Like Tree137Likes
Old 06-28-2012, 03:07 PM   #17221
gene1219's Avatar
Trader Rating: 16 (100%+)
Originally Posted by bronc4now View Post
so im putting together my mini and looking at the stock esc teu-104bk and it says i need a receiver with a bec to power the servo that's the 1st ive heard of a receiver having a bec. so anyways do i need a castle bec ? or can i just run a cap on the receiver ? sorry i did search im sure this has been asked
You should be fine with your RX. Back in the day most reviecers advertising point was that they were BEC (bettery elmintating circutry) Now a days it's a givin that most RX feature BEC.
gene1219 is offline   Reply With Quote
Old 06-28-2012, 03:23 PM   #17222
bronc4now's Avatar
Trader Rating: 40 (100%+)
cool man thanks i sould have it ready this weekend but im to busy to race
RACE-BASH-CRAWL
Two many toys not enough time..
bronc4now is offline   Reply With Quote
Old 07-01-2012, 05:03 PM   #17223
Raman's Avatar
Trader Rating: 54 (100%+)
Selling an ABC Goose rear wheel drive if anyone is interested
FS/ ABC Hobby Goose
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 07-01-2012, 06:04 PM   #17224
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by caltek1 View Post
k bojar,
The majority of the cars I was racing against were setup as MO5M cars using the Tamiya Swift body shell. So yes the softer set up will work on the medium and the short wheel based cars. I have a preference for LWB mini's. I did try the new JCW mini shell and found it was not as stable as the 2006 LWB mini cooper shell. This may have been due to wrong tyres early in my testing. However the LWB Copper body seemed to make the car more stable and easier for me to drive hard. My car did not traction roll at all with the setup I used. I also used V2 Tyre Gripper traction compound front and rear , early on and then used nil for the two finals. Two warm laps were enough for the tyres to work with great grip.
BTW,
I was using the new Ride mini springs which come as a matched pair. These were fitted to TRF shocks with three hole pistons and 35 wt oil front and rear. Next time I may try softer rear oil.
Regards,
Calvin.
so when you said 'soft', you meant in the 25 range? I'm not sure what I have in there now, but I was actually thinking 30/35 with the tamiya springs
thanks for the setup hints, my mini was awesome this weekend - too bad I was a dumbass and forgot to charge my transmitter
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-01-2012, 09:58 PM   #17225
niznai's Avatar
I think you will find that it is the ESC that has the BEC, not the radio. If the ESC doesn't have a BEC, then you need a separate battery pack for the receiver with the correct voltage
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-02-2012, 02:15 PM   #17226
bronc4now's Avatar
all done
RACE-BASH-CRAWL
Old 07-02-2012, 07:17 PM   #17227
jsr555's Avatar
Trader Rating: 17 (100%+)
all done
Very nice job.
Xray T4 - Yokomo Bd7-14 - HPI Pro5 - Powered by Hobbywing
HPI RS Pro - HPI Pro 3 - ??
jsr555 is offline   Reply With Quote
Old 07-06-2012, 11:59 AM   #17228
bkspeedo's Avatar
For those that have run Mini's outside on low traction asphalt, which Tamiya pre-mount slick would work better?
Type A with hard insert
Type A with soft insert
I would consider the Sweep or Solaris but there a smaller diameter tire that some may not like.
My reason for asking is we're working on specing 1 tire so racing stays even and those that start racing now exactly what to buy.
For those interested here's the rules we've defined so far.
Colorado Spec mini class
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-06-2012, 05:26 PM   #17229
hanulec's Avatar
Trader Rating: 27 (100%+)
Why not just run the radial tire?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-06-2012, 06:14 PM   #17230
bkspeedo's Avatar
We had 3 people running mini's this last Sunday at HobbyTown. 1 of the guys practiced with radial tires and the car didn't perform quit as well as the slicks we ran during racing I'm thinking the Type A tires will last longer as well.
Brent Klingforth
Old 07-06-2012, 06:57 PM   #17231
gruman28's Avatar
We race mini on a low traction parking lot. We usually have at least a full heat of mini, sometimes more. Almost everyone at our track runs sweep mini tires. Not only do they handle great, they seem to last longer and cost less than the tamiyas. Do over look them.
Chris
gruman28 is offline   Reply With Quote
Old 07-06-2012, 08:57 PM   #17232
bkspeedo's Avatar
Chris
What compound Sweep are you using?
Brent Klingforth
Old 07-07-2012, 11:06 AM   #17233
Hyde's Avatar
Low traction dusty twisty asphalt:
Hard foam tire inserts front/soft rear
Mid springs in the rear/soft up front
Longer track setup w/longer straight and less turns. stiff in rear, mid in front, same tire inserts as above.
Works for me.
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 07-07-2012, 04:48 PM   #17234
gruman28's Avatar
Most of us use 33's. Some use a combo of 33 and 40's.
Chris
Old 07-08-2012, 12:51 AM   #17235
Big Fran's Avatar
Trader Rating: 14 (100%+)
Hi all. I'm new here but have had RC stuff for the past 30 years.
I just painted my first body in over 10 years. Hope to be getting it out with my buddy in some parking lots soon.
Here are the pics...
Big Fran is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
