Like Tree137Likes
Old 06-21-2006, 08:25 PM   #1666
akuhon's Avatar
Originally Posted by ICEMAN
the bumper kit is made by EAGLE RACING , a lot of their stuff is imported threw Integy but they do not list that part# , the # is 1229. it shows it on Eagle's website , maybe some others can help and we can all locate some, Cya
DO you have the pics ?
I've just visited eagle-racing website but no pics.
I think it's an old product, listed under M03 parts
akuhon is offline   Reply With Quote
Old 06-22-2006, 02:28 AM   #1667
ckbridge's Avatar
For better bumpers on the M03 chassis would the M04 bumper fit, using part # 50850 (E2, E3) for the bracket and part # 6275061 for the urethane bumper?
I know that the bumper for the TL01B does fit. Use part # 0005688 (C11, C20). It’s a “kick up” type buggy bumper/skid, but fits fine.
I also found M03 speed tune gears at Integy.
http://integy.automated-shops.com/cg...40106283600.0b
while looking for the bumper, which is not at integy.
If anybody tries the M04 bumper let us know if it works.
ckbridge is offline   Reply With Quote
Old 06-22-2006, 09:01 AM   #1668
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
I'm pretty sure the M04 bumper will not work, the m04 mount has a tapered screw pattern, where as the TL01 / M03 has a straight pattern. 2 of the 4 holes might fit, you could create new holes in the chassis for the top holes
tamiyarcracer is offline   Reply With Quote
Old 06-23-2006, 09:27 AM   #1669
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Any reports on how well the RP30 and RP36 mini tires work?
Which are better for them, the Medium or Medium-soft inserts?
-=≡ Tamiya TA05 · TRF415MSX · F103R · M-03R · M-04 · M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 · OFNA LD3 Pro · Fastcats · Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 06-23-2006, 09:32 AM   #1670
SpeedTech's Avatar
Spoke to Adrian over at Schumacher who imports the RP tires and the RP36 has been working very well at our local track (indoor high-bite asphalt) and the 30 has been working well on out door asphalt. I'll talk to other mini racers to see which inserts they run in what compound.
We actually have a large shipment of RP mini tires and inserts coming in along with bodies, spare parts, hop-ups, and we are putting together titanium screw kits and ceramic bearing kits for the mini. Also, we're trying to get a couple more different kinds of bodies from Japan for the Mini into the states.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 06-23-2006, 10:17 AM   #1671
Steve Wang
Keep me posted on the bodies Steve
Old 06-23-2006, 10:54 AM   #1672
At our indoor track we are running the med firm insert and 36 on the front and med firm with 30's rear
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 06-23-2006, 11:02 AM   #1673
Originally Posted by Difuser
At our indoor track we are running the med insert and 36 on the front and med with 30's rear
Dan we only got Medium and Medium soft inserts we need medium firm and firm inserts
Old 06-23-2006, 11:10 AM   #1674
What Troy said oops
Old 06-23-2006, 11:12 AM   #1675
AdrianM's Avatar
Take Off only makes a Medium and Medium Soft insert there is no insert firmer than Med. The Mini tires with the Med inserts are not all that soft.
Adrian Martinez
Old 06-23-2006, 11:59 AM   #1676
What Adrian said too...
Old 06-23-2006, 12:41 PM   #1677
RaceBucks's Avatar
A friend bought the RP30's but traction rolled so much that he went back to x-patterns. He loaned them to me and I could hardly turn without rolling. We are on high traction asphalt. Any tips from someone having them work? RP's are great on our sedan's so I wanted them to work on the mini; any thoughts?
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is offline   Reply With Quote
Old 06-23-2006, 01:46 PM   #1678
Jam-ehz's Avatar
How much traction compound are you using on the tire? Just start using a thinner band toward the inside of the tire until you get the sweet spot between acceleration grip and minimal rollovers..
I put a layer of CA glue on the outer sidewall of sedan tires to reduce rolling for my TC, why not mini tires?
Old 06-23-2006, 01:52 PM   #1679
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
at my local track (Glen Burnie Hobbytown, MD.) Many people run the 30's. A few run the xpatterns, some run tamiya slicks. Me personally, i like the S grips with about half the tread worn down.
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 06-23-2006, 02:22 PM   #1680
RB as corrected before by Adrian and Troy. I am running the 36 fornt which should help lessen bite a bit. I have the medium insert in the car and it could prolly use a bit stiffer insert like the Hpi. you can use CA on about a 1/16" stripe on the very outer edge to also reduce side bite a bit. You don;t need much and it will do the trick. Our bite is very similar to SoCal but our track is a bit more abrasive.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
