Like Tree1Likes
Old 02-22-2012, 08:15 AM   #16756
What is the preferred method of mounting a 2.4 receiver, and more important, the antenna tube?
Pics would be cool. Thanks guys.
Losi Mini Desert Truck- big 370 motor/lipo
BL Micro Rally- 3s lipo. Too fast for its own good.
OnlyVees is offline   Reply With Quote
Old 02-22-2012, 05:07 PM   #16757
I mounted my reciever on my m05 rear part of chassis where the servo is with tray removed, mounted sideway. ESC sit the same but on otherside of servo. oppersite the motor. to keep the left/right weight distrubtion correct. i have my short annenta tube mounted in the hole in rear, with wire going though the bottom of hole.
Vrooom is offline   Reply With Quote
Old 02-23-2012, 04:37 AM   #16758
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
I do something similar; receiver mounted with velcro on the opposite side to that suggested in the build manual. Antenna relocated to unused transponder retainer's mounting hole, small blue 3mm shim to make the countersunk hole flush with the plastic.
marcos graveyar is offline   Reply With Quote
Old 02-23-2012, 05:24 AM   #16759
wollow86's Avatar
Local rules mean we have to build as per instructions, except for transponder mount, so have to use the platforms for the esc/receiver.. Here's my layout on an M05 SWB.
I used to use the same method of where the transponder stay was meant to mount but now I have a simpler option
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 02-23-2012, 06:30 AM   #16760
Why the carbon between the mount posts ?
Old 02-23-2012, 06:53 AM   #16761
Old 02-23-2012, 07:03 AM   #16762
wollow86's Avatar
Its a body post stiffener made by Ride. It just looks like carbon, its actually plastic. Stops the body from moving around so much during cornering. It's got body clips above and below to prevent it from moving (and thus holding the posts stable)
Last edited by wollow86; 02-23-2012 at 07:06 AM. Reason: figured out you weren't talking about the chassis weight
Old 02-23-2012, 07:36 AM   #16763
pejota's Avatar
Looking for a little advice...
Might be in the market for a Tamiya Mini....
Can i get some suggestions on a used kit? M03, M04, M05
...or...
Which brand new kit should i look at, M05 or M06.
I know that's a rather vague question, but my knowledge of Minis is basically zero. I already race VTA and 17.5 so i have onroad knowledge, just no frame of reference for a Mini.
Thanks!
pejota is offline   Reply With Quote
Old 02-23-2012, 07:48 AM   #16764
sosidge's Avatar
...or...
Thanks!
First task as ever is to see what is popular, what is permitted, and what performs well at your local track.
But the basics are...
M-03 - Front wheel drive, goes well straight out of the box, higher CG and less possible adjustments so perhaps not as quick as the later M-05.
M-04 - Rear wheel drive, mid-motor, hard to get going well even when they were current, different gear ratios to the current cars. Not a great basis for a racer unless you think you can tackle the challenge.
M-05 - Front wheel drive, needs some tweaking from out-of-the box settings to go well, lots of adjustments. Probably the most sensible starting point.
M-06 - Rear wheel drive, rear motor, harder to drive but in the right conditions can be the fastest Tamiya mini of them all.
Old 02-23-2012, 07:49 AM   #16765
kaiser's Avatar
mo3 or mo5, thats the most popular. they are front wheel drive.
the m06 is rear wheel and not very poplular, in my area atleast.
can't go wrong with either the m03 or m03, both excellent cars, i preffer the m03, just because i've had it forever.
vintage for life! Jrx2/JrxPro/RC10/RC10ce/RC10 graphite/RC10 oin/RC10T/RC10T2/RCPS sprinter/Optima x2/Scorpion/too many old tamiya's to list
RCHR.biz
kaiser is offline   Reply With Quote
Old 02-23-2012, 07:52 AM   #16766
Wollow86, that is serious amount of toe-out....
pejota, M05 or M03 is the one to buy. M05 is newer chassis, M06 and M04? is RWD chassis.
Old 02-23-2012, 08:04 AM   #16767
pejota's Avatar
Thanks already!!!
We're essentially starting the class from scratch. I think one person has an M03 or M04, but i honestly don't know.
We're looking at Silver Can or 25.5 brushless, box stock gearing and that's about it so far.
I'd rather get something that has good parts support... are M03 parts still available?
Old 02-23-2012, 12:41 PM   #16768
justchris's Avatar
[QUOTE=Vrooom;10370554]Wollow86, that is serious amount of toe-out....
As above is there a reason for a setting
like this wollow 86 ??
TC6 Savox ] TC6.1 Sanwa ]
XL 5.9 Optifuel] M11X 2.4G ] 6000 IP lipo
justchris is offline   Reply With Quote
Old 02-23-2012, 04:48 PM   #16769
Mr RCTech's Avatar
You can adjust your front steering arms for more ackerment if that's what you need.
Mr RCTech is offline   Reply With Quote
Old 02-23-2012, 05:38 PM   #16770
wollow86's Avatar
There is definitely a reason. It stops the wandering on the straights. And I mean stops. My car tracks straight as an arrow . The toe out also helps the initial turn in, which you lose when you have a heavy diff (300,000wt), and have such a soft rear/hard front.
Everyone locally comments about it as well, but when they drive my car they cant believe how good it is. Its an RC-Mini.net tip.
Admittedly, I am trying to dial it back a bit, taking it out in small steps.
Also I managed to hit something a while back, and the car was pulling right. But after the race I couldnt find anything wrong with the car. I've checked the uprights, c hubs, ball studs... nothing is bent. When I used the trim to straighten the cars tracking there was more toe out so I took some out. But it doesnt seem to effect the performance of my car.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
scirocco14
