Like Tree61Likes
Old 06-11-2012, 11:01 AM   #17191
Can I play too?
Tamiya mini cooper-p1010001.jpg   Tamiya mini cooper-p1010002.jpg   Tamiya mini cooper-p1010003.jpg   Tamiya mini cooper-p1010004.jpg
DLS II is offline   Reply With Quote
Old 06-11-2012, 02:53 PM   #17192
Big Features's Avatar
Anyone have a good M03 set up for TCS rules? I'll be on a slightly bumpy indoor asphalt track. Thanks!
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 06-12-2012, 05:43 PM   #17193
Originally Posted by Granpa View Post
All of this discussion on titanium screws is really a part of a larger topic which is what upgrades do you recommend ????? This has been asked a multitude of times. My philosophy and pocket book says as few as possible. They all fit in the following categories:
1. Increase the durability bearings, aluminum steering uprights, etc.
2. Make the car easier to work on TRF shocks, adjustable turnbuckles
3. Make the car go faster When you really think about it there are few if any upgrades that actually make the car go faster. We are not talking about motors here cause obviously a faster motor will make the car go faster.
When evaluating an upgrade or mod, it has to be justified by one of the above 3 ???? Let's take the titanium screw for example. Durability increase---probably not. Makes the car easier to work on---probably not. Makes the car faster-----you're kidding me. Verdict-----not worthwhile. Except where a tenth of a tenth difference in lap times is important. And that's damn near never.
One of the fastest Minis at our track is an M03 with the following upgrades-----ball bearings, TRF shocks, rear roll bar. That's it folks. A few spacers here and there and adjustable rear camber link made from 5mm short couplers and a 3x12 set screw. Sort of makes you wonder about all these upgrades.
Thank you everyone for the good advice. I think I am just going to keep it simple with only the basic mods noted above and just focus on the driving!
Dirt_McGirt is offline   Reply With Quote
Old 06-13-2012, 04:14 PM   #17194
You never mentioned whether your car was an M03 or an 05. If it's an 05, the aluminum steering bits are a good upgrade, even if they are a little "pricey". If it's the M03, using a Kimbrough servo saver is worthwhile.
There are a lot of things you can do to the car to make it handle better, thus making it "faster", without the expenditure of a lot of $$$$$. Most of the really good Minis around here are pretty basic. We do spend a lot of time and effort on the shocks and spring combinations, ride height, camber, toe out etc. This stuff is as important as the driving except for those who are unusually skilled and can adapt their driving to fit the car. Most, like me, have to adjust the car to fit their driving "style".
My lack of driving skills is almost legendary around here, but I'm able to keep up with all but a few and still beat most. The difference is that my cars are just "tuned" to how I drive. Once you get the car to help you instead of the other way around, you'll understand.
Granpa is offline   Reply With Quote
Old 06-13-2012, 10:25 PM   #17195
toast.'s Avatar
Very well said Granpa - sounds like an RC Koan.
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 06-14-2012, 01:51 AM   #17196
Tim K's Avatar
Be OF the car, but not IN the car ...
Tim K is offline   Reply With Quote
Old 06-15-2012, 10:48 PM   #17197
toast.'s Avatar
I need to replace my mid wheel base Fiat Abarth body, cant stand to look at it all beat up. It seems like the popular bodies are the fiat or swift.
Any thoughts on Shun's CRZ body - does it really make a difference???
Old 06-16-2012, 05:09 AM   #17198
flat4's Avatar
Send a message via Yahoo to flat4
what kind of chassis or chassis's is this?
mo6/ae sc10/2wd slash
flat4 is offline   Reply With Quote
Old 06-16-2012, 08:18 AM   #17199
toast.'s Avatar
"SHUN (#SH001) Honda CR-Z MUGEN body for M05 (225mm)"
Old 06-17-2012, 05:03 AM   #17200
jsr555's Avatar
Trader Rating: 17 (100%+)
My ride.. Tamiya Alfa Giulia GTA on M05 Pro
Tamiya mini cooper-m05-alfa-1.jpg   Tamiya mini cooper-m05-alfa-2.jpg   Tamiya mini cooper-m05-alfa-3.jpg
Xray T4 - Yokomo Bd7-14 - HPI Pro5 - Powered by Hobbywing
HPI RS Pro - HPI Pro 3 - ??
jsr555 is offline   Reply With Quote
Old 06-17-2012, 05:50 AM   #17201
flat4's Avatar
Originally Posted by DLS II View Post
Can I play too?
sorry about that, I'll try this again,...what type of chassis/chassis'es is that?
Old 06-17-2012, 10:21 AM   #17202
Hi,
I have a M03, an ebay special that needs quite a bit of TLC, I think it's going to cost me in the region of 60 to make it factory fresh (without hop-ups). I noticed I can pick up an M05 Alfa Mito for 92, before I spend out on the M03 replacing parts and hop ups, would you recommend spending the extra on the M05? I could always sell the M03 rolling chassis back on ebay.
eyedeebee is offline   Reply With Quote
Old 06-17-2012, 12:59 PM   #17203
Originally Posted by eyedeebee View Post
Hi,
Just out of curiosity, what do you mean by "factory" fresh. You could build a rolling chassis, not counting tires and wheels, with brand new almost everything for that amount. That's here in the USA, but the pricing may be much different in the UK.
Many people new to Minis are absolutely horrified by all the "slop" in a Mini. They will spend a lot of time and effort "shimming" and other tolerance tightening tricks only to find that none of this helps in most cases. That "looseness" is perfectly normal and will not affect the performance in any way.
If it were my car, this would be the program. Buy a "C" parts tree, replace any broken or bent parts, install electronics, new tires and wheels, go have fun. The M03 is a better car than the M05 in most situations.
Old 06-17-2012, 01:21 PM   #17204
M03Racer's Avatar
Trader Rating: 32 (100%+)
Can I play too?
Very nice. What chassis is that.
M03Racer is offline   Reply With Quote
Old 06-17-2012, 01:26 PM   #17205
Granpa- thanks for the response.
The car is pretty badly battered so I've got a new chassis, 2x C parts and 2x b screw bag on order. I also noticed one diff bevel gear is slightly damaged on a few teeth and the gear shafts are worn. So factory fresh to me is replace damaged / worn parts, which will pretty much leave me with a new rollling chassis. I'll keep the old parts as spares. The shocks are being replaced with mini cva's and the drive shafts swapped for UJs.
Can I ask what is recommended for lubing the diff and gears/bearings/axles?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
