Old 02-18-2012, 09:23 PM   #16726
gtfour93's Avatar
Trader Rating: 22 (100%+)
Originally Posted by clayrace24 View Post
Who makes that body, where did you get it, and what wheelbase are you running. Looks nice! I'd like to replicate my '72, but it won't be the same without the ass end hangin' out in the corners!
Clay
ABC Hobby's 240Z version is 210mm & HPI's version is 225mm. There is also a 240ZG (wider flares) version for 1/10 by ABC Hobby.
gtfour93 is offline   Reply With Quote
Old 02-18-2012, 11:05 PM   #16727
dirtman71's Avatar
Dirtman71 wrote: Got my 240z body done
Clay
TeamBluegroove on eBay for $30 shipped. 210mm wb and 160mm wide. Almost 170 at front fenders. I like it but tight on the battery wires. The scale look fades on the lower front end. And I wish it had the rear wing No window masks but has the overspray mask
I wasn't going for super scale and I know that the body will get thrashed pretty quick since I am new to on road. A 240z has been one of my favorite cars since I was little, that along with the 510. It was $10-15 cheaper than any other body. It didn't have bumpers or a stick kit.
Kyosho SC-R, RC8Be, Jammin X1CRe, Jammin SCRT10, RC10GT2, T4.1
Slash 2wd ChuckWorks slice B2, E-maxx, RC10T3, Tamiya M-05, TA-05
dirtman71 is offline   Reply With Quote
Old 02-19-2012, 01:42 PM   #16728
New to the thread, putting an M05 together this week. Do I need grease on the idler, spur and diff gears? Seems like this would add considerable drag...
Running box-stock silver can motor with cheapie NiMh cells.
Losi Mini Desert Truck- big 370 motor/lipo
BL Micro Rally- 3s lipo. Too fast for its own good.
OnlyVees is offline   Reply With Quote
Old 02-19-2012, 03:11 PM   #16729
wollow86's Avatar
I did when I first built mine, and I'm planning on it with the wifes m05 when it arrives next week. But I do think it adds drag to the car initially, but as the excess spins of the gears I think it gets faster. I haven't added any extra since I got the car.
Of course if anyone wants to share ultra fast mini secrets, I'm listening.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 02-19-2012, 03:47 PM   #16730
dirtman71's Avatar
I have some new gears comming and I was thinking about trying some chain wax for motorcycle chains that I have. It is a liquid that dries into a thin wax. Anything that doesn't atract dirt has to be better
Old 02-20-2012, 11:33 PM   #16731
Decampong's Avatar
Unhappy Mini Keeps On Tumbling Over When Turning
Hi guys,
I have an M05 S Spec, Long Wheel Base Config.
It keeps on tumbling over while turning and it is not funny anymore.
Set-up:
- front hard white springs with BLUE pen marks
- rear hard white springs with YELLOW pen marks
- tires are Tamiya slicks with medium foam inserts
- ride height is that the arms are parallel to the ground
- oil is the oil that comes with the kit
- my EPA is already at 60% and if I go any lower, the car won't turn anymore
- the tracks are asphalt high grip indoor
- shocks are the blue TRF shocks
What am I doing wrong?
Decampong is offline   Reply With Quote
Old 02-20-2012, 11:40 PM   #16732
monkeyracing's Avatar
1. Gears: Don't grease the gears! Run them dry, or use a tiny squirt of spray silicone.
2. Traction roll: Have you tried applying a tiny bead of CA glue to the sidewall of the front tires, right where they meet the tread?
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-20-2012, 11:47 PM   #16733
Decampong's Avatar
Thumbs up
Hmm....this is great stuff!
I will try both of those!
Thanks!
Any more tips from the experts?
Thank you RC Tech!
Old 02-21-2012, 01:58 AM   #16734
Mount your electronic very low, maybe you run harder tyres in front to reduce the traction roll.
Vrooom is offline   Reply With Quote
Old 02-21-2012, 02:08 AM   #16735
You're welcome. I'm a dedicated fan of the Tamiya Mini class. I mean, who else d0 you know that has a full set of brand new HPI/Ronal Teddy Bear wheels with new/old HPI radials? Yup, only me...because I'm a dork.
Stab it and steer.
Old 02-21-2012, 02:20 AM   #16736
tony gray's Avatar
No...someone else does too Jim....
tony gray is offline   Reply With Quote
Old 02-21-2012, 02:34 AM   #16737
Hey,
this is great for the Gears, its cheap, about $5.99 to $6.99 a can, for 10oz.
more than a lifetime supply, and its made by "DuPont. use it sparingly.
its; DuPont Teflon Silicone Lubricant. i got it from Amazon for $5.49 Midway Auto Supply + $4.42 shipping. or try Auto Supply Store.
Product Description
A clean, light duty lubricant. Excellent for non-metal materials that may be damaged by conventional lubricants.
Helps prevent sticking, binding and freezing. Formulated with DuPontTM TeflonŽ fluoropolymer to outperform other silicone sprays in both metal and non-metal applications
Clean, non-staining and odorless Waterproofs, protects, lubricates and preserves
For use on rubber, plastic, vinyl, leather, metal and wood Eliminates squeaking and binding in windows, hinges, locks, etc.
Helps prevent rust, oxidation and corrosion on all metals Protects o-rings, fishing gear, tools and farm equipment from salt, chlorine and corrosives
-D
I did it is offline   Reply With Quote
Old 02-21-2012, 02:37 AM   #16738
sosidge's Avatar
Originally Posted by Decampong View Post
Hi guys,
Set-up:
Try and build the car with a tiny amount of droop if you haven't already.
Old 02-21-2012, 02:47 AM   #16739
I thought the Aussie versions had koalas or beer cans on them.
Stab it and steer.
Old 02-21-2012, 04:53 AM   #16740
Do you know if i need to put in rubber o-ring in diff output shaft with CVD kit ?
it is rather tight there.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
