Like Tree2Likes
Old 10-24-2012, 05:02 PM   #17701
monkeyracing's Avatar
Originally Posted by turbotron View Post
Ok man cool, that sounds perfect. And thank you for the tips! now for power, i know the silver can is great. But something with a tad bit more spank would be cool too lol. Any suggestions? i used to have a tamiya factory can laying around, but who knows where that is. If i wanted to go brushless, what kv? all my stuff is probably over powered for this little guy.
Track down a Hobbywing 13T 35A system and you'll probably never look back. It has become the international standard for minis Hobbywing's product page.
Best deals are usually out of Hong Kong and there are loads of rebranded and copied versions, too.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-24-2012, 06:01 PM   #17702
bkspeedo's Avatar
How do you run the diff in your Mini?
1. Ball diff, tight
2. Gear diff, shimmed tight, still has diff action
3. Gear diff, shimmed medium, lots of diff action
4. Gear diff, box stock, spins freely
If none of the above please describe what you use for a diff and how it's setup?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-24-2012, 06:03 PM   #17703
I)arkness's Avatar
go back one page, a person responded you to your question
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 10-24-2012, 06:23 PM   #17704
RossoTorro's Avatar
Originally Posted by I)arkness View Post
the blue/sliver chrome chassis parts are just a strong as normal bits, as they are just std parts dipped in the coating
My blue M05 is shelfqueen since the whole coating sucks static electricity like a condensator. The discharge happend through TX and it went wild for half a second when discharge. When i lift the car up and held my finger 10 cm from the motor the spark would fly. I belive it's a combination of many things like rideheight, coating and carpet. The strange thing is that the blue M03 chassi did not have this problem and with almost same running gear (ezrun, spektrum TX, lipo, foamtires and plastic gear servo) and same carpet.
And to think of it, i bought two kits of them along with extra red, black and blue frames. Also have two of the silver frame specials....
I guess it's like Alienware computers, who needs them? But my god they look and feel nice, eh?
RossoTorro is offline   Reply With Quote
Old 10-24-2012, 06:26 PM   #17705
I)arkness's Avatar
one thing i never have to worry about, as i dont race on carpet
B.Portelli
Old 10-24-2012, 06:47 PM   #17706
artwork's Avatar
Trader Rating: 55 (100%+)
1. Ball diff, tight
I am curious about this as well...I am surprised there was only one response. So everyone is running a tight ball diff?
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 10-24-2012, 06:54 PM   #17707
RossoTorro's Avatar
1. Ball diff, tight
I used to run ball diff with ceramic balls, medium tight.
We race on carpet and with foams, so it means nothing to you i guess.
Now i run oil filled gear diff's becasue it's less maintanance and setting stay same.
Old 10-24-2012, 09:08 PM   #17708
bkspeedo's Avatar
I'm hoping to see 10+ responses on this topic. It's a bit of a controversy in CO where we're just starting to race Mini's. I'm a little shocked only 1 person responded.
Brent Klingforth
Old 10-24-2012, 09:12 PM   #17709
I)arkness's Avatar
1. Ball diff, tight
Best option and will provide the most acceleration out of the corner
can get the same result as the tight ball diff, but will weigh more
again same as above but will lose the extra punch
crap at everything, dont even bother
B.Portelli
Old 10-24-2012, 09:36 PM   #17710
bkspeedo's Avatar
1. Ball diff, tight
Have you ever attended a TCS race? If yes, did they allow a tight shimmed gear diff or did you have to run a ball diff?
Brent Klingforth
Old 10-24-2012, 09:36 PM   #17711
Tough question to answer cause it really depends on track surface, grip level, track temp, etc. Some will make diff change to suit the conditions.
For me, a medium stiff ball diff for all except the unusual.
Granpa is offline   Reply With Quote
Old 10-24-2012, 11:57 PM   #17712
I prefer box stock gear diff, built per instruction. With light coating of anti-wear grease. No extra shims.
Tried tight ta03 ball diff, m05 diff, spool. I just seem to gravitate back to the simple gear diff.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 10-25-2012, 01:50 AM   #17713
Static: That's got to be a metal plating/foam tire combo. I've only ever raced on carpet, with rubber tires and a few times with a plated chassis, but never had static. Or...maybe you're REALLY bad at wiring.
Diffs: I've run a tight ball diff with ceramic balls for a few years and was the bomb until recently, when the oil filled gear diffs came out. Seeing how I can't run anoil filled diff in an M03, I jumped straight to a spool. (locked diff)
Driving style needs to be adjusted for the spool, as the car wants to plow a lot more. Softer front suspension, higher rear ride height and/or slightly earlier turn in on the corner are all tools you can use to adapt.
Speaking of oil filled (stock gear) diffs, has anyone ever found a way to get some 500,000wt silicone in one and keep it there?
Stab it and steer.
Old 10-25-2012, 03:18 AM   #17714
RossoTorro's Avatar
Lol, yeah, if you say so.
Old 10-25-2012, 10:47 AM   #17715
The Big Wig's Avatar
Originally Posted by The Big Wig View Post
Does anyone know if the dimentions of these? Would they fit the M04 in front?
No?
The Big Wig is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
