Old 02-15-2012, 11:32 PM   #16711
dirtman71's Avatar
Oh man....raced my M-05 for the first time last weekend what a blast. Even if I screwed things up. Normaly there are like 10 mini's but Sun they had 23. the first heat I got in only 2-3 laps before I lost a rear wheel nut. they got the wheel back on and found the nut, but over tightened the nut so it just pulled to the right. Oh well.
the 2nd heat went much better. after a few laps started to get a feel for it and started pushing it a bit. I was suprised at how hard I could push it. I could run WOT through everyting but like 2 corners. Still had a hard time keeping a tight line. I finished 4th. but my times were all over the place. up to 6 sec. last 5 laps were within a sec though. but I was still 5 sec per lap off of the fast guys
made it to the b main and broke a c hub and couldnt steer about 3 laps in, finished in 10th out of 13.
here is something I noticed. We are all running silver cans, but in the second heat i was getting passed on the straights. I just didnt have the top end that some of these guys had. I was running the sweeps @ 55mm compaired to the 60d's. Maybe they ran the highspeed gears. I know some of them are serious about the silver cans and they have found the fastest motors
all I know is I have to find more top end and work on my line
Kyosho SC-R, RC8Be, Jammin X1CRe, Jammin SCRT10, RC10GT2, T4.1
Slash 2wd ChuckWorks slice B2, E-maxx, RC10T3, Tamiya M-05, TA-05
dirtman71 is offline   Reply With Quote
Old 02-16-2012, 03:43 AM   #16712
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Originally Posted by BoneCrusher View Post
The 1st round Tqer (Rick), decided to make me a gear diff with white putty in it and told me to test that
Any more info on this, what exactly is "white putty" ?
How much is used ?
marcos graveyar is offline   Reply With Quote
Old 02-16-2012, 04:41 AM   #16713
Can Tamiya (54192) M05 Aluminum Steering Link work with stock plastic cam thingy (the one sit on bearing), or do i need additional parts (tamiya 54191) to make it work ?
I only needed steering link to make car go straighter..
Vrooom is offline   Reply With Quote
Old 02-16-2012, 04:53 AM   #16714
Almost done building my new M05 Pro. As usual with the Tamiya kits they're a joy to build Need to assemble the shocks and fit some more electronics in there, and paint the Nissan Silvia S15 body I got with it. Unfortunately I'm having issues finding PS-59 dark metallic blue here in Sweden but I'll find it eventually
Tamiya mini cooper-photo-2012-02-15-21-39-35.jpg   Tamiya mini cooper-photo-2012-02-15-21-39-56.jpg
nbla is offline   Reply With Quote
Old 02-16-2012, 05:24 AM   #16715
wollow86's Avatar
I have heard of special bearing treatments to make them freer. Like removing the shields for example. I've never bothered to do that because I don't want to be replacing bearings every meeting because I got a bunch of crap in them.
But I'm starting to think that minis free up a bit as they get older. Mine seems like its gotten faster as its gotten older.
The other things to consider are the tyre diameter, as you stated, does make a difference. Also the diff. A properly set diff will give better drive off the corners, and prevent the car from diffing out and essentially being 1 wheel drive.
Dont forget batteries, what type and what capacity batteries is everyone running? Or motor temps. If they have a heat sink and you dont your motor may not be performing quite as well.
And finally, silvercans are not all created equal. There's a reason some people buy 5 of them and water dip and so on... I'm just glad we use the hobbywing system
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 02-16-2012, 10:01 AM   #16716
dirtman71's Avatar
Some of these guys take this way to seriously. they will dyno 20 motors to find the best one. 3-4 of them race 3 times a week. if we keep having 20+ mini's then maybe we need a novice class.
I am running a Gens ace 3000mah 25c 2s. One thing that is hurting my speed is I am getting sand inside my gearbox. I will get a piece or 2 stuck in the gears. I taped over the extra holes for the motor mount and nothing is cracked and it fits together like it should. Going to open it up again today and look for anything I misssed.
It is time for new gears. What is the feedback on the high speed gears?
before I put new gears in I need to solve the sand issue. running a silver can will I loose to much bottom with the high speed gears?
Old 02-16-2012, 10:09 AM   #16717
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
How much is used ?
We fill the diff with poster putty, the adhesive putty. I got mine at the dollar store, so no questions on how much it costs
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 02-16-2012, 10:40 AM   #16718
Mr RCTech's Avatar
KOOL TOOL!!
http://www.rctech.net/forum/attachme...ffmaster_1.jpg
Mr RCTech is offline   Reply With Quote
Old 02-16-2012, 02:22 PM   #16719
AJGr33n's Avatar
Looks good, looking forward to seeing what it looks like finished.
Team: AJRacing
Car: Tamyia MO5-Pro (Venom 13T)
AJGr33n is offline   Reply With Quote
Old 02-16-2012, 02:51 PM   #16720
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Welcome to Mini World! Blue bling is always nice to have, but in your case, not so sure it suit those wheels. Maybe some black wheel nuts would look better.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 02-16-2012, 02:55 PM   #16721
Thanks!
Yeah I know it looks silly, and probably even more silly when I get my body painted. I will probably end up stealing the black nuts from my TT-01, I just wanted to see what it looked like with the wheels on
TT-01, TT-01, DF-03Ra, TB-03, M-05 Pro
Old 02-17-2012, 02:03 AM   #16722
Yes. The M06 Pro has that AL piece in the kit and the 2 plastic steering arms (cam thingies) are used with it. M05 and M06 steering parts are basically the same.
Sydewynder is offline   Reply With Quote
Old 02-18-2012, 11:29 AM   #16723
dirtman71's Avatar
Got my 240z body done
Old 02-18-2012, 03:23 PM   #16724
AJGr33n's Avatar
Nice
Team: AJRacing
Old 02-18-2012, 06:44 PM   #16725
clayrace24's Avatar
Trader Rating: 38 (100%+)
Dirtman71 wrote: Got my 240z body done
Who makes that body, where did you get it, and what wheelbase are you running. Looks nice! I'd like to replicate my '72, but it won't be the same without the ass end hangin' out in the corners!
Clay
Losi 8be 2.0, AE B44, BMI COpperhead 12,Tamiya F104,Tamiya M05 Mini Cooper, Xray T3 2011
clayrace24 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
