Like Tree200Likes
Old 10-25-2012, 12:45 PM   #17716
Laguna Bozo's Avatar
Monkey,
RE oil- filled stock gear diff
ANS NO
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 10-25-2012, 12:50 PM   #17717
monkeyracing's Avatar
Well, a guy can dream, right? Guess I'll just jam it full of putty. (That's what she said!)
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-25-2012, 03:06 PM   #17718
What would you guys recommend grease wise in a std m03 diff?
markrobinson is offline   Reply With Quote
Old 10-25-2012, 04:34 PM   #17719
bkspeedo's Avatar
None of the above. Buy some extra Gear Diff shims, the ones included with the kit. Add 2-4 (1-2 per side) under the main gears, add some diff grease under main gear and in the planetary gears as lubricant, screw the case back together tight. Test the diff action, should be very tight but have some slip, If still loose add 1 or more shims. The diff will loosen up some after the first few uses.
This works very well and should only need a rebuild after 40-50 races.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-26-2012, 12:45 AM   #17720
Thanks for the reply Brent.
Anyone else want to share how they build there's
Old 10-26-2012, 02:05 AM   #17721
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
I double shim the main gear too and also use a copious amount of Tamiya Anti Wear grease.
This gives a nice tight diff.
I do find that I go through a lot of spur and idler gears though. Mainly stripping the teeth on the first gear, but also bending of teeth on the first and second gear.
marcos graveyar is offline   Reply With Quote
Old 10-26-2012, 02:29 AM   #17722
So much for Tamiya's Touring Car hard joint cup set
This is after 4 race days.
Old 10-26-2012, 02:40 AM   #17723
Do you have a part number for these. I've got loads of bevel gears hanging around, but not a spare shim in the house.
Jim
Stab it and steer.
Old 10-26-2012, 03:15 AM   #17724
Tamiya 12300010 9mm washer.
Old 10-26-2012, 03:17 AM   #17725
Hi, what color is that? Mine is very dark (not shiny) and so far no grooving.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 10-26-2012, 03:34 AM   #17726
I)arkness's Avatar
ta03 hardened ball diff outdrive is dull gray no groves, while the gear diff outdrives have a grove for some reason
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 10-26-2012, 08:12 AM   #17727
These are the grey ones, Tamiya 53218 RC Touring Car Hard Joint Cup For Gear Diff (TA04, TA03, TL01) .
Only got them mid August.
Old 10-26-2012, 11:00 AM   #17728
I posted on more than one occasion a modification that my good friend Laguna Bozo came up with several years ago. Since then, my out drives seem to last nearly forever. This mod has been TCS legal for a # of years, but at the last Nationals they did not allow it. However changing back to the stock configuration only takes a few minutes.
The mod is a little time consuming to do if you don't have a mill. All you need to do is open up the drive slots to accommodate a #53890 swing shaft protector. Since I don't have a mill, I used a dremel and cut off discs to open up the slot wide enough for the blades. It took about 45 min. the first time, but it took less time on subsequent efforts. Be sure to use eye protection if you try it with a dremel.
You don't need to start with new outdrives, cause your "notched ones will be fine. Also, the blades which you obviously place on the drive pins of the axle
will make them longer so you will have be careful of the amount of spacers you use on the inside of the outdrives.
Granpa is offline   Reply With Quote
Old 10-26-2012, 01:45 PM   #17729
tossedman's Avatar
Holy crap this was a long read! Learned lots though. Now to go put it all to the test.
Cheers eh!
Todd
I am always doing what I cannot do yet, in order to learn how to do it.
Vincent Van Gogh
tossedman is offline   Reply With Quote
Old 10-26-2012, 03:05 PM   #17730
Should have asked before: Do you know of any reliable online sources? They seem to be a little sparse at most places I've looked.
Stab it and steer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
