Old 09-22-2012, 02:30 AM   #17551
rave1010hk's Avatar
Default My mini Cooper Body
My mini Cooper Body
Tamiya mini cooper-dsc00368.jpg   Tamiya mini cooper-dsc00366.jpg   Tamiya mini cooper-dsc00367.jpg   Tamiya mini cooper-dsc00364.jpg   Tamiya mini cooper-dsc00369.jpg
MUGEN MTX5、MTX4-R、NR FLASH 12.PTS/MRX5、NR FLASH 21.PTS/MBX6、NR BONITO 21-7XLBS/SPP 966、733、811、411、120、120L、240、100/TAMIYA 417、F104X1、M05/XRAY RX8、T3/FUTABA 4PKS
rave1010hk is offline   Reply With Quote
Old 09-22-2012, 02:49 AM   #17552
sosidge's Avatar
Originally Posted by nytryder View Post
Got a buddy into minis and he picked up a brand new m05 s-spec kit. He got a ta03 ball diff and is having trouble fitting it in...it's too narrow/ too much side to side play. He tried switching the plastic bearing cups around and that didn't help either. Is he supposed to use different outdrives with it? or is there another trick to making it work like using bigger bearings?
There is some side-to-side play in the diff, more than a high-end TC, but it shouldn't affect the operation of the car.
It uses the smaller bearings that need to go into the plastic outdrive bushings, it is exactly the same fitment as the Tamiya gear diff, bushings on the outside.
Old 09-22-2012, 03:04 AM   #17553
monkeyracing's Avatar
The TA03 ball diff should have come with the appropriate outdrives. The splines are a different length than those on the gear diff. The odd bit is that they're shorter, which would appear to be a problem. The chassis halves are completely together? If so, just drive it and see what happens.
17.5T motor guys, you should find this entertaining: I got a Novak Ballistic 17.5T today in a trade. It's my first sensored, adjustable timing brushless motor, so I thought I'd get as much wrong out of the way as possible right away. I popped it into my M03 with the speed gears, big pinion, etc. I cranked the motor timing all the way up and added maximum boost on my ESC. It sat there on my bench looking all eager and ready to go.
It was...for about half a second before the tire blew off the rim and the gears made funny noises. Oops!
This is so cool!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 09-22-2012, 03:12 AM   #17554
Laguna Bozo's Avatar
Default 2c Mini
One more 2c worth: The 17.5 experiment was good. Found out if the chassis could take it, which it did, and how many actually enjoyed going faster, which is still up in the air.
The problem with Mini class is that some still view it as a beginner's class, which it no longer is (TCS has a spec beginner's class). Mini is usually the largest entry, hardest fought class at TCS! Because it's the most fun. But the experiment also proved that if it's broken into 2 classes it is most likely doomed. Which is exactly why Fred's decision this year is important, at least to all of us on this forum, and why 21.5 may be the best compromise...
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 09-22-2012, 03:21 AM   #17555
rave1010hk Great Paintjob!!!!!!!!
MWShelton is offline   Reply With Quote
Old 09-22-2012, 05:11 AM   #17556
No motor limit
+ YouTube Video
Chassis can take it. It's the tires that may have problems.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 09-22-2012, 10:05 PM   #17557
Got my new S spec chassis built today, will get the body done up and will post a picture soon. got to finish tweeking it some
hdzrtmini is offline   Reply With Quote
Old 09-23-2012, 03:52 AM   #17558
Found a better pic of the M-06R on RC Driver. Yup, silver and red plastics and aluminum. But...what's on the rear upright there? A brass weight of some kind?
Stab it and steer.
Old 09-23-2012, 01:58 PM   #17559
Been racing and building Minis for quite awhile and NEVER, EVER have figured out how you can measure the end play in the diff. Also have never bothered to ever shim the gears after my first attempt many years ago. Never could figure out how many shims to use and where to put them.
Now, I just build the diff, install the gears, install the outdrive with the pin, put the diff on that outdrive. These parts are placed in the right chassis half, then the left chassis half is placed and it's all screwed together. As long as it's spinning free with no binding, I never give it a second thought. How can you tell if anything is shifting from side to side ?????? And if it does, how can you tell if it does and by how much?????? The chassis is screwed together and there is no way to look inside.
Just for academic interest, can someone post the procedure for measuring end play for the diff and the gears.
Granpa is offline   Reply With Quote
Old 09-23-2012, 02:26 PM   #17560
Erik, ol' buddy, just make sure he built it exactly as the instructions say, and hasn't shaved or modified any parts. Build the ball diff per the instructions, use the outdrives with the short splines that came with the ball diff. Do not, I repeat, do not use the outdrives made for the gear diff with a ball diff. You cannot get into trouble if you follow the instructions.
Also check that he built the suspension arms correctly, cause it's really easy for a newbie to get those all wrong.
Old 09-23-2012, 02:59 PM   #17561
I'm Erik's buddy, I built the diff per instruction and slapped it in just like you said Granpa. All is good after a few runs and I am pretty sure the arms are built right i mean i did follow the directions.
Not sure how you can build arms wrong but then again I'm a 1/5 scale guy and ever thing is much bigger ha ha
Old 09-23-2012, 04:11 PM   #17562
Ok here it is, I come from the 5th scale off road so i am known for not spending to much time on my bodies LOL.
Well !@#$% cant post pictures.
Old 09-23-2012, 07:44 PM   #17563
Here is something else I've been wondering about. It has been posted that the steering linkage in the M05 has a lot of slop which is BAD, BAD, BAD. Sure enough, when I checked mine, which has the Tamiya metal bits, it did have some "slop". So without too much thought, I shimmed out most of the "play" which was a real PITA to do. On test driving, I did not notice a significant improvement in performance, in fact none at all. I just "chalked" that up to perhaps my not being a good enough driver to notice the difference in "feel".
Then, guess what, I lost the gears at a race. Anyone who has ever done this, knows you have to partially disassemble the steering linkage to split the chassis. Yep, you guessed it the extra shims fell on the floor. Crawled around on the floor and could not find them so just put everything back together and let the left steering arm have a little slop. My lap times did not suffer. "How can that be" you might ask. Surely your car was wandering and the steering must have turned to mush. No, not really.
So to all you would be Ellery Queens out there, can you tell me why this happened. I think I know, but would like to hear from the shimmers and non shimmers.
Old 09-23-2012, 08:58 PM   #17564
silvalis's Avatar
Trader Rating: 29 (100%+)
I seem to recall the RC mini boys writing about the acres of steering slop in their minis and how it just works...
Mine works fine without shimming. The one time I shimmed it I hit something and bent things...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 09-24-2012, 12:32 AM   #17565
thanks guys for the help on the balldiff install. looks like hidezertmini got it figured out and signed up here on the forums too.
nytryder is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
