Like Tree18Likes
Old 07-22-2012, 03:55 PM   #17341
Hmmm, I never thought of that. Good idea.
mariob62 is offline   Reply With Quote
Old 07-27-2012, 12:10 PM   #17342
I bought a set of m chassis dampers 54000. The quality is very impressive.
I have a couple of questions:
How many 3mm o rings should I place on the damper shaft to achieve 56mm shock length?
The set comes with black and clear I rings. Are the clear ones for sealing the body and the black ones for length adjustment?
2hundy is offline   Reply With Quote
Old 07-27-2012, 01:42 PM   #17343
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
three black orings in the shock bodies and clear for sealing ...
OVA is offline   Reply With Quote
Old 07-27-2012, 02:43 PM   #17344
Right, the clear one is for the shock body and acts as the oil seal. Use one black o-ring on the shaft, which I believe is what the instructions call for. On the M05, not using any spacer under the piston on the shock shaft will work better. That will give you more droop which can help under certain track conditions. Suggest you try it both ways and see which you like better.
Three o-rings are used on the old TRF TC shocks that had the long shock shafts. There are many variations of the TRF shocks, with different shock body sizes and varying shock shaft lengths, so it can get confusing.
A 56 mm shock length was pretty much standard, but presently many racers are using longer shocks. A lot depends on what the grip level is at your track along with which spring and oil combination you are using. Generally speaking, the lower the grip level, the longer the shock.
Granpa is offline   Reply With Quote
Old 07-29-2012, 01:06 PM   #17345
I've set the ride height by adjusting the collars on the 54000 dampers to 5mm all round. That was easy enough.
Since I now have the option of fine adjustment after upgrading the shocks I've had a further play with the preload.
I have four mini electronic scales and have tried to equalise the weight at all four corners.
Unadjusted they read:
FL 374 FR 316
RL 279 RR 320
After adjustment:
FL 348 FR 344
RL 295 RR 291
It seems so counter intuitive to preload the corners that start with less weight to even the load. Is this the correct way of doing this?
Old 07-29-2012, 07:51 PM   #17346
niznai's Avatar
Yeap, that is right.
It is not counter intuitive if you consider how suspension works.
Make sure you don't change the ride height in the process.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-30-2012, 12:03 AM   #17347
Chiefy 707's Avatar
At first I thought this was a front motor drift TA06 then I saw the mini body. OMFG nice!
http://www.youtube.com/watch?v=gdbDv...eature=related
BTW, how do you embed a youtube video on the forums?
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 07-31-2012, 05:15 PM   #17348
scribbler's Avatar
I thought that car came out a while ago. Isn't the 4wd mini with a 380 sized motor?
Has this caught on at all? Is anybody running a 4wd mini class at club level?
scribbler is offline   Reply With Quote
Old 07-31-2012, 05:22 PM   #17349
scribbler's Avatar
Originally Posted by Vrooom View Post
the yellow bars is extra set of arms placed there along with orginal arms. i guess that will stop the caster block cracking? anyone done it?
Will those bars across the back of the arms fit, is there clearance? I want to try this it looks different.
Please post pictures of the end result if you're going to follow through with it
Old 08-01-2012, 01:15 AM   #17350
They have just started a 4WD mini class at our club here in Aus. They have even put rules together for this. It's starting to become quite popular down here.
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 08-01-2012, 01:28 AM   #17351
racerxcali's Avatar
Cool
racerxcali is offline   Reply With Quote
Old 08-01-2012, 01:36 AM   #17352
racerxcali's Avatar
Thumbs up good setup
Originally Posted by fatdoggy View Post
FWD = Push, Understreer
RWD = Oversteer
Try using hard springs on the rear and lighter springs on the front as well as decient tyres. I've heard the hpi x patterns (for the hpi mini) work well.
Works good
Old 08-01-2012, 01:38 AM   #17353
racerxcali's Avatar
Default yeah i think so
Originally Posted by tony gray View Post
Such a project needs to begin with the assumption that the M05 is a BETTER car, and therefore worth tearing apart a perfectly good M03 to do the conversion...
dddd
Old 08-01-2012, 04:11 AM   #17354
Ride height was unaffected. It only needed a total of 0.75mm of adjustments on the collars to even it out, not much at all really.
Since doing this, the car no longer pulls to the left on acceleration!
Old 08-01-2012, 08:25 AM   #17355
iloverc(kuneho)'s Avatar
Default Damper
A good day to all i just purchased m chassis damper set just want to ask what works well the two holes or the three holes and what silicone oil and springs should i exactly use (tamiya brand)
By the way my kit is m05 and am running it on asphalt
Any help would be much appreciated thanks in advance and god bless us all
-rob
Me u cnnt ps.
Plf #69
iloverc(kuneho) is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
