Like Tree101Likes
Old 12-13-2012, 02:01 PM   #17986
monkeyracing's Avatar
Happy birthday, Bob!
I feel very much the same way. I may have gotten really sick a few years ago and I'm pretty messed up now, but I still get to play with toy cars! Life is good.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 12-13-2012, 10:03 PM   #17987
durtbag's Avatar
Thumbs down 60D Super Grips
Seems to be a world wide shortage. Are these now NLA?
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 12-13-2012, 10:29 PM   #17988
Nope. Still a current part. The last batch we saw were ultra sticky, too. Maybe they're between production runs?
Stab it and steer.
Old 12-13-2012, 10:57 PM   #17989
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
http://www.rc-mushroom.com/product_i...l-tire-p-16889
Blitzrockey is offline   Reply With Quote
Old 12-14-2012, 03:37 AM   #17990
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Belated Happy Birthday Bob.
Is there any cake left, cause I didn't get my slice yet.
marcos graveyar is offline   Reply With Quote
Old 12-14-2012, 08:16 AM   #17991
durtbag's Avatar
Originally Posted by Blitzrockey View Post
thanks Cale! I actually put in an order last night with them. Most HK stores seem to be out right now.
Terence
Old 12-14-2012, 08:21 AM   #17992
The new S-Grips we've seen have been packaged in a bag rather than a box. These were of a softer rubber cpd, and the first impression was that they would be a "grippier" tire. That may be true, but overall, the tire is not as good as the old. They just did not seem to work and are very prone to rolling. Lap times were 0.5 to 1.0 sec. slower than the old #1016 Spec S-Grip premounts.
After some experimentation, using the conventional "tricks", they are a little better and we've managed to lessen the "mushy" handling. Of course, this makes them illegal for TCS racing. Hopefully, when the new #1016 premounts arrive, it will be with the old cpd rubber.
The problem seems to be the softer rubber cpd makes the sidewalls too soft. It makes for traction rolling and a "mushy" feel" to the car. We've tried various solutions like stiffer inserts, cyanoing the sidewalls, double stuffs, building up the wheel between the center ribs, etc, which helped, but the older premounts were still quicker. Most of the solutions tried are illegal for TCS racing.
Granpa is offline   Reply With Quote
Old 12-14-2012, 10:00 AM   #17993
"I could set the building on fire."
Stab it and steer.
Old 12-14-2012, 10:44 AM   #17994
I was just going to post that. Happy belated, Gramps!
jjjheimer is offline   Reply With Quote
Old 12-14-2012, 11:45 AM   #17995
Thank you all, but the post was only to let you know that life is good. I do appreciate and enjoy each day more than before, take less for granted, appreciate each friend and kind word or act more than when i was younger.
Also, that careful construction and attention to detail in your set ups can keep you competitive. Don't win many races these days, but the lap times haven't slipped much if any. What's happened is that the guys are getting faster and their set ups are better. Hopefully, I had a bit to do with that cause I've shared much info over the years and have posted quite a bit.
Unfortunately, this has ruffled a few feathers, which is okay. A little controversy is good for the discussion. However, one must acknowledge that someone having a differing opinion, does not make him your mortal enemy. Really, there is more than one "good" way to build a diff, or shock length, or set up, or combination of spring and shock oil, etc. I will admit to getting irritated when someone pontificates. But that's a failing of mine and needs a bit of attention.
Old 12-15-2012, 12:31 AM   #17996
I'm looking to fit a foam front bumper to my m03.
Would an aftermarket m05 one fit.
I'm not sure if the mounting points etc are the same, they look pretty similar in the photos
markrobinson is offline   Reply With Quote
Old 12-15-2012, 08:03 AM   #17997
toast.'s Avatar
Happy Belated Bday - i dont post much but i've been silently following your RC wisdom and wanted to say "Thanks!" you are a great help.
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 12-15-2012, 10:06 AM   #17998
purple haze's Avatar
i was under the impression that the premounts had been discontinued . not true ?
www.karz.ca
www.carcar.ca
www.rcgears.net
purple haze is offline   Reply With Quote
Old 12-15-2012, 10:42 AM   #17999
Hello first time sorry for my bad english, I'm from Switzerland.
I want to ask her how the M05 Gear differential cone filled with oil without all this boils?
JiaBee is offline   Reply With Quote
Old 12-15-2012, 11:07 AM   #18000
Would an aftermarket m05 one fit?
Mounting points are different. Best bet is to base the bumper off of the M03 part and add to it.
They seem to make a batch about once per year. I wish they came on some heinously bright pink/yellow/orange wheels. The grey is so somber.
If you are referring to the 3Racing differential, it uses a rubber seal and O rings to keep the oil in. While constructing the differential, some air space is left to allow for expansion.
Stab it and steer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
