Like Tree21Likes
Old 08-07-2012, 03:57 PM   #17371
MD
MD's Avatar
Trader Rating: 106 (100%+)
Originally Posted by marcos graveyar View Post
Does anyone know of a source for Tamiya Orange wheels for the Suzuki ?
Tamiya part number 49470. Looking for 3 sets.
Thanks in advance.
Here you go.
http://www.vellrip.com/store/product....asp?p=32&c=38
http://www.bidorbuy.co.za/item/68122...nt_Orange.html
MD is offline   Reply With Quote
Old 08-08-2012, 09:04 AM   #17372
Has anyone any tips on building a smooth 3racing oil filled gear diff? I have built it as per instructions and find it stiff and notchy, I removed 1 shim from each side and it is better but not as I'd like. I notice that if I lossen the 4 screws holding it together it gets smoother which is not ideal having loose screws.
Zen RSGT, Trinity, Hobbywing, LRP.
M05 S-Spec, LRP, Intellect.
M05 v2 Tekin, Orion, Savox.
B44 Mamba Max, Trakpower.
B44.2 Avid chassis, Speed Passion, Gens Ace.
BILKO1 is offline   Reply With Quote
Old 08-08-2012, 09:46 AM   #17373
I have a vague memory of removing some flashing from the gears, take a close look at them. I also left out one large shim from each side and it feels pretty smooth.
Steve S is offline   Reply With Quote
Old 08-08-2012, 11:18 AM   #17374
sosidge's Avatar
Another thing to bear in mind with the 3Racing diff is that the standard o-ring seals are exceptionally stiff and cause a lot of drag. I'd run-in the diff for as long as possible to bed them in before choosing the oil and putting it in the car.
I've got a feeling I had to remove some flashing from the circumference of the gears, but I am running the full complement of shims in mine. Since each moulding is slightly different, adding or removing shims can help.
Old 08-08-2012, 04:23 PM   #17375
Thanks for the replies guys i'll strip it down and check the gears for flashing then give it a good run in.
Old 08-09-2012, 02:27 AM   #17376
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Originally Posted by tony gray View Post
Stopped making them a few years back, you'll struggle to find them anywhere now.
Apart from HERE, pricey though
Thanks Tony and MD,
Pricey indeed, may have to rethink a bit, might just spray the white rims I have instead.
marcos graveyar is offline   Reply With Quote
Old 08-10-2012, 08:41 AM   #17377
Anyone use tamiya CVA mini shock unit II on m05 with internal 4 - 5mm spacer to lower the car??
i race on smooth tight carpet track.
I'm replacing 3racing body as they leak LOTS with this shock body. 3racing piston/shaft fits fine.
Is there enough suspesion travel on those with 5-6mm ground clearance?
Vrooom is offline   Reply With Quote
Old 08-11-2012, 08:39 AM   #17378
I'm in the process of building a set of mini cvas for my father's m03, 63 years old and still racing! I test fitted the shocks and there's plenty of travel to achieve 6mm ride height with 55d tires but not 60d.
I have a question regarding oil weight with these mini cva shocks. I'm using m-chassis aluminum dampers on my m05, 400cst oil all round. What oil should I use with these cvas to get a similar damping action?
My old super mini cvas had the clear 900cst oil, these mini cvas come with 400cst.
2hundy is offline   Reply With Quote
Old 08-11-2012, 09:22 AM   #17379
Thanks Tony and MD,
Found 2 sets on Ebay from "Jasons Store".
$7 a set, so not too bad at all.
Old 08-14-2012, 01:58 AM   #17380
monkeyracing's Avatar
Middle of the night, really bored question: What's the most useless piece of bling on your mini? Mine would be the carbon gear shafts. Not really blinky, but utterly pointless.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-14-2012, 03:26 AM   #17381
as for right now, its whole car. useless thing, that like to snap oversteer and understeer at every corner. lol.
Old 08-14-2012, 04:30 AM   #17382
Kail's Avatar
Thanks Tony and MD,
If you need the Fluoro Orange rims, I have many sets. I have many other selection of new rims for mini too.
Kail is offline   Reply With Quote
Old 08-14-2012, 07:05 AM   #17383
So if someone was going to get a M05 just to beat around his block, would stock be ok (yeah....right) or are there some essential upgrades?
Jongrill is offline   Reply With Quote
Old 08-14-2012, 07:13 AM   #17384
c-lyon's Avatar
Jim, I may not be blingy, but I'm probably the most useless item that my car has.
c-lyon is offline   Reply With Quote
Old 08-14-2012, 07:23 AM   #17385
tudor_47's Avatar
yes stock will do OK.
I have a blinged M05 and my friend got one thats stock even got the included dampers on.. There is next to no difference in our laptimes on the track
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
