Like Tree100Likes
Old 11-20-2012, 07:06 AM   #17851
rcjunky1's Avatar
High end esc's have lower resistance, noticeable, maybe not, but that's the difference. Is it worth getting the fx pro over the fx, maybe not, but I imagine some could notice, not me.
What shims do people put in there diffs? My s-limited kit should be in this week and I already have everything else ready to go for it except the motor plate and long steering link to all match, so I just need the shims and I should be building this weekend. What size are they, or better yet, a part number.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 11-20-2012, 10:04 AM   #17852
Originally Posted by Granpa View Post
Actually, this is part of a larger discussion of cheaper electronics vs. higher end electronics. For most of us, our driving skills are not great enough to notice much difference. Your lap times will not be noticeably different when using a lower end esc compared to a high end esc like the KO or LRP quantum.
The primary reason for using higher end electronics is for reliability and consistency of performance. Most of the electronics in the Minis in my stable have electronics that are many years old, but still are trouble free. Yes, hi end stuff fails, but not at the same rate as "cheap" stuff.
How about the ESC that the kit comes with? Is it even worth using? I'm only going to be running a silver can. I have a spare mamba max pro I could use, but thought that would be overkill for a silvercan.
jha07 is offline   Reply With Quote
Old 11-20-2012, 11:12 AM   #17853
monkeyracing's Avatar
The kit ESC will do just fine. Unless you're one of the worlds most elite drivers, you'll never notice the difference. The only thing I've ever found lacking in the kit ESC is drag braking, but brakes are for chumps anyway.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 11-20-2012, 01:12 PM   #17854
Whether you use your mamba max pro or your kit esc sorta depends. Have no idea what a mamba max pro is, but am going to assume it's a really good esc. My logic is this. If you have no immediate or near term plans for the mamba, by all means use it in your Mini. If however, your Mini is just meant for occasional bashing and will not be raced, use the kit esc. Really it just sorta depends.
A lot of people seem feel that just because the Mini is cheap to purchase, it's a waste to put good "stuff" in it. "Good stuff" is just "good stuff". It just makes things easier and makes going racing a pleasure instead of being a frustrating experience where you were chasing down "problems".
Granpa is offline   Reply With Quote
Old 11-20-2012, 11:23 PM   #17855
Hello everyone I am thinking of trying the shorty lipos in the mini making the hole of the chassis squeare and using the tamiya part 54224, but I need that someone helps me and tell me the distance between the suports to know if I can have the lipo inside with the bullet holes in the outside.
Kind regards
jimjav is offline   Reply With Quote
Old 11-20-2012, 11:55 PM   #17856
Maximum amps the 540 silvercan brush can push is 80A. TEU 104 is 60A. LRP QC3 is 110A and VFS1 is 120A. I might be wrong.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 11-21-2012, 01:07 AM   #17857
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Originally Posted by rcjunky1 View Post
What shims do people put in there diffs? I just need the shims and I should be building this weekend. What size are they, or better yet, a part number.
They are Tamiya Part No. 12300010
marcos graveyar is offline   Reply With Quote
Old 11-21-2012, 12:15 PM   #17858
rcjunky1's Avatar
Thanks, but it appears that part is discontinued, does anyone know what size they are? They're called 9mm washer, but no dimension can possibly be 9mm...
Team Durango Canada
Old 11-21-2012, 01:50 PM   #17859
c-lyon's Avatar
If these are the big ones inside the stock diff, mine measure about 14.8 x 9.6 x .3mm.
c-lyon is offline   Reply With Quote
Old 11-22-2012, 12:48 AM   #17860
I bought some only weeks ago from here
http://www.goldstarstockists.net/liv...cn2885&x=0&y=0
Old 11-22-2012, 06:10 AM   #17861
rcjunky1's Avatar
Thanks, so they're probably 10x15x0.3 shims, I'll see what I can find
EDIT: turns out the durango diff shims are 10x12, so I'll be getting a pack of the 0.1 ones and play with differant amount of shims to get a good diff action. I made sure to order the heavy duty tranny gear set as well so hopefully I don't need to touch the diff to often. My kit should be here tomorrow along with the last few parts I need (other then the motor plate and steering link) so I'll be probably building it Tuesday on my day off. I'll be taking pics and doing a build review for my local forum so I'll post a link here once its up.
Team Durango Canada
Old 11-23-2012, 03:01 AM   #17862
Be warned, too tight a gear diff and you'll start stripping gears (when the front of the car lifts, the gears spin up and when the front comes back down you'll shred the spur)
Old 11-23-2012, 09:10 AM   #17863
Good tip about using durango shims! I'm about to build my M03 kit and already have lots of durango shims.
Old 11-23-2012, 10:52 AM   #17864
rcjunky1's Avatar
I was going to buy some durango shims, then noticed I already had tamiya ones which are exactly the same. it seemed to do the trick, but should it feel a bit notchy until broken it? I didn't do it too tight yet as I think it needs to wear in a bit. I already put the black gears in it so hopefully it stays together, if not I have a backup white set.
Team Durango Canada
Old 11-24-2012, 07:32 PM   #17865
I have a question and if I am hijacking this thread I do apologize. Used the search function and this seemed the best thread to ask the question I have.
Was at the local hobby shop today when I noticed they were racing again. Went inside to talk to one of the employees there as I wanted to see what classes they had. One of the classes ran Tamiya M chassis (03 and 05) and goes on to talk about both chassis. He tried to sell me a M05 RTR for $159 (TAM84134). I didn't buy it as I wanted to research parts availability, etc. Looking on-line it said that most parts are discontinued are are on back order. So my question is this. Was the guy just trying to unload some old stock on me or are these cars still used and parts are readily available? Appreciate the help.
MoralThreat is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
