Like Tree81Likes
Old 05-29-2012, 06:43 PM   #17131
Originally Posted by ic-racer View Post
I can mention that I found that information useless and frustrating. After ordering the Robinson Racing Products 48P 16T and 18T "Absolute" hardened steel pinions I can post that THEY DO NOT WORK on the minicooper. You need 0.6 mod pinions. I sent the Robinson Racing pinions back and got the Tamiya pinion.
monkeyracing's info is correct. He listed pinions that are .6 module. He did not say to get the 48 pitch pinions. 48 pitch and "48 pitch metric"/0.6 mod pinions are two different things. Maybe you got confused with the wording "48 pitch" metric. Just follow his part numbers 1118 and 1120.
Look here at the very bottom set of pinions.
Sydewynder is offline   Reply With Quote
Old 05-29-2012, 06:44 PM   #17132
Originally Posted by tony gray View Post
Remember this thing?... Only released a few months ago amidst loads of hype and interest.
Is it possibly the biggest m chassis flop ever? We didn't even bother to do Part 2 of our review on the car because Tim lost the will to live after Part 1.
How could Tamiya have got it SO wrong?.............
What is wrong with it?
ic-racer is offline   Reply With Quote
Old 05-29-2012, 06:49 PM   #17133
The post states that 48p and 0.6 mod are the same thing. That information is frustrating and useless and wrong.
Robinson Racing makes a line of pinions in the Tamiya/0.6 mod/48p "metric" pitch.
Old 05-29-2012, 07:01 PM   #17134
His post that you quoted say 48p "metric" and also has tamiya/0.6 mod wording. In the end all that matters is that you got ones that work.
Old 05-29-2012, 07:38 PM   #17135
monkeyracing's Avatar
Dude, not only have I been running these pinions in my minis since 2008, I even gave you part numbers. I can't make it any easier for you.
Part numbers are easy to figure out. EG: 20 tooth would be 1120. 18 tooth is 1118.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 05-29-2012, 10:17 PM   #17136
Mister Pink's Avatar
You tell them Monkeyracing, you tell the world! Robinson racing gears ROCK! In a Tamiya mini chassis. Part # 1120 makes my mini go round.
Mister Pink is offline   Reply With Quote
Old 05-29-2012, 10:22 PM   #17137
P/S hey Jim there's no such it as 48p "metric" gears.
See ya at the track for my kick in the junk
Old 05-29-2012, 11:13 PM   #17138
You're getting crutch to the goodies, pal. My feet don't go that high anymore. Unless I'm falling over in a comical, bungling, Clouseau-esque fashion.
Stab it and steer.
Old 05-30-2012, 06:16 AM   #17139
Originally Posted by TT_Vert View Post
Thank much. Did you use the center predrilled hole or the one closest to the front of the vehicle? Also, do you have your servo saver perpendicular to the chassis or slightly angled? it seemed if I had the linkage at the length the manual recommended the servo arm had to be angled which didn't seem right to me.
Dave
Install it so that the rod is at 90 degrees to the servo arm/saver centerline. That gives you even travel R and L.
Granpa is offline   Reply With Quote
Old 05-31-2012, 07:04 AM   #17140
bkspeedo's Avatar
For those experienced Mini drivers which chassis do you feel is the fastest today; M-03, M-05, M-06?
What chassis is Brandon Koslosky using this year or in the past few to win the TCS championships?
What tire works best on carpet, please provide part number?
Thank you
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 05-31-2012, 07:40 AM   #17141
RobS's Avatar
Thank you
Although I have never run the M06, I have a lot of experience with the M03 and M05. In my experience he M03 is lighter, more nimble but harder to drive, while the M05 is heavier, more consistent and easier to drive. Back to back I think the advantage goes to the M03 (for me at least). The tire setup for carpet I find best for the M03 is M-Grip fronts (50684) with hard inserts with Type A slick (53340) rears with soft inserts. That setup for me works everywhere! However when I ran the M05 I ran M-Grips all around with hard inserts in the front and soft inserts in the rear.
To sum it up in the hands of the right driver I think the M03 has the advantage, however for most its easier to go faster with the M05.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 05-31-2012, 08:22 AM   #17142
Thank you
The M03M or L. Actually, Brandon"s first win was with a M05M. Last year it was a M03M. Both cars used a Swift body. BK and I had been having this conversation ever since the M05 was introduced. Finally got him to admit the M03 was the better platform. The M03 rules at the Tamiya track, although the M05 have been getting better.
The consensus locally is that the M03 is the easier car to chassis tune. It will run well with a wider range of set ups than the 05. The 05 is really finicky on set up. You're either on or way off.
I gave my M06 kit away. It was tough to do, cause most of the guys didn't even want it for free.
Limited experience on carpet, but if you want to run Tamiya tires, the S-grips and the Type A seem to be the best. The S grips take careful tire prep to work though. For the smaller diameter tires the Sweeps are a good choice. You'll have to look up your own part #s cause I'm feeling lazy today and don't feel like looking them up for you.
Old 05-31-2012, 08:34 AM   #17143
CW22's Avatar
Trader Rating: 93 (100%+)
Default Sweeps tires
Hi Grandpa,
For Sweeps tires which type is work at the TCS?
Sweeps 33 or 40?
Please advice me thank you.
CW22 is offline   Reply With Quote
Old 05-31-2012, 08:50 AM   #17144
Originally Posted by CW22 View Post
Hi Grandpa,
Sweeps 33 or 40?
Sweep tires are not legal for TCS racing. Stick with the Spec S grip tire.
Old 05-31-2012, 09:04 AM   #17145
bkspeedo's Avatar
Is there a setup sheet available for the M-03 or M-05? Can you provide a starting point setup even though it's for pavement?
Where's the best place in the US to but tires and parts?
Thanks for the help.
Brent Klingforth
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
tony gray, Tubbers
