inserts
Tamiya (#50686) M-Chassis 60D Inner Sponge Set http://www.rcmart.com/tamiya-50686-m...h=595_744_1389
Tamiya (#53204) M-Chassis Inner Sponge http://www.rcmart.com/tamiya-53204-m...h=595_744_1389
Tamiya (#53255) M-Chassis 60D inner sponge hard http://www.rcmart.com/tamiya-53255-m...h=595_744_1389
rimracker is offline   Reply With Quote
Old 01-10-2013, 08:17 AM   #18177
Thanx to those who were complimentary, but I do have a tendency to ramble on. Rather than quoting anyone I'll just answer some of the questions. Again, these are just my opinions and might not be correct for the conditions at your track.
If you plan on doing the TCS races, the information requested on Tamiya tires is unnecessary. The TCS series uses a Spec tire. Actually a couple, but I haven't looked at the rules in detail for this year yet.
Inserts, except for the molded ones, should all be glued. Unfortunately, some of the #1016 have the inserts separate and the tire develop soft spots. Contact cement works best. Never use cyano cause it creates hard lumps, which is worse than having soft spots created by separated inserts.
You add weight to the front of the car primarily to get better turn in. It's value in maintaining traction, especially during acceleration is questionable. Weight is added to the rear, however, to maintain traction on corner entry. Adding weight is really for adjusting the cars behavior on corner entry and I don't see it's value for other reasons.
Never have weighed the chassis, but if the dark grey ones are heavier, that may be a good thing. You have to add weight to the rear of the car, if you want to have good steering into a corner. Usually, a Mini that has the front end right will need 28 to 56g of weight in the tail. Other things you can do to maintain a good front end on your set up is to drop the rear end lower, slow the servo down in the Tx, change the steering curve, carry a touch of throttle into the corner. Stiff springs in the front will kill aggressive steering which may be what you need at your track, but I like as much steering as I can get and try to work on the back of the car to control it.
As soon as I see an M06, I tend to walk as quickly as possible in the opposite direction. I bought one like all my compadres, but had the good sense to never build it. After having it for some time, I first tried to sell it for $75, then $50, then I tried to give it away with no takers. Finally, out of pity, someone took it for free to do me a favor. And yes, I know at certain carpet tracks, it may be quick, but it's just not not for me. I never cared for Phylis Diller either.
Old 01-10-2013, 10:42 AM   #18178
Hey guys , some advice , rebuilt my M05 today for a big race next month
Fitted some adjustable upper arms , and want to know whatmyou set the camber at ??
Also the car has a tendancy to pull right when i pull full throttle from a standing start , all bearings are good and everything is free and well oiled , on the straight it goes straight
Any ideas ?? I am running a 3racing gear diff with 500,000 oil in there
Thanks Phil
Any ideas for set ups on M-grips ???
Old 01-10-2013, 10:51 AM   #18179
More of a Rip Taylor fan?
Thanks for the PNs, Cal. I was thinking about heat shrink as a next step.
Stab it and steer.
Old 01-10-2013, 12:31 PM   #18180
Core Creations's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to Core Creations
Exclamation
Grandpa..sorry..I didn't see your response a while back. This thread has been moving! I am back and getting my minis up to snuff. I would really really like to make Nationals again. There isn't anything like Tamiyas USA track!!
I've spent some time disassembling rebuilding my cars and looking very close at anything that can squeeze any more performance out, but honestly...the most performance to gained is track time...more and more track time. I'm debating on bringing my beast M03 out of retirement...have to see. TCS season is coming up quick!!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Speed Chaser
