Old 12-30-2011, 02:15 AM   #16366
tony gray's Avatar
Interesting idea Mats, but still wont fit.
The spacing for the mounting bolts is different on the 380 size can. And while you could possibly drill/slot new holes it still wont fit as the 'glued on end' will hit the layshaft and the belt tensioner support...
tony gray is offline   Reply With Quote
Old 01-01-2012, 08:05 AM   #16367
Core Creations's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Core Creations
Tamiya M05 pro Blue Edition with hop ups! Tics. Nice blue M05 for sale
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-01-2012, 11:17 AM   #16368
Send a message via AIM to Profoxcg
did you guys run the TA05 M Four yet?
Profoxcg is offline   Reply With Quote
Old 01-01-2012, 01:03 PM   #16369
tony gray's Avatar
Patience my friend, or a Jedi you will never make....
Tim K is on the job, hopefully mid week (fingers crossed).
Old 01-02-2012, 03:18 AM   #16370
tony gray's Avatar
Check this out.
Actual IN CAR footage from Tony P's car at Coburg Velodrome today...... And no it's NOT speeded up, that is the actual speed the cars are going. Prepare to be amazed..
+ YouTube Video
Old 01-02-2012, 03:56 AM   #16371
Monkeys punk's Avatar
Great movie. Wish we had somewhere like that in the uk. We have an indoor one not to far away but not enough interest to book it anymore. Is this with kit gearing ?
Top Racing Sabre mini
Tamiya m05
Sakura zero
Monkeys punk is offline   Reply With Quote
Old 01-02-2012, 07:15 AM   #16372
justchris's Avatar
Great vid!!!!!!!!!!!!!!!!!
As monkey says nothing like that overhere.
What is that thats running
TC6 Savox ] TC6.1 Sanwa ]
XL 5.9 Optifuel] M11X 2.4G ] 6000 IP lipo
justchris is offline   Reply With Quote
Old 01-02-2012, 02:36 PM   #16373
tony gray's Avatar
We have indoor Velodromes here too, but they're polished wood, no grip....
All cars in the video are M03/05's with Hobbywing 5.5 turn system. Speeds of around 80km/h.
The SCT truck (getting passed by a Mini!) is a HPI Baja clone.
Old 01-02-2012, 07:50 PM   #16374
dirtman71's Avatar
looking at getting a Mini Cooper just for some fun club racing. all I know is that they run them stock brushed, FWD.
I have a few questions that I cant realy find an answer for. Should I get a M-03 or M-05? It looks like the pro kit has the oil filled shocks...what shocks should I use if I get a regular kit?
I have a bunch of 2s lipos but they are square not round, can you make the regular lipos work?
It does look like the regular kits do need some upgrades and I would probably be better off getting the pro kit...but I like the $110 kit price, just looking for a fun, cheap way to move into a little on-road.
Kyosho SC-R, RC8Be, Jammin X1CRe, Jammin SCRT10, RC10GT2, T4.1
Slash 2wd ChuckWorks slice B2, E-maxx, RC10T3, Tamiya M-05, TA-05
dirtman71 is offline   Reply With Quote
Old 01-02-2012, 08:14 PM   #16375
After installing the TA03 ball diff (built as per rc-mini) on my m03, i felt improved on-throttle steering and more well behaved rear, but felt the car lost some off-throttle steering. Any advice on how to increase some off throttle steering, without compromising the rear grip, or is this a compromise I have to live with for the ball diff? Am using the red/yellow springs F/R with the kit oil (super mini CVA) and spice 40R all round. Running mainly on unprep asphalt (prob low grip) Hope I do not have to spend on new tyres though...
Thanks!
stocker is offline   Reply With Quote
Old 01-03-2012, 02:22 AM   #16376
Butler205's Avatar
Thanks!
I have been through the same and just completely rebuilt my car after 2 years of racing on the same surface type. I had my TA03 diff built tight with AW grease. I have this time built it looser with normal ball diff grease and glued the bolt. Overall my car is better in this area, but I have also made some other changes, so can't say it will definite help. I think it will be compromise and a case of finding the balance you like.
Full info here.
http://www.tamiyaclub.com/forum/inde...d=438408&st=0&
M05 Racer(retired) FF03 Racer - Brushless Hyper 7 Basher
Butler205 is offline   Reply With Quote
Old 01-03-2012, 03:12 AM   #16377
tony gray's Avatar
Get an M05S if you can afford it. If not, buy the Pro kit but you'll still need to change the shocks as the clear ones break.
You CAN'T make the square lipos fit sorry - end of story..
Thanks!
Tyres...you cant run Spice 40's all round, it'll never work. We ALWAYS run softer tyres on the rear. And Spice 40's are super hard anyway!
If you're keen to stay with Spice I'd suggest 36 front/28 rear.
Old 01-03-2012, 03:48 AM   #16378
Butler205's Avatar
How would running softer rear tyres improve off throttle turn in?
Old 01-03-2012, 04:04 AM   #16379
caltek1's Avatar
Trader Rating: 33 (100%+)
TFG,
You can make the square batteries fit a MO5, if your allowed to modify the chassis. Happens all the time in Thailand.
I know it is not kosher for USA TCS racing or here in Australia, but is legal for Asia.
Later,
Calvin.
Tamiya mini cooper-166354_178088465555020_100000616047479_493677_2298783_n.jpg   Tamiya mini cooper-268364_229741433723056_100000616047479_814694_1970560_n.jpg
caltek1 is offline   Reply With Quote
Old 01-03-2012, 04:12 AM   #16380
caltek1's Avatar
By running a softer rear tyre you will have more rear grip. If you want more steering then either lower front ride height, soften front spring and harden rear spring or use a softer oil up front.
All up we only ever run a harder tyre on the front and a softer tyre on the rear. That is what we have found best, when using the HW 13T BL system in our cars.
The other option would be to purchase the front shock tower for the MO5,(CF or alloy) and stand the front shocks up which will give more steering.
But hey, you should test things on your own car and running surface and decide what works for you.
After you have tried that, then try making the car wider or narrower front/rear, wider front/narrow rear etc. You might find that a combination of factors will make your car work better for you.
Once you have a decent setup then driver the wringer out of it and don't adjust anything.
Just my two cents.
Me , I know what makes me semi competitive. I have a base setup that I do not touch and tune only with tyres and inserts. I do not change anything when running on carpet or asphelt, just the tyres and lower or raise ride height. Car works good for my style of driving.
A wise man, TFG, advised a few years ago get a pretty decent setup and then learn to drive the car and stop messing with it. Took a little while for that to set in, but it is now working for me.
Later,
Calvin.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
SEO by vBSEO 3.5.0
