Like Tree198Likes
Old 10-26-2012, 02:11 PM   #17731
monkeyracing's Avatar
Originally Posted by tossedman View Post
Holy crap this was a long read! Learned lots though. Now to go put it all to the test.
If you're bored and want to read a little more, here's a pretty good document on basic setup...HERE!
It will download as a .doc file, btw. If you just want to roam his site, I think this is it.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-26-2012, 02:15 PM   #17732
c-lyon's Avatar
If these are the big internal spacers I'll bring some tonight, Jim.
c-lyon is offline   Reply With Quote
Old 10-26-2012, 03:16 PM   #17733
Thanks, Colin. You're the KING.
Funny, can't find any of these things in N. America, but shops in Europe and Australia are offering loads of them for cheap. Also funny: They're under Tamiya 7-digit spares program, but the current part number has 8 digits. (2300010 is now 12300010)
Stab it and steer.
Old 10-26-2012, 04:07 PM   #17734
tossedman's Avatar
Thanks Jim,
More grist for the mill eh. Hope to get out to Carcar on Tuesday or Thursday for a bit of practice. Got a new radio coming from Santa (i know it's a bit early but my wife works that way. ). It should be here next week. (I hope)
Here's what I've been working on in the meantime. It's an M-05 pro chassis with the Orca Spark combo installed. I put a Kawada Borsche Speed Star body over top of it. Just because I could. It's the first body I've painted and turned out all right. Gotta practice more on that front as well.
Cheers eh!
Todd
I am always doing what I cannot do yet, in order to learn how to do it.
Vincent Van Gogh
tossedman is offline   Reply With Quote
Old 10-27-2012, 02:15 PM   #17735
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Ran the M05 in LWB form for the first time today. On a high grip carpet I couldn't get the back end to stop skipping on tighter corners, I tried changing to less gripy tyres, tyres with more grip, soft springs, hard springs, it still skipped. Any thoughts ?
Basic set up,
Front:
Tyres - M-Grips, Spice 5.5mm Medium insert, no additive or glue on tyre.
Damper - TRF M Chassis, 400wt oil, 3 hole piston, one black O-ring under piston, red urethane bush above bladder, 56.25mm, red spring, outer hole on CF upper mount, M06 Ball shaft lower mount.
Camber - Standard link. Toe 2deg out
Rear:
Tyres M-Grips, Tamiya Hard insert, no additive or glue on tyre.
Damper - TRF M Chassis, 400wt oil, 3 hole piston, one black O-ring under piston, red urethane bush above bladder, 56.25mm, red spring, standard upper mount, standard lower mount.
Camber - Adjustable link with 2mm spacer Toe 1.5deg in, Silver anti roll bar.
marcos graveyar is offline   Reply With Quote
Old 10-27-2012, 10:04 PM   #17736
bkspeedo's Avatar
Basic set up,
Front:
Rear:
I've come to find out with Mini's that ride height rake is a powerful setup option. I have an M03 but the overall geometries are similar (arm length, upper camber link ect.). I run a substantial amount if negative rake, front higher than the rear. Front ride height 10mm, rear side height 6mm. This helps stop weight transfer to the front keeping more weight on the rear tires which should help keep the rear of the car from skipping around. You may not need this much but give it a try.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-28-2012, 08:51 AM   #17737
Basic set up,
Front:
Rear:
Try increasing the rear camber. You also may try going to softer springs.
Another reason for running the front ride height higher than the rear is that you also get a camber adjustment. Most of the time on hi-grip surfaces, 5mm front and 4mm rear is a workable starting point.
I've done quite a bit of testing on hi-grip asphalt and have found that in my hands, the LWB is about 0.5 sec per lap slower. On lower grip surfaces, the LWB is just fine and is my preference there.
Granpa is offline   Reply With Quote
Old 10-29-2012, 10:24 PM   #17738
Trader Rating: 57 (100%+)
I'm having a steering/handling issue with my M05. On carpet the car is very twitchy and rotates very easy, but the rear isn't sliding and tends to roll very easy. I have my radio turned all the way down on speed as well as expo on steering and throttle. EPA is at 70% l/r. Is there anything else electronically I can do? I'm using a m11x.
How about mechanically? The car is on Sweep 33's (spec tires) In LWB with the JCW coupe body. I do have about 21 grams under the servo and the front bumper lower cavity filled with lead, its about 17 grams total.
Setup
Front
Tires - Sweep 33
Shocks - 3 hole, 1mm oring, 500, blue, 57mm
Adjustables - kit camber, 2* toe out, 3.5mm ride height
Rear
Tires - Sweep 33
Shocks - 3 hole, 1mm oring, 350, yellow, 57mm
Adjustables - kit, but do have the adjustable link not installed yet 4.5mm ride height
PROMODVETTE is offline   Reply With Quote
Old 10-29-2012, 10:25 PM   #17739
Double post
Old 10-29-2012, 11:09 PM   #17740
hello I came across spec m-05
and the q is do you guys use the extra heavy alum .pcs? for racing?
motor heat sink or do you buy the alum . motor mount or skip them both? (orca motor doesnt need any help with heat?)
what about the alum plate for the rear wheels?
thanks for any info
urban is offline   Reply With Quote
Old 10-29-2012, 11:15 PM   #17741
Suspended
I will mention this because you didn't say what your radio gear is. First you need to check if indeed your exponential is doing what you think it is. I say this because it seems there might be differences between makes. Some soften the servo response at positive expo some soften it at negative. Logic would have you think you need negative exponential to soften the servo response because you need a logarithmic not exponential response curve. Manufacturers don't necessarily follow this logic though. Have a little test with your gear and with the results in hand you'll know.
More from the more knowledgeable.
niznai is offline   Reply With Quote
Old 10-29-2012, 11:46 PM   #17742
My Spektrum has expo backwards. It was really annoying until I figured that out.
Stab it and steer.
Old 10-29-2012, 11:52 PM   #17743
I)arkness's Avatar
lol
yeah you want it in the positive range not negative
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 10-30-2012, 06:25 AM   #17744
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Setup
Front
Tires - Sweep 33
Rear
Tires - Sweep 33
Can you double check you dont have your rear uprights on the wrong side? You should have toe IN on the rear. We had this problem on someones car last Sunday, once the issue was found and rectified, the car was fine.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 10-30-2012, 01:56 PM   #17745
Thanks for all the tips. I will check those all out and give it a try tomorrow night!
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
