Like Tree100Likes
Old 07-12-2006, 03:44 AM   #1756
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Jeff,
53217 Touring Car Hard Joint cup set (for ball diff) suits Manta ray or Ta03 ball diff
53218 Touring Car Hard Joint cup set (for gear diff)
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-12-2006, 04:15 AM   #1757
Mad Mackem's Avatar
Thanks Dan, do you know anywhere that has them in stock?
Mad Mackem is offline   Reply With Quote
Old 07-12-2006, 05:43 AM   #1758
SilverShelby's Avatar
Just picking at Doc his a buddy too hehe
and YES Its a can motor!!!!!
M03,M05L,M06M,FF03PRO,CC01 Jeep,M03L-Yello Mini
ABC Hobby Goose,Genetic
2011 Memphis winner Mini,FWD
2013 e mergent winner Mini
SilverShelby is offline   Reply With Quote
Old 07-12-2006, 06:54 AM   #1759
billjacobs's Avatar
Trader Rating: 52 (100%+)
Default tamiya m04m setup for low traction asphault
I tried to find a setup for an m04m on low grip parking lot asphault and was unsuccessful, so this is to help others: (won tcs local race twice)
1) shocks: I use tamiya gold shocks from ta03 days (new trf shocks are the same length)
a) 2 hole pistons and 25 weight associated oil front and rear.
b) front short red springs, rear short yellow springs (old tuned short springs)
c) front uptravel and downtravel limiters, down travel 4mm, uptravel 2mm
(downtravel goes inside shock, uptravel goes outside shock on shaft)
d) rear uptravel and downtravel limiters, down travel 4mm, uptravel 3mm
e) 1mm extra preload in rear left shock (to compensate for the motors weight)
the reason the front needs up and down travel limiters is to move the suspension into a higher natural position and to limit the droop (less front droop means increased on power steering) (otherwise at full suspension compression, the front tires toe in too much causing the car to push, and there is too much camber causing the tire to wear unevenly), same thing for the rear, but it is more to limit camber change
2) Gear diff in the back with .2mm 10mm spacers added to each side in addition to the standard washers and anti wear grease inside the gear diff
3) 1 degree toe out in the front (the toe out turns to neutral as the suspension is compressed in a corner)
4) 2 degree toe in blocks in the rear
5) s grips with hard foam inserts in the front (s grips must be in good shape or the car will drift on the straights), a slicks with hard foam inserts in the rear
6) sway bar in the back (modified m03 sway bars (use short plastic links on top and bottom, this makes the swaybar link shorter)
Other hop ups on the car:
m03 aluminum steering blocks (not necessary, but adds weight to the front end for more grip)
tl01 suspension shafts
full ball bearings
adjustable steering turnbuckles
m04 motor heatsink (doesn't do much, but I can put a 20 tooth into the 19 tooth setting and the heatsink keeps everything lined up)
Hope this helps somebody.
pics are below:
Tamiya mini cooper-m04m3.jpg   Tamiya mini cooper-m04m2.jpg   Tamiya mini cooper-m04m1.jpg
billjacobs is offline   Reply With Quote
Old 07-12-2006, 08:35 PM   #1760
KyLayfield's Avatar
Trader Rating: 86 (99%+)
Where can you buy the silver can kit motors? -Ky
KyLayfield is offline   Reply With Quote
Old 07-12-2006, 09:26 PM   #1761
racenut's Avatar
Trader Rating: 15 (100%+)
Stupid question here but i will ask it anyway...
What chasis comes with Suzuki swift body??? is it Mo3 just like mini cooper???
racenut is offline   Reply With Quote
Old 07-12-2006, 09:36 PM   #1762
Mad Mackem's Avatar
It is a M03M which is a standard M03 with a medium spacer in the chassis. This gives a wheelbase between a standard Mini and the BMW variety.
Old 07-12-2006, 09:40 PM   #1763
racenut's Avatar
Oh i see...alryt, tnx.
Old 07-17-2006, 06:30 AM   #1764
Nova F1 Racer's Avatar
I ran my 4 wheel drive Tamiya Mini Cooper yesteday in a charity race ( small track in a parking lot and thay said I could run it with the other minis) in Geln Burnie, MD and here is the summary:
BTW, I took a TL01 body and cut/shaped/glued/etc so it has the wheel base of the mini cooper, modified the shaft... BTW, NOT THE LONG version....
I used mini parts for everything else except the chassis... 4 months in the making, getting the shaft just right was the biggest problem....
I used the stock "diff" in the rear and a locked/packed diff in the front with a 23 tooth pinion.... Silver can motor and a 2 year old 3300 stick pack battery...
I had a expert racer take it for a spin ( He is one of the area's best mini driver so I could get a real good and honest opinion ). He was amazed on how well the car handled the infield, very few minis could touch it in the infield. The straight away was another story, a little slow but it made up for it on the rest of the track... So I am going to put ball diffs in the front and rear to see if I can get some of the speed back on the straight away.
I'll try and gets some pics tonight and post them tomorrow with out the electronics. A number of people has expressed a lot of interest in this car and the they were amazed on how well it looked exactly like a mini and handled like a 4 wheel drive car.
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 07-17-2006, 09:26 AM   #1765
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
hi,
Just a quick Q,
which is the best mini M -chassis (Mini) in handling?M03L or 03.
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 07-17-2006, 10:02 AM   #1766
Originally Posted by KREATOR1
hi,
Just a quick Q,
the "L" is easierto drive and on wide open tracks and no tight corners.
The shorter version has less weight ( the expander and the the body ) and can turn on a dime and leave change. Traction roll can become an issue as well..
RC Tech member #11
Old 07-17-2006, 10:46 AM   #1767
itchy b's Avatar
hi,
Just a quick Q,
the mo3m is a good allrounder for most tracks
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 07-17-2006, 12:45 PM   #1768
rclink's Avatar
Send a message via AIM to rclink Send a message via Yahoo to rclink
Talking Best all around tire for mo3?
Hey'
Can anyone recommend the best all around tire for hot weather, compound surfaced tracks? Just bought a mo3 and have stocks on to run around, but I'll need to change for racing. Got any idea's?
Rclink
rclink is offline   Reply With Quote
Old 07-17-2006, 01:08 PM   #1769
Originally Posted by rclink
Hey'
Rclink
Ms in front and S in rear.....
RC Tech member #11
Old 07-17-2006, 09:41 PM   #1770
racenut's Avatar
We did that a year ago here in the Philippines. I still have mine collecting dust in the drawer. We also did a monster version of shorten wheel base of TLo1.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
