Like Tree198Likes
Old 07-08-2012, 06:06 AM   #17236
Where is good place to put weight in m05? I bought lipo battery, and found my mini being 50g under weight to minimum 1250g
my car didnt steer too well. Im thinking of adding a small iron bar under the lipo battery. will that be enough?
actually what is the ideal weight distubtion in the m05 ?
Vrooom is offline   Reply With Quote
Old 07-08-2012, 06:40 AM   #17237
sohlman's Avatar
Trader Rating: 89 (100%+)
Under lipo and under servo are great places for extra weight.
Steve Sohl
sohlman is offline   Reply With Quote
Old 07-08-2012, 06:56 AM   #17238
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by Big Fran View Post
Hi all. I'm new here but have had RC stuff for the past 30 years.
I just painted my first body in over 10 years. Hope to be getting it out with my buddy in some parking lots soon.
Here are the pics...
Looks cool...i haven't seen those xip decals around in a while
you need to check out the SJCCR thread and the Jackson NJ threads - both places run the mini's Jackson is even hosting a TCS race in a few weeks
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-08-2012, 06:57 AM   #17239
k_bojar's Avatar
how did you get yours so light????? mine's 120-ish grams overweight
Old 07-08-2012, 07:22 AM   #17240
Mine was all stock, only optional part is 3racing shocks, 3racking knuckles, 3racing steering linkage. 3racing bottom wishbone. that all.
Old 07-08-2012, 08:39 AM   #17241
You do realize the 1250g weight minimum is with the battery and body. It's hard to conceive of a M05 that would come out at less than 1250g ready to race.
Granpa is offline   Reply With Quote
Old 07-08-2012, 10:29 AM   #17242
I have a quick question for all you mini gurus.
I've fitted the following to my m05:
Tamiya 53597 Universal assembly
Tamiya 53267 TA-03 Ball diff
The ball diff instructions do not mention placing an o ring in the outdrives, should one be in there?
2hundy is offline   Reply With Quote
Old 07-08-2012, 10:47 AM   #17243
monkeyracing's Avatar
You don't require an o-ring when running the ball diff. Did the ball diff come with proper outdrives? They're a tiny bit different than the gear diff ones.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 07-08-2012, 10:52 AM   #17244
The car weighed like something like 1205g today, the lipo battery i had is 180g, my old nimh battery is 270g. I had to add 50g weight on it to make 1255g
that figure is full race weight, including transponder. even down to all 4 body clips
Old 07-08-2012, 10:54 AM   #17245
Yes the ball diff came with it's own outdrives.
They differ from the standard m05 ones by being splined as opposed to flattened off.
I've had ball diffs in other cars and the outdrives are part of the diff plates, they are more akin to standard outdrives in the TA-03 ball diff.
One outdrive has a long pin at the end which runs through the diff, out the other side and into the other outdrive. It's as if they are designed to slide left and right within the diff splines.
Old 07-08-2012, 11:24 AM   #17246
Hyde's Avatar
I once blew the brains out my M03R with a mamba max BL system, I didn't have any o-rings, the cup popped out a little and rounded out the splines on the diff. I was using 3racing CV's. I'm sure it can happen with a less powerful motor but chances are less.
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 07-08-2012, 11:37 AM   #17247
Are the 3racing universals the same length as the Tamiya?
Old 07-08-2012, 01:12 PM   #17248
I've just tried some black tamiya o rings in the outdrive cups, pushed in as far as possible. The drive train is noticably binding, albeit slightly. Without the o rings it is very free indeed although this allows the outdrives to worryingly slide in and out of the diff, at least 2mm of movement.
Old 07-08-2012, 03:02 PM   #17249
They differ from the standard m05...
I was thinking about the outdrives as used on the older version of the kit gear diff, which were also splined, but at a slightly different length than the ball diff. I'm glad the kit came with them in any case.
Yes, and they're a much better value. Just be sure to avoid the v.2 ones. I doubt anyone has any left for sale, but they were a bit hit or miss. The current v.3 ones are perfect.
Question for you guys: Who has filed out their outdrives in order to utilize plastic blades on their outdrives? Just looking for tips and anything I'll need to be wary of. I', chucking the Yeah Racing spool back into my car and I'd like to keep my axles happy.
Stab it and steer.
Old 07-09-2012, 05:23 AM   #17250
I've been searching the net for a definitive answer and the closest I came was this.
The re-released Top Force is suppled with two ball diffs which are very similar to the TA-03 diff. It has the o rings in the outdrives.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
