Like Tree137Likes
Old 09-13-2012, 04:38 PM   #17506
sosidge's Avatar
Originally Posted by dirtman71 View Post
Dusted off my mini(havent driven it in 4 months) to see what kind of shape it was in. Under acceleration it pulls to the right...rather hard. It has to be the 3 racing diff? It stops pulling as soon as I get off the throttle. Thought it might be a bearing, or something binding in th front, or even the rear. But it only pulls under power so logic tells me loose diff.
I have had this problem before and the diff must be worn and I cant keep it to stay tight. want to try a solid axle in the front...how well do they work? will i loose any handleing? maybe go to a gear diff?
I posted and went through this probably 9 months ago...just my problem persists and looking for some fresh thoughts
The 3Racing ball diff is junk and I wouldn't let it any where near my car. The gear diff is OK but needs running in and careful selection of the oil, otherwise you will end up with the same straight line instability.
As well as checking for bent parts and seized bearings, you should run toe-out on the front end, this also helps with the stability.
Old 09-13-2012, 05:03 PM   #17507
dirtman71's Avatar
I have a lot of slop in the front end...I think that is killing me too will add some toe out.
looks like I just need to buy a new car
Kyosho SC-R, RC8Be, Jammin X1CRe, Jammin SCRT10, RC10GT2, T4.1
Slash 2wd ChuckWorks slice B2, E-maxx, RC10T3, Tamiya M-05, TA-05
dirtman71 is offline   Reply With Quote
Old 09-13-2012, 05:50 PM   #17508
Core Creations's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to Core Creations
Any more info?? Specs??
84312 M-06R Chassis Kit (RC Limited) (RC Model)
Release Date : Dec
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 09-13-2012, 06:45 PM   #17509
monkeyracing's Avatar
Interesting. Not currently a Tamiya part number, but it does appear to be the next one in line. Not sure what the point would be of an M06R, though. Maybe a stop gap until Tamiya decides to drop the M07 bomb in a year or two?
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 09-14-2012, 12:59 AM   #17510
niznai's Avatar
Hopefully it comes with some decent shocks instead of the woefully clear plastic items on the PRO.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-14-2012, 09:58 AM   #17511
Having a hard time finding any diff lube thicker than 125,000.. where are you guys getting your 300,000 and 500,000?
jjjheimer is offline   Reply With Quote
Old 09-14-2012, 10:04 AM   #17512
Try TQ RC Racing
Granpa is offline   Reply With Quote
Old 09-14-2012, 10:37 AM   #17513
Not sure if you picked a brand, but Kyosho makes both 300k and 500k.
Stab it and steer.
Old 09-14-2012, 07:53 PM   #17514
flat4's Avatar
Send a message via Yahoo to flat4
"84312 M-06R Chassis Kit" from what I have been able to find out/ see, is instead of blue aluminum part, they are red?... including the shocks,...but that is just a pic I saw at:
http://tamiyablog.com/
mo6/ae sc10/2wd slash
flat4 is offline   Reply With Quote
Old 09-14-2012, 08:14 PM   #17515
Thanks monkeyracing.
Old 09-14-2012, 08:44 PM   #17516
No worries. Happy to help.
Stab it and steer.
Old 09-19-2012, 10:44 AM   #17517
Looks like the TCS Mini Pro class will be going to 21.5 B/L next year. Don't know how many on this thread race the TCS series, but just posted it as information. TCS usually goes with major manufacturers so all of the speedos and motors should be available from the large hobby shops and from your LHS.
That was the knock on the system used in Australia in that trying to find one was like trying to fins a "speakeasy" in the days of Prohibition. To my very young friends and non USA friends there was a time that alcoholic beverages were illegal in this country. Thus the term Prohibition and an illegal, underground bar was termed a "speakeasy". How products are distributed are a little different in the various locals. What might be widely available in one area may be vastly different in another country.
Seems like a good solution cause the experiment with 17.5s was not totally successful. They were too fast and were too much for the spec tire we were expected to run. They worked better in the "outlaw" races which allowed the smaller 55mm tire which have a lot more "grip". The other problem was they were very hard on the drivetrain and reduced universals to junk in half the time and outdrives were notching on very little run time.
Sorry, "grip" is caveman for traction or the coefficient of friction between the tire and the track surface. Come to think of it, so is "loose" and "slick" in other contexts. But then, I drink my coffee from a "mug", like women with "boobs" and "legs", a fan of "big" cars and "sprint" cars without "wings" on "dirt" but realize it was way too dangerous, and think that F1 is the ultimate form of racing. Altho, my favorites were the "midgets".
Old 09-19-2012, 11:12 AM   #17518
SMcD's Avatar
Trader Rating: 61 (100%+)
Mini PRO 17.5 brushless class succesfully killed. Great job guys - mission accomplished. Now I can peacefully retire from TCS racing w/o regret. Thank you.
SMcD is offline   Reply With Quote
Old 09-19-2012, 02:02 PM   #17519
Interesting post in that no one "killed" 17.5 B/L in Mini Pro except those who were running 17.5s. The Mini Pro class was offered at the Nats, but no one entered or so few entered it was not a viable class. There would not be any incentive for the organizers to have a class that no one enters would there????
Old 09-19-2012, 04:30 PM   #17520
rcdave1's Avatar
Trader Rating: 14 (100%+)
And some one thinks that a 21.5 class would be better? I read the couple of post before this and I would like to give my input on this subject as I'm a avid 17.5 mini cooper racer. I raced in 3 tcs races this year and continued to race the whole summer with the same mini cooper and had no problems with gears or universals. As for the speed I don't see a huge difference in the speed and its certainly controllable even with the premounts which I ran in the 3 TCS races, I won 2 of them and Tq'ed 1, my pace was only 6 seconds up on the silvercan mini's. I continued to run throughout the summer and won or came in 2nd in most of the outdoor racing. If Tamiya is wanting to go the 21.5 route then I'm sure that I'm not the only one that will be done with TCS racing. I raced the silvercan mini's along time and faired pretty well, but after trying the 17.5 I was hooked, very little maintenance on the motor and very little use of my lipo. Just a win win in my opinion.
I'm sure everyone has their opinion and they have that right this is just my opinion.
Dave Banks
rcdave1 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
