Like Tree81Likes
Old 04-11-2012, 06:46 PM   #16876
flat4's Avatar
Send a message via Yahoo to flat4
Originally Posted by k_bojar View Post
if you don't wanna drop the cash on the TRF shocks, and the 3racing ones are hit or miss, get the mini cva shocks tamiya makes..
the clear bodied ones are crap - plastic is brittle...but the mini cva shocks are way better just another option that would be in the same $$ ballpark as the 3Racings ones
thanks for the idea on the cva shocks, the defiantly sound like they will do the trick
mo6/ae sc10/2wd slash
flat4 is offline   Reply With Quote
Old 04-12-2012, 12:46 AM   #16877
Have anyone tried the Team Powers mini-lite motors? how are they compared to the Hobbywing?
Was thinking about getting a 9.5T
MatsNorway is offline   Reply With Quote
Old 04-12-2012, 07:12 AM   #16878
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by FNG RIDER View Post
Here is my just finished M05 Pro build. My base set up is:
Suspension:
Front shocks 55wt/blue springs 3 hole piston
Rear shocks 40wt/yellow springs 3 hole piston
Height: front 5mm rear 6mm
Camber: rear +2
Tow: +1.5
Tires: any combination of S-Grips, Type A/soft and Type A/firm
Drive Train: TA03 Ball Diff, M03 CVDs
Motor: Revtech 17.5/20t pinion
Speedo: Novak Edge
Body: Alfa Romeo Giula (CRX on order)
I will test this weekend at Speedtechrc
did you expand the wheel wells on the alfa? i like how low you got it, but i don't think i'd be able to get away with that for a TCS race
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-12-2012, 08:02 AM   #16879
FNG RIDER's Avatar
The Alfa is from my old M04 rwd and probably wouldn't be allowed for that reason. I'll use it for practice. I have a CRX body on order and will post up pics.
I did hack away the body, TCS allowed me to cut the wheel well before, but then it was only enough to clear the tires. Now its really noticeable.
I'll take the Alfa body to tech just for laughs!
RC10B5, Tekno 410 sct, TA05 v2 Reedy 17.5, Revolt 30, Seaport Tug, Axial SCX10 Rubicon ess sound system.
FNG RIDER is offline   Reply With Quote
Old 04-12-2012, 08:59 AM   #16880
monkeyracing's Avatar
They must allow some slack. Several bodies, including the original style Rover Mini won't fit 60d tires at all without some modification.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 04-12-2012, 04:44 PM   #16881
Don't disagree with you that often, Jim. However, the Rover Mini Cooper body works with the 60D tires just fine. Gets a little close when using the 2 degree rear hubs, but this body was used for TCS racing for a long time. Don't see it much anymore since most guys run the mid or long WB cars now.
The body of choice for the MWB cars is the Swift and the best body for the LWB car is the BMW or the 2006 Cooper. The others just don't seem to work as well. You, of course, may find other bodies working better at certain venues, but so far have not run at any track where this was true.
And No, they don't allow much, if any body "butchering" at a TCS event.
Granpa is offline   Reply With Quote
Old 04-12-2012, 05:01 PM   #16882
Maybe I'm trying to mount them too low. I've always had to hack up the wheel wells to gain clearance. One of my fellow racers got a better idea. He used a heat gun to reshape the body subtly. Very cool work on his part and fit within rules as the body was cut along the proper lines, etc.
EDIT: Y'know what? I've just been looking through my photo collection and discovered that we're both kind of right, Bob. Tamiya seems to have made a few versions of the Rover Mini shell over the years and several of mine fit just fine without any tweaking. It appears that some versions were designed to work with 55D tires and some with 60D. I've got a really early version in a box around here someplace. I should have a look at it. I'm pretty sure the reason I never used it was because I couldn't make it fit.
Stab it and steer.
Old 04-12-2012, 05:53 PM   #16883
Firefox's Avatar
Originally Posted by tony gray View Post
A new release Mini from Tamiya. M05 (LWB we assume) JC Works Mini Coupe.
The body set is Tamiya 51489
Tower Hobbies shows it as being available mid April.
http://www3.towerhobbies.com/cgi-bin...I=LXCBCZ&P=SM#
Tamiya M05, Associated SC10.
Firefox is offline   Reply With Quote
Old 04-12-2012, 08:08 PM   #16884
wollow86's Avatar
My new mini body:
My sister painted it for me with a matching TC for an event I have on the weekend. Its her first go airbrushing so I think it turned out pretty good.
Its a Colt New Mini, SWB.
On the rover mini 60D debate you guys are having, I found my tamiya mini difficult to fit the 60d sized tyres under, they rubbed front and rear.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 04-13-2012, 01:03 AM   #16885
Default Ezrun 13.5 troubles.
You guys with the ezrun 13.5's fitted, do you have have any cutting out issues at full throttle up the straights? A mate is running this in his M03 with a lipo and getting exactly this. He doesnt have the punch or the timing cranked right up. I was thinking of fitting a power cap?
scoop is offline   Reply With Quote
Old 04-13-2012, 01:29 AM   #16886
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
I think the Monte Carlo Rally Mini shell has smaller wheel wells as it is designed for the 55D tyre.
marcos graveyar is offline   Reply With Quote
Old 04-13-2012, 02:03 AM   #16887
I have noticed that the Tamiya CVA black shocks need some improvements:
1) The shafts are often dinged up and need smoothing (2-6 dings are typical and can be felt with your fingernail.) Use a hobby knife to "shave" the ding repeatedly until it is mostly gone, do not sand it or scrape with the blade vertical wrt the shaft, and
2) Assembly instructions have you insert the o-rings into the shock body and then push the shaft through. I do it the other way around, sliding the well oiled shaft and o-rings together and then sliding the pieces into the body. Less possibility of scratching the o-rings that way. Note the e-clip is already on the shaft.
Cheers
RedRover is offline   Reply With Quote
Old 04-13-2012, 03:30 AM   #16888
niznai's Avatar
I don't think that is possible. To insert the shaft with the e-clip on you have to insert it from the top of the shock body, whilst the o-rings go from the bottom. And you need to have the piston on too.
It is true though that you can put the shaft through the body and then put the o-rings on the shaft (at the other end) and then slide them home. This is my preferred method.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 04-13-2012, 07:37 AM   #16889
StarrRacing's Avatar
Default New Mini Body #1
I got this body when I bought my Used M05... don't know what car it is...
Jeff Starr
U.S. Coast Guard (Retired)
Traxxas 4x4 (x2), Associated SC10,
XRay T3 '009 (VTA), XRay T3 '10 (USGT), Tamiya M05 (Mini),
Tekin, Spektrum.
StarrRacing is offline   Reply With Quote
Old 04-13-2012, 07:40 AM   #16890
Default New Mini Body #2
Another I got when I bought my used M05.... don't know what it is.... lol
Jeff Starr
Tekin, Spektrum.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
