Like Tree200Likes
Old 11-08-2012, 12:23 PM   #17821
So for medium grip carpet, which m03 wheelbase length do most people prefer?
jha07 is offline   Reply With Quote
Old 11-08-2012, 12:41 PM   #17822
Usually medium, sometimes long for me.
Here I used M03m... big mistake as traction roll was my enemy. The M05s were less susceptible to traction roll.
+ YouTube Video
The traction roll was so frustrating, my car looked like this in the A-main.
I took anything I could find, put it on the left side (e.g. lead, heatsink, tamiya wrench).
Also had left ride height 3mm, right 6mm. And all different spring rates in each corner of the car.
That was the time I wish I brought my M05.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 11-08-2012, 03:02 PM   #17823
I run the short wheelbase m03, but with the rear two degree toe hexes that really help against traction rolling, but in all fairness, running the soft red tamiya springs ,front and back, have stopped the tractuon rolling tendencies dead on their tracks... Gluing the front tire side walls really help, and I run S-grip front tires with 60D slick rears.....
bertrandsv87 is offline   Reply With Quote
Old 11-10-2012, 01:01 PM   #17824
Can someone explain to me how the following tires are different?
Looking at rcmart, they have 4 different slick tires...
- Tamiya (#53215) M-Chassis Slicks
- Tamiya (#53222) M-Chassis Super Slicks
- Tamiya (#53340) 60D Reinforced Tires TYPE-A
- Tamiya (#54216) 60D Reinforced Tires Type B for M Chassis
Old 11-10-2012, 01:47 PM   #17825
monkeyracing's Avatar
53215 - 60mm, crappy kit slicks
53222 - 55mm, kind of sticky
53340 - 60mm, very grippy slicks
54216 - 60mm, medium grippy slicks
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 11-10-2012, 03:58 PM   #17826
THanks.
Would Type B (front), Type A (rear) be a good combo for a M03L on carpet?
Or should go with a less grippy front tire like a radial?
Can I assume the kit tires are useless for racing?
Old 11-10-2012, 04:26 PM   #17827
Everyone's situation is different, but I've had good luck with S grip radials on either all 4 corners, or just on the rear with Type A slicks on the front. A little CA glue on the sidewalls on the front, leading right up to the edge of the tread that meets the surface will stop traction roll, should it become an issue.
If your selection is limited to the tires you listed, then A on the rear and B on the front would be appropriate.
Stab it and steer.
Old 11-10-2012, 04:51 PM   #17828
I'm limited to Tamiya tires only.
How do S-grip radials compair to Type B slicks grip wise?
Old 11-10-2012, 05:03 PM   #17829
More grip with S.
Stab it and steer.
Old 11-10-2012, 05:32 PM   #17830
What about S-grip radials vs Type A slicks?
Old 11-11-2012, 10:52 AM   #17831
c-lyon's Avatar
I currently like Type A on all four on both M05 and M06 with Niftech, as one of our local tracks is Niftech only. Just don't oversauce the tires.
c-lyon is offline   Reply With Quote
Old 11-11-2012, 11:53 AM   #17832
Laguna Bozo's Avatar
Default Niftech?
Sorry...Dummy here...Niftech?
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 11-11-2012, 11:59 AM   #17833
Bigwave's Avatar
It's a brand of Traction Compound.
David "Bigwave" Stashko
Bigwave is offline   Reply With Quote
Old 11-11-2012, 12:58 PM   #17834
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
I find M-Grips all round work better on our carpet than S-Grips.
marcos graveyar is offline   Reply With Quote
Old 11-12-2012, 09:07 AM   #17835
Why didn't you like the s-grips?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
